Kingtech presents the all new T1 sports jet
#2553
Do you mean what position I set each channel, like HOLD vs. a preset position? Or do you mean how long for system to wait until executing Failsafe positions?
i wish Cortex and PB had something like the Jeti Assist Intelligent Failsafe feature.
#2554
My Feedback: (46)
I’m in interested in hearing how others setup failsafe on their jets as well. Specifically hold, or a set position and why? Aside from throttle to idle.... I usually just go with hold since i have no idea when and where a failsafe condition might happen. I can’t see how setting any surface to any set position is going to do any good.
#2555
My Feedback: (46)
So I went to install my steering servo into the nose gear mount (I’m using Electron) and to my surprise it doesn’t fit! It’s too wide for the mount which I didn’t even think would be an issue. I’m using a Savox 1267 (I think it is) because I happened to have it on hand. Does anyone have a HV Savox servo that does fit? I’d like to keep them all Savox. If not, anyone recommend a good HV MKS that fits?
#2557
My Feedback: (53)
I had to file the opening in mine a little as well....
For the failsafe......I program, gear up, flaps up, motor off.....and all surfaces to the trimmed neutral positions.....and then I would pray that it doesn’t hit anyone or anything.....
bodywerks (08-24-2020)
#2558
#2559
All,
I have an extra New In Box Advanced Radio Smooth Flight ARXL w/Gyro and Sequencing if anyone is interested. I know Pacific RC is out and I'd let it go if someone needs one. PM me if you're interested.
#2560
My Feedback: (53)
I go with setting Ailerons, Rudder, and Elevator to neutral, Flaps Up, Gear Up, Throttle OFF. I agree that it likely won't do any good no matter what you set it to, that's just what I do. Regarding the gear, I figure there is a slightly better chance the gear will survive if they are retracted. This is why I really like the Jeti Assist Intelligent Failsafe feature, sadly a similar feature is not available on Cortex or iGyro. Intelligent Failsafe, if activated, puts the aircraft in a gyro stabilized level decent until impact, which greatly improves the chances of your turbine and other gear surviving. As Dansy noted above, prayers are needed to avoid hitting someone or something. -Tom
If I would ever loose link (never did before 40+ years) I wouldn’t be concerned much about saving the plane....I can always cry after it’s safe deep into the ground....
#2561
I
Thanks for your perspective, it's good to understand all the different options and reasonings. I suppose there are an infinite number of ways to game this scenario, one thing is certain though, loosing control of a 35 lb turbine jet is a bad thing. Be care about saying "never did..." because I went 42 years before I lost my first (and only one so far) aircraft to a radio problem. -Tom
Actually the stabilize descent is not something I would use...it only extend the glide area....I rather get it in the ground closer to where I’m flying less chance to do any harm or damage...
#2562
My Feedback: (53)
I
just joking....I’m not superstitious.......
bodywerks (08-25-2020)
#2564
Thank you guys.
Yesterday I weighed T1, and adjusted the CG. I'll start at 255mm from the leading edge. Weight with UAT filling + about 1 cm of fuel is less than 14 kg - / 30.68 lb /. ***winter***
Dansy (08-26-2020)
#2565
Mine finally showed up exactly (to the day) 8 months after ordering. Dirk was fantastic through the process and y'all were right....it was worth the wait. Even after seeing pictures and understanding what 2.2 meters means, this jet was still bigger than I thought it was. The paint is beautiful with only a few minor blemishes which I'll be able to buff right out. Can't wait to get going on it. The purple is much more brilliant that it looks in the pictures as well.
smcharg (08-26-2020)
#2567
My Feedback: (64)
Looks great! You’ll like it even more when you fly it. Enjoy!!
#2569
Hi guys, as for the expo setting. You have set the expo only in stabilization mode /off/ or even when stabilization / normal on/. I was wondering if the expo setting in stabilization mode / normal on / could not reduce the stabilization efficiency. For example, Jeti recommends not using the expo on its Rx Assist, with stabilization turned on. ***winter***
#2571
Hi Daniel, I'm sorry, but I don't understand your answer. You have an expo in all modes, or just in a mode where you fly without a gyro /gyro off/..... ***winter***
winter1 (08-29-2020)
#2573
OK....
When you have a moment, please see how much expo rate you have on your radio, when using gyro.
In the afternoon I tested on the ground whether the size of the expo affects the operation of CortexPro. Whether I gave an expo of 0% or 100%, the gyro always had the same efficiency. I didn't measure it, I just checked it with a look. ***winter***
#2574
OK....
#2575
My Feedback: (64)
My experience is that with the gyro turned on, it feels as though you have more expo than you actually have. For maidens, I set up radio with more expo and gyro off. Once trimmed, I refly with gyro on. It will usually feel a little dead around mid stick. I then start to decrease expo settings until it again feels right to me
My maidens are usually 35-45% expo, gyro off. Once I turn gyro on, I am usually closer to 25% expo....but again it is a all a personal feel thing and varies from plane to plane and radio to radio
