Reload this Page >
Kingtech presents the all new T1 sports jet
Old 08-22-2016, 07:00 PM
  #326
flejter1
flejter1's Avatar
Originally Posted by dontop
Dirk, I'd like to see a turbine ready version. Building's not my thing. I'll let the pros and the guys who live up north who have 6 months a year of bad weather do it.
Don
Hi Don,
I'm sure there are many quality builders in your area we can set you up with to build you a T-1. Most of the hard work is done on the T-1, like all the control surfaces are hinged and double control horns are installed at the factory. To me that is the most time consuming task for assembling a jet. Let me know if you want us to put the word out.
Dirk
Old 08-22-2016, 07:05 PM
  #327
TonyBuilder
TonyBuilder's Avatar
Originally Posted by flejter1
Hi Don,
Dirk
TB
Old 08-23-2016, 07:08 AM
  #328
Digital Pilot
Digital Pilot's Avatar
More Photos
ID:	2178011   Click image for larger version
ID:	2178012   Click image for larger version
Old 08-23-2016, 07:21 AM
  #329
gunradd
My Feedback: (9)
gunradd's Avatar
Originally Posted by Digital Pilot
More Photos
Nice clean install!! Much better then my rush job lol.
On the fuel tank I would highly recommend securing it with something. I used a big zip tie around it. When full of fuel and doing some high G maneuvers I would not trust the Velcro.
Old 08-23-2016, 07:22 AM
  #330
gunradd
My Feedback: (9)
gunradd's Avatar
Also guys remember to tighten the wing clamp bolts before transportation or you will find they all fall out on the ride to the field.
Old 08-23-2016, 07:36 AM
  #331
Digital Pilot
Thank you.
I have a couple Velcro straps I will use around the tank and board.
Old 08-23-2016, 07:41 AM
  #332
Digital Pilot
I plan to Hysol nuts to the top side wing bolts so they can't work there way out. Iv had to do this in jets in the past and works well. If you ever need to remove them you still can.
Old 08-23-2016, 09:08 AM
  #333
TonyBuilder
My jet came today
TB
Old 08-23-2016, 09:51 AM
  #334
raron455
My Feedback: (38)
raron455's Avatar
[QUOTE=TonyBuilder;12250027]My jet came today
TB[/QUOTE
Congrats Tony,,
keep up the post like the other fellas who are building theirs,, I wanna know what I'm in for when Mine gets here..
Old 08-23-2016, 12:03 PM
  #335
sirrom
OK, going to pull the trigger on one of these very soon. Already started gathering materials for the build. Can someone post the dimensions of the equipment mounting board please. I can lay it out on my computer with all the items, I plan on laser cutting mine to make it look nice and clean.
Patrick
Old 08-23-2016, 03:37 PM
  #336
TonyBuilder
Ok so here is the un boxing.
the box is very sturdy.
My wing tub was loos in the box, but it did not do any damage
ID:	2178085   Click image for larger version
ID:	2178086   Click image for larger version
Old 08-23-2016, 03:43 PM
  #337
TonyBuilder
First thing I noticed was the wheel wells are diferent.
So it looks like they changed the bottom of the wing at the wheel wells. This eliminates the option of doing inner gear doors but this will be good for the sports guy that just wants to put the gear in and go. It does come with doors for the struts and the noes wheel, but not as nice... For me as I like doing gear doors. Now I can just forget them and move on
TB
ID:	2178088   Click image for larger version
ID:	2178089   Click image for larger version
Old 08-23-2016, 03:49 PM
  #338
TonyBuilder
I just did an inventory and visual inspection, wow the paint job and quality is amazing.
The craftsmanship is top notch!,
ID:	2178091   Click image for larger version
ID:	2178092   Click image for larger version
ID:	2178093   Click image for larger version
ID:	2178094   Click image for larger version
ID:	2178095   Click image for larger version
Old 08-23-2016, 03:52 PM
  #339
gunradd
My Feedback: (9)
gunradd's Avatar
So so it looks like they changed the bottom of the wing at the wheel wells. This eliminates the option of doing inner gear doors but this will be good for the sports guy that just wants to put the gear in and go. It does come with doors for the struts and the noes wheel, but not as nice... For me as I like doing gear doors. Now I can just forget them and move on
TB
tony that is allot better then the prototypes. The well is so big on mine I had to trim it some to get the airlines into the fuselage on the bvm quick connections. Wish I had those wells
Old 08-23-2016, 03:56 PM
  #340
TonyBuilder
Really impressed with the finish, only one area got damaged during shipping but it's the black so should be east to fix.
The hinges look good and tight, I really like the overall engineered design of this jet.
The wing is beautiful
TB
ID:	2178097   Click image for larger version
ID:	2178098   Click image for larger version
ID:	2178099   Click image for larger version
ID:	2178100   Click image for larger version
ID:	2178101   Click image for larger version
ID:	2178102   Click image for larger version
Old 08-23-2016, 04:07 PM
  #341
TonyBuilder
The fuselage is huge!
I got lucky, in my scrap pile I have an old CF wing tube from an Aeroworks Super cub that is exactly the same size, it is about 3/4 shorter so not sure that will mater.
I love the noes cone
Nicely engineered!
The canopy is a bit ode as it just slides forward to unlock, might throw a few magnets in.
Equipment tray!
Turbine hatch is well done.
TB
ID:	2178104   Click image for larger version
ID:	2178105   Click image for larger version
ID:	2178106   Click image for larger version
ID:	2178107   Click image for larger version
ID:	2178108   Click image for larger version
ID:	2178109   Click image for larger version
ID:	2178110   Click image for larger version
ID:	2178112   Click image for larger version
Old 08-23-2016, 04:20 PM
  #342
TonyBuilder
Some more details from the un boxing.
Rear section.
Man this bird is big!
Let the build begin
TB
ID:	2178114   Click image for larger version
ID:	2178115   Click image for larger version
ID:	2178116   Click image for larger version
ID:	2178117   Click image for larger version
ID:	2178118   Click image for larger version
ID:	2178119   Click image for larger version
ID:	2178120   Click image for larger version
ID:	2178122   Click image for larger version
ID:	2178123   Click image for larger version
ID:	2178124   Click image for larger version
ID:	2178125   Click image for larger version
ID:	2178126   Click image for larger version
Old 08-23-2016, 05:36 PM
  #343
lfierro1
Patrick
The equipment tray is 12 1/4 inches long by 6 1/2 at the front and 7 inches at the rear
Old 08-23-2016, 11:30 PM
  #344
i3dm
My Feedback: (51)
Tony, the back of the canopy already has powerful magents built inside.
Old 08-24-2016, 03:44 AM
  #345
TonyBuilder
Default Noes gear
I got the noes gear ready to install.
I went with dule push rods to spread the load from a single pivot point,
robart bolted clevis and 2/56 X 4/40 ball links on titanium rods with alternating threads for fine tuning.
I pinned the servo plate with a 2/56 button head screw.
Linkage.
Next I will prep the main gear.
TB
ID:	2178147   Click image for larger version
ID:	2178148   Click image for larger version
ID:	2178149   Click image for larger version
ID:	2178150   Click image for larger version
Old 08-24-2016, 03:47 AM
  #346
Quandry
Is your pipe OK Tony? looks a little dinted :O
Old 08-24-2016, 04:18 AM
  #347
gunradd
My Feedback: (9)
gunradd's Avatar
Pipe is fine they just are not pretty lol. They are plenty strong enough.
Old 08-24-2016, 04:43 AM
  #348
Johnny9390
My Feedback: (34)
Got a text from DHL saying my box had arrived!!!! Was all excited then realized it was just the gear! Lol spoke with Dirk and he told me mine should be here anyway. Question for you guys that received it. Unfortunately was told that EMS does not provide tracking number but rather they bring over to US and have USPS handle the delivery but looks like the box is too big to fit in a USPS truck. Did you guys receive a notice from USPS and have to pick up box yourself at their location??
Old 08-24-2016, 10:58 AM
  #349
smiller
Mine showed up yesterday at my place of work, no notice. it was recieved by our shipping dept. Box is not that big, should fit on most trucks. It was very well boxed as others have shown, Mine had a fist size hole in the side of the box, but luckily it was at a void in the box where no parts were!!
Scott
Old 08-24-2016, 12:04 PM
  #350
Johnny9390
My Feedback: (34)
Mine arrived today and was waiting for me outside my house!! Thanks Barry, Dirk, Chris , and Mr Ir Kim!
