Jeti DS-24
#1677
My Feedback: (53)
‘I’m pretty sure I like my DC-24 much better then any DS radio......the exact reason I when with Jeti (DC-16) when I first saw them....to make a blank statement like that one..is a little......
#1678
Hi Everybody
I have a problem with my new DS24. The rotary dial sticks in the down position every now and again when i push the button. Any suggestions on how I can remediate ?
Many Thanks
James
Many Thanks
James
#1679
#1685
I think he is referring to the silver button in the center of the rotary dial that we use to move around the menus/settings. It sounds like the silver button does not pop right back up after he presses it each time.
#1686
Yes. I don't usually push the rotary part. I always push from the center. On the 16/24 the center is silver so I always felt it was meant to be pressed and not the rotary part. Maybe pressing the rotary part puts it an angle which causes enough friction for it not to pop right back up. Just a thought.
#1688
Been flying for 41 yrs, first a digiace, then futaba, then century's (single stick and dual), JR/futaba mix, then graupner then spektrum, then jeti and probably about to try a core. So have been around the bock a bit, yet I have zero brand loyalty. In there day all of the above TX's had their +/-.
When something works I use it when I doesn't I don't. Most people hold onto stuff that they might not normally want to only due to the upgrade costs which these days can be substantial.
The extent some show in regards to brand loyalty, the never ending battles on forums is a strange occurrence. Be prepared as every RC brand since the beginning of time has enjoyed a peek and then a demise, nothing will change there.
I have drawn your ire as you believe I have questioned the joy of your life, a remote control unit.
My comments have not been focused on how good one TX is versus another, it had been about the change in the 900mhz system on the newer version that will not be compatible with previous. Additionally I commentated that a 12, 16, 24 hybrid from jeti could probably be in the works to reduce product lines.
Now if someone from Jeti chinned in and said don't worry we have a fix in the pipeline regarding the 900mhz concern then end of conversation.
Regards,
Regards,
Dansy (08-01-2020)
#1690
#1691
My Feedback: (53)
Regards,
Regards,
#1692
#1693
How can one militarize a discussion regarding a remote control unit?
Fix, as the 2.4 and 900 are on one plug in board it would not be very complicated.
Regards,
Regards,
#1694
#1695
My Feedback: (9)
I'm really confused about this fuss over the 900mhz rec. Im guessing very few people are using this as a backup. I've seen people say they have flown their planes with the 900 alone to test it out. So I'm guessing in the event your two 2.4s go out the old 900 will do the job just fine. You act like the new 900 is world changing and somehow makes the old one obsolete. For pete sake this is just a backup receiver that more than likely will never be called upon in your planes lifetime. And i'm sure jeti will sell the old 900 as long as there is a demand for it. I do run a 900 in all my jets and dont have the slightest concern it wont do the job it was intended for.
uncleTom (08-01-2020)
#1696
My Feedback: (20)
Craig,
Here is my 3D printed stand for the DS-24. It was designed by my friend Keith (yellowbird911) . The one in the photos has been working great for 2 years. I love it. It slides on the handle from the side with the DS-24 handles going through the opening. It has just enough friction to hold position and then easily fold for storage.
The link is on Thingiverse. I don't know if the link is his latest mod as the first one I used split where it goes around the DS-24 handle. The mod was to add material around the base of each side of the bracket that slides on the DS-24 handle. I can find out from Keith if he has a later file with the mod.
Gary
https://www.thingiverse.com/thing:2886136
Gary
#1698
My Feedback: (7)
Those cases hold up really good, we use them at work, UA, we have been using them for about 2 years now and the abuse they get from the guys at the airport is immense, we have like 40 of them, solid cases, I wouldn't hesitate to buy one of them if I was on the market to get one.
