Reload this Page >
Kingtech presents the all new T1 sports jet
Old 08-29-2016, 06:23 AM
  #376
TonyBuilder
TonyBuilder's Avatar
Originally Posted by raron455
Hey Tony, Turbine pipes are very sharp on the edges, so it is common for them to stop just inside the tailcone, about 1/4-1/2 inch or so,
as far as spacing, KT states 20-30mm I myself would probably go with 3/4 -7/8 inch for that 120,, from the end of the turbine exhaust cone to the beginning of the pipe, NOT THE BELLMOUTH of the pipe, but the pipe itself,, I put a quick Reference on Digitals Pic (Hope you don't mind) to help understand, the cone needs to be in side the bellmouth.
Keep on chugging at the jet bubba, It looks fantastic.
Thanks Ronnie!
TB
Old 08-29-2016, 07:07 AM
  #377
Digital Pilot
Digital Pilot's Avatar
Good Day.
Regarding the nose gear door, I like the two peace setup as i can get the cylinder to the front of the side hinged door so it does not open in flight. The forward door is hinged from the front and opens with the strut like most other sport jets.
Old 08-29-2016, 07:33 AM
  #378
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
i wish I couldve heard that screeching eel!!!! What in. The hell!!
Old 08-29-2016, 07:52 AM
  #379
raron455
My Feedback: (38)
raron455's Avatar
HAA,,, I'm surprised you didn't hear it wherever you were, it was just as loud on the taxi way as it was on the backleg of the pattern...
for those that don't Know, earlier this year I maidened my 1/6 lone star gunfighter F16 (ended up losing a few months later lord rest its soul) at Mississippi. I had the turbine set wrong, I had it set about 1 inch from the edge of the bellmouth instead of the pipe. It made such a loud screech, I bet it could be heard 2 miles away, Horrible. After talking to Dirk,,(ONCE AGAIN EXCELLENT CUSTOMER SUPPORT FROM KINGTECH) He walked through my setup on the phone and told me where I screwed up. I moved the turbine back, set the 1 inch from the end of the pipe, more Power, and most important, the SCREAMING Banshee was gone.
Point of story, when you have a pipe with a large bellmouth, set your measurement from the end of the pipe, NOT the bellmouth. I know I am speaking from experience,,I was lucky I didn't burn my jet up...
Old 08-29-2016, 05:29 PM
  #380
TonyBuilder
That's a great story, nothing like lessons learned...by fire!
TB
Old 08-30-2016, 11:07 AM
  #381
Johnny9390
My Feedback: (34)
For those of you on FB I have created a group with a build page dedicated to the T-One for anyone who wants to follow and provide inputs. Always love constructive criticism
https://www.facebook.com/groups/865077050197302/
Old 08-30-2016, 02:18 PM
  #382
Johnny9390
My Feedback: (34)
I noticed gunradd your main gear is mounted with brake line facing in, I had mine facing out like i3dm had on serial 1. Is there a right or wrong way to mount them?
Old 08-30-2016, 03:28 PM
  #383
gunradd
My Feedback: (9)
gunradd's Avatar
I guess they can go either way. Its up to you.
Old 08-30-2016, 04:04 PM
  #384
TonyBuilder
I did mine with the srtut offset out as I did not want it to slam into the top of the wing when the gear goes up.
TB
Old 08-30-2016, 04:23 PM
  #385
TonyBuilder
So one thing I noticed with the frame. Normally on my builds I do my own servo setup, tray and mounting so I can control how the linkage is done. I always setup the throws so that hight rate is the full travel of the control surface and the full travel of the servo. On my ailerons with the ball link out side the hatch enough to not hit the hatch and on the furthest home on the horn for the aileron I only get about 50% of the servo travel before it binds so I have to set the servo to only move 25% each way on high rates and about 15% on low rates.
Correct me if I'm wrong but you always want full travel of the servo at the highest rate. In order to achieve this you need to move the linkage attachment point in closer to the servo. To do that you would have to cut the slot in the servo hatch for the ball link. My standard setup for scale or sports planes is to use a 1" or less horn on the servo and then make the horn on the control surface the appropriate length to achieve full travel on the servo, this is around 20 degrees to start with, on elevator I like 25 degrees minimum.
So my first thoughts are the horns on the control surfaces need to be longer. One remedy I will try when I do the elevator is to use a heavy duty clevis like I used on the noes gear steering. This will allow the servo arm to be sorter and the linkage will go into the wing. This is not my preferred linkage methods but really the only option to get full travel from the servo. If this works I will do that on the flaps and the ailerons as I had to dial down the servos to about 30% to get the throws that are needed.
Are any of you guys running into this when setting up your control surfases?
TB
Old 08-30-2016, 04:33 PM
  #386
gunradd
My Feedback: (9)
gunradd's Avatar
TB
Tony I didn't like the stock set up also so I dremmeld out a bigger slot so I could use a smaller servo horn and the linkage fits into the wing. I think I only did this for flaps. Will go look tonight.
Old 08-30-2016, 05:14 PM
  #387
Johnny9390
My Feedback: (34)
I did have to come down on the travel so the servo arm didn't hit the hatch.
Same for the Flap
Old 08-30-2016, 05:15 PM
  #388
Johnny9390
My Feedback: (34)
Old 08-30-2016, 05:27 PM
  #389
gunradd
My Feedback: (9)
gunradd's Avatar
Just looked at mine. I used clevises on the servo side and made the slots a little bigger.
Old 08-30-2016, 05:29 PM
  #390
TonyBuilder
Seams like the best solution!
TB
Old 08-30-2016, 05:43 PM
  #391
Johnny9390
My Feedback: (34)
If you use a clevis doesn't it make it harder for the pushrod to line up with the horn on the moving surface? There's not much give to make that angle to align it with the horn no? Post a pic gunradd
Old 08-30-2016, 05:53 PM
  #392
Johnny9390
My Feedback: (34)
Saw your pic gunradd. Your idea works but with the new kits the horns are doubled on the moveable surface. So unless you move the servo itself to a more center position in alignment with the horn, it makes it hard for the pushrod to make that angle to fit right on the horn on the flap or aileron. At least in my plane the way the servo sits and the arm I'm using I have to use the ball links to make a straight shot from the servo arm to the horn
Old 08-30-2016, 05:54 PM
  #393
Johnny9390
My Feedback: (34)
With the clevis on the servo arm there is no wiggle room left or right
Old 08-30-2016, 08:47 PM
  #394
Digital Pilot
Wing Doors Done!
ID:	2179006   Click image for larger version
ID:	2179007   Click image for larger version
ID:	2179008   Click image for larger version
ID:	2179009   Click image for larger version
Old 08-31-2016, 03:11 AM
  #395
TonyBuilder
Originally Posted by Digital Pilot
Wing Doors Done!
I am so jealous that you got the good wings with the good wheel wells. Did you get all the other improvements? I'm wondering why they changed the wing so drastically
TB
Old 08-31-2016, 05:07 AM
  #396
smiller
Hey guys, what control throws are we looking at for the T-one.
Scott
Old 08-31-2016, 05:45 AM
  #397
Digital Pilot
T.B
I have all the improvements, I personally like the round wheel wells with the half doors
Old 08-31-2016, 05:52 AM
  #398
gunradd
My Feedback: (9)
gunradd's Avatar
Dont think it needs wiggle room. I havent seen the new ones in person but I dont think a double horn would change my set up at all.
Old 08-31-2016, 06:36 AM
  #399
smiller
The double horn is offset from the servo arm slot, so it is setup for a rod end on the servo arm.
Scott
Old 08-31-2016, 06:41 AM
  #400
gunradd
My Feedback: (9)
gunradd's Avatar
Scott
Scott I gave Dirk all the control throws at Kentucky jets. I will see if he can post them. For me the ailerons didn't need to much throw but I have plenty of elevator and all the rudder it could take. I fly high rates all the time also.
