Reload this Page >
Kingtech presents the all new T1 sports jet
Old 08-31-2016, 07:21 AM
  #401
smiller
Originally Posted by gunradd
Scott I gave Dirk all the control throws at Kentucky jets. I will see if he can post them. For me the ailerons didn't need to much throw but I have plenty of elevator and all the rudder it could take. I fly high rates all the time also.
Thanks gunradd !
Scott
Old 08-31-2016, 08:08 AM
  #402
JetBravo
In the specs it list the model power requirements for a K80 - K160 size turbine. How would this fly on a P100? I have one sitting around that needs a home. Wondering if it would be a good fit.
Old 08-31-2016, 08:18 AM
  #403
gunradd
My Feedback: (9)
gunradd's Avatar
It should fly well. It will suffer in the verticals but fly pretty good otherwise. Airplane flies super light with a very light wing loading.
Old 08-31-2016, 04:11 PM
  #404
TonyBuilder
TonyBuilder's Avatar
Originally Posted by Johnny9390
Saw your pic gunradd. Your idea works but with the new kits the horns are doubled on the moveable surface. So unless you move the servo itself to a more center position in alignment with the horn, it makes it hard for the pushrod to make that angle to fit right on the horn on the flap or aileron. At least in my plane the way the servo sits and the arm I'm using I have to use the ball links to make a straight shot from the servo arm to the horn
There is a simple solution for this. I will try it on the elevator, if that works I will do it on all the surfaces.
TB
Old 08-31-2016, 06:46 PM
  #405
Johnny9390
My Feedback: (34)
Yeah try it out. I am also not using the stock horn. Some would go into thresd and pull right out. Didnt like thst so i got a pack of heavy duty dubro 4-40 and made my own rods with carbon sleeve. Yes overkill but looks nice when done. Will go back and heatshrink sfter all is set and look even cooler
TB
Old 08-31-2016, 09:33 PM
  #406
flejter1
flejter1's Avatar
The factory finished the 1st Honda Scheme!!
I liked it so much, I had to order 1 for myself.
Dirk
ID:	2179174   Click image for larger version
ID:	2179175   Click image for larger version
ID:	2179176   Click image for larger version
ID:	2179177   Click image for larger version
Old 09-01-2016, 03:42 AM
  #407
raron455
My Feedback: (38)
raron455's Avatar
Yessir that is one good lookin bird, Cant wait till ny purple one comes in...
Old 09-01-2016, 03:43 AM
  #408
TonyBuilder
Ronnie, do you have to wait 6-10 weeks...you might have yours flying before mine!
TB
Old 09-01-2016, 03:55 AM
  #409
raron455
My Feedback: (38)
raron455's Avatar
Tony, Im not sure when Ill get mine, I ordered mine on 8/18, and the estimated delivery was 8-9 weeks. W Dirk let everyone know on the 25th, any New orders from that point on may take 10-12 weeks. Im hopin mine is the shorter,, of all the personal attributes, Patience is my weakest point 4 sure,
Old 09-01-2016, 04:22 AM
  #410
TonyBuilder
This is what I am working on to correct the servo setup and linkages. This is with a 1" servo arm, HD clevis, and 4-40 ball link. I took a ball and put it between the two horns to lock it in and put the linkage on the inner outside. This give a almost perfect alignment. Some trimming of the slot will need to be done but not much. This might just work.
TB
ID:	2179192   Click image for larger version
ID:	2179193   Click image for larger version
Old 09-01-2016, 08:54 AM
  #411
Johnny9390
My Feedback: (34)
So that's for the stab. So you're not using the double horn on the flying surface. Just one side. I would just as a washer so the ball link doesn't come off in flight.
johnny
TB
Old 09-01-2016, 09:12 AM
  #412
causeitflies
causeitflies's Avatar
Hmm... So I guess I'll be moving all my horns or servos when I get mine. That's the downside of these ARFs. I spend more time redoing things the way I want them than if they hadn't done it for me.
It's been about seven weeks since I ordered mine at Kentucky.
Old 09-01-2016, 09:16 AM
  #413
TonyBuilder
johnny
Still using the double horn but going to the side, they are tied together with the threw bolt that will keep it from flexing, and yes a washer is always used on the ball link.
TB
Old 09-01-2016, 09:18 AM
  #414
TonyBuilder
builders make the most critical builders of ART frames...but they also come up with good solutions too.
TB
Old 09-01-2016, 09:53 AM
  #415
Digital Pilot
Digital Pilot's Avatar
Hmm, I'm using all the hardware and factory horn locations on mine. I haven't seen any issues that concern me. Am i missing something?
Old 09-01-2016, 01:39 PM
  #416
Johnny9390
My Feedback: (34)
Ive been using most ofnthe hardware, just not the factpry horns. Thought they looked too big and funky looking. And had issue with one of them not right size. And alsonwill be using a metal hinge for the doors instead of the plastic one.. these are just preferences as i had other items already laying around but the kit does come with everything you need. No complaints here.
Old 09-01-2016, 03:28 PM
  #417
Digital Pilot
The only hardware i did not use where the plastic hinges. I had aluminum ones already as well..
I feel that the factory hardware is good. For the price of this kit im pleased with the hardware and quality of this jet.
Would buy another in a heartbeat!
Old 09-01-2016, 04:16 PM
  #418
TonyBuilder
nothing wrong with the hardware and factory horn. But if you want 100% throw at high rats on your servo the factory setup won't let you do that. This setup is typical for 3D were you have 1-1/2" or 2" servo arms with big throws. But for a jet or a warbird you don't need or want all that throw. Most sport or scale modles will have a different setup that allows the surface to achieve maximum movement for that particular model (usually around 20-25 degrees of deflection each way).
There is nothing wrong with the factory setup and many are flying with it...be it with only using 20-30% of the servo throw and resolution. As a builder this is not the ideal setup or use of the current technology we have with our servos and radios. With a little engineering all this can be achieved in the factory as it is surface/ servo setup 101!
For those of you that build this jet in a week from finding it at your door this is fine, but for the builders we want it the way it should be, and the way we know it should be. I have no problemb making it work and find it a challenge sometimes to work these issues out. My comments are not ment to criticize but to offer positive feedback and options for others. The generic setup used on this jet works for most frames but it's not the best for this one. With a little tweaking they can get it right to where even the most inexperienced builder can achieve the proper results that most seasoned builders get. In my opinion the control horns are still to short for this type of setup (servo arm and ball link outside the wing)
I get that this is a bargain and making changes raises the cost but we are talking simple changes, even doing the flap setup like Topflite uses would work here and not add to production cost.
A factory internal servo mount for the ailerons would also be easy to do and look really cool and even better...work!
I think this is a great model and will be very popular in the future as long as the cost stays down, otherwise they will be compeating with CARF and SM and they have the setup I'm talking about already.
TB
Old 09-02-2016, 03:33 AM
  #419
TonyBuilder
My thermo sleeve arrived so now I can do the tail section.
This stuff is good for constaint protection of 500 degrees and intermittent of 2000 degrees
should do the trick.
TB
ID:	2179301   Click image for larger version
ID:	2179302   Click image for larger version
Old 09-02-2016, 04:19 AM
  #420
gunradd
My Feedback: (9)
gunradd's Avatar
Perfect! The outside wall of the pipe will never get that hot so you will be good. The servo wires during the build was the one thing that scared me for new people to turbines building this plane. That is the one spot you can get into trouble on by not paying attention to the wires being close to the pipe.
TB
Old 09-02-2016, 04:31 AM
  #421
gunradd
My Feedback: (9)
gunradd's Avatar
Per our request the factory has now made a larger fuel tank along with a combined smoke tank. This tank will not come stock and will need to be orderd seperate from the T1. Not sure how soon they will be available but not to much longer. Also dont know price yet.
3.7L fuel tank plus 1L smoke tank.
Old 09-02-2016, 04:55 AM
  #422
WimB
WimB's Avatar
Nice, me want!!!
I'll be placing my order any day now, orange version, Grumania pipe, and the big tank.... comes just in time!!!
Wim
Old 09-02-2016, 05:45 AM
  #423
bcovish
My Feedback: (8)
bcovish's Avatar
Is that going to be big enough to get three servo wires through it. I'm assuming 2 elevator and 1 rudder
Old 09-02-2016, 07:45 AM
  #424
Digital Pilot
So tomorrow should be the day!
I will list my CG, throws and flight report later tomorrow evening. Hope to have some good photos as well...
Old 09-02-2016, 08:48 AM
  #425
flejter1
flejter1's Avatar
Pictures, Pictures, Pictures!!!!
Please send pictures of your finished T-1 to us, static or flying. I could use some good shots of "ALL" the color schemes to post on the website. Your participation is greatly appreciated!!
Good Flying,
Dirk
[email protected]
