Jeti DS-24
#2051
My Feedback: (10)
Thanks again Mark. The first video is for pre-REX receivers using serial link PPM Positive instead of EXBUS and EXBUS/Backup. In the 2nd Harry C video he doesn't show which port the secondary receiver is plugged into. So maybe it does go into the EXT port on my R3/RSW, but I've seen it work using R3/RSW port 2 however it won't work that way with mine.
I'm trying to have a REX10A for primary, an R3/RSW for secondary and a REX3 900 for back up. What I've seen work is REX10A port E1 to R3/RSW port 2 and REX10A port E2 to REX3 900 port E1. I just can't get mine to work when plugged in that way following the Harry C and Esprit videos. It's probably some simple setting I need to change in the DS-24, but so far I haven't found it.
#2052
Harvey,
Connect Port 4 (EXT) of the R3/RSW to E1 of the REX.
Make sure via Device Explorer that the output of Port 4 of the R3/RSW is set to EX Bus, not ppm.
Also confirm that E1 of the REX is set for EX Bus also.
I'm running this setup with a REX7 and R3/RSW in dual path and it works just fine.
Paul
Paul
#2054
Harvey,
Paul
Paul
#2055
Mark,
Not currently. I have never used a 900, but I have left space for it in my install. See below, where I connect via a Cortex Pro and CB210. The 900 will connect to the Cortex Pro (RX2 input) and then into the CB210.
I would assume that the 900 would connect into the REX, but I don't know if the REX has the ability to do Rx switching. You may need a CBxxx to handle that.
Paul
Paul
#2056
That appears to be a non-standard set up for a CB210 & Cortex Pro.
I run the main REX into Cortex Pro port B, and the backup Rx to port A. Cortex Pro ports 5 & 6 go in to the receiver ports, 1 & 2 in the CB. The 900 receiver goes in to the 3rd receiver port. The telemetry goes into the EXT ports of the CB.
#2057
Note I have not yet installed a 900, so have not fully proven the strategy, but that's my understanding of how it should work.
Paul
#2058
If you run the 900 directly into the CBxxx 3rd Rx port, you lose any gyro benefit at switch over to 900. The REX and connected R3/RSW provide primary and backup 2.4 RX's, and the Cortex Pro will provide switching to the 900 should it need to.
Paul
Paul
#2059
My Feedback: (53)
Paul
Paul
Personally the expander would only go in my CB’s….in fact if I need an expander I would go CB320 or 400…..I have both in different jet….
#2060
My Feedback: (10)
Harvey,
Paul
Paul
Thank you for your reply. I can set the R3/RSW Serial Link to EXBUS. I can't change the pin config like I can on REX receivers.
On the REX10A, E1 is set to EXBUS/Backup.
This works and servos run as long as I use the EXT port (4) on the R3/RSW. I can disable the primary REX10A and the secondary R3/RSW still drives the servos.
If I check 'Enable 900MHz Backup' then the primary and secondary receivers stop working and Device Explorer crosses them out. Is that normal? As soon as I uncheck 'Enable 900MHz Backup' the primary and secondary receivers work again.
I may have a bad REX3 900 receiver. When I try to bind it to my DS-24 nothing happens, no banner, no Receiver Bound announcement.
So using the EXT port on my secondary R3/RSW allows both REX10A and R3/RSW to work together (E1 on REX10A connected to EXT port 4 on R3/RSW). But I cannot add my REX3 900 for backup. Is it possible it's defective?
Harvey
#2061
Harvey,
i suggest you replace the secondary R3/RSW with the 900 Rx, and try running the combination in single Rx mode (not dual path), and then disable the 2.4 transmissions to check that it correctly switches over to the 900 Rx.
While I've never used a 900, I assume that it is very similar to an R3, so make sure that it is set up for EX Bus output into the REX.
I don't recall, but I suspect that the REX cannot handle multiple secondary receiver inputs and then perform the necessary switching. You would need a CBxxx to do that function. I guess you could daisy-chain to a second REX instead of the R3/RSW and then connect the 900 to the secondary REX. I've never tried that though.
Paul
Paul
#2062
My Feedback: (10)
Harvey,
Paul
Paul
#2063
My Feedback: (10)
Hi All. Thank you for all your help and suggestions. Per Esprit I need a REX3 900.bin file in the Devices folder on my DS-24 in order to bind (Pair) my REX3 900 receiver to the DS-24, which I updated to v5.06
My DS-24 does not have a REX3 900.bin file, only a REX3.bin and RSAT900.bin in the Devices folder. I checked the one previous backup I did in May and it wasn't there either.
Can I get the REX3 900.bin file from Jeti Studio so I can load it to the DS-24 with USB? If so, where can I find the REX3 900.bin file? If not, is there anywhere else I can get it?
Or, can someone PM me the REX3 900.bin file?
#2064
My Feedback: (53)
#2067
My Feedback: (10)
If your Tx has a REX3 900.bin file in the Devices folder could you copy it and email to me. I'll PM you my email address.
#2068
My Feedback: (53)
Yes, I have updated the DS-24 to 5.06 a 2nd time in case there was a hiccup during the 1st update. The REX3 900.bin file is still not in the Devices folder.
And I can say it work with the USA REX3 900 RX, I have them in all my jets (almost)
#2069
My Feedback: (10)
Hi All, problem solved.
I do not have a European DS-24.
There is no REX3 900.bin file for the REX3 900 receiver. It uses the RSAT900.bin file.
I went through everything with James to make sure I wasn't doing anything wrong with settings, connections and the binding process. He is replacing my REX3 900.
Thank you everyone for your suggestions. It's great that Jeti has a lifetime warranty.
Skunkwrks (08-17-2022)
#2070
My Feedback: (10)
Questions on Data Analyzer:
I would like to know what the Q graph represents. Is it similar to LQI? My understanding is that Q represents the percentage of frames that made it from Tx to Rx and back to Tx. If so, and if I see a dip to 95% on the graph does that mean that 5% of the frames were lost during that time? How many lost frames would that be? Or does Q represent something else?
I would also like to know what the A graphs represent (with 9 at top for antenna A1, A2, etc). Is it a form of RSSI? If not, is there a way to see RSSI in -dbm?
#2071
Any one using PwrBx Igygo Sat on Jeti? Does it connect direct to the RX?
I'm building a 2m Rebel and don't want to use a Cortex on it, as the Assist RX don't work well on jets I was thinking in using and I gyro Sat....
#2074
yes I know and I have 7 of them in my larger jets but didn’t want to throw a $ 300 gyro in this small jet….
i have try several times the jeti assist ones on 2mt jets with no luck… the only one that worked fine was on a carf joker kt85
#2075
My Feedback: (10)
I'm curious what issues people have had using Jeti Assist in jets. I have no problems, in fact I have used it both ways. The traditional knob first until plane oscillates then back off slightly and move percentages to a switch. But I really like the newer Assist update with the option to select the type of flying you plan to do and it sets the gyro rates for each control surface, similar to AR Smoothflite.
I also have a jet with a Pioneer and iGyroSAT. My Jeti 2.4 receivers plug into the Pioneer and my 900 plugs into my primary 2.4 receiver. The iGyroSAT plugs into the Pioneer. It works fine with same precision as Demon Cortex, but I have to use a knob at first to get max rate and repeat for ailerons, elevators and rudder. Then move all 3 rates to a single switch.
I like the new Assist much better as it is easier and saves time, plus it is very precise and allows you to tweak all the various gyro characteristics such as locked in feel, etc. In a jet you select jet and in my large Extra 300 I select precision aerobatics. No knob, no oscillation test, just locked in and fly on rails. In addition it makes for a cleaner install with less wires.
PS one of my posts states that Jeti has a lifetime warranty. I don't remember who told me that, but it's not true. Jeti has a 2 year warranty.
