Reload this Page >
Kingtech presents the all new T1 sports jet
Old 09-10-2016, 06:18 PM
  #526
bjnginge
Originally Posted by gunradd
Tested the v2 pipe today with a K210 and smoke all is good.
So a k170 would work if turned down a bit? Would the residual thrust be too much?
i know you have flown it with a 170, just want to know how it performed with one.
Old 09-10-2016, 06:24 PM
  #527
smiller
There are more compact 4.40 rod ends available out there than the ones supplied. I used some i had from a QQ Yak 54 and with SWB 1.25 arms with the rod end set at the 1 inch position, I can get the recommended throws without the rod ends going into the slots. I did have to widen the slots a little because the arms rubbed on one side. Using rod ends{ball links} the push rods line up fine.
Scott
Old 09-11-2016, 05:11 AM
  #528
Johnny9390
My Feedback: (34)
I'm using Savox SA-1256TG that has 277oz of torque all the way around except for the flaps which I'm using Savox SA1230SG which has about 400oz of torque. Let's see how she goes. The Savox are noisy little servos.
and I'm using the standard ball link on both ends no clevises
Old 09-11-2016, 05:14 AM
  #529
Johnny9390
My Feedback: (34)
Btw 1 inch hanger 9 aluminum arms all the way around except for rudder which has a 1.5 arm
Old 09-11-2016, 06:56 AM
  #530
Digital Pilot
Digital Pilot's Avatar
I did the same using Savox 1230's. and 1256 on steering. They are a little noisy but they are great servos. Been using them for many years now.
Old 09-11-2016, 10:28 AM
  #531
TonyBuilder
TonyBuilder's Avatar
Got some progress on the noes wheel gear door.
I am using robart aluminum door hinges.
Threw bolted them with 2/56 button head screws.
I also glued a ply skin to firm up the door, it would not take the twist out as I hoped.
Not sure if I will cut the door even though it won't close 100% at the front.
Air cylinder has more strok then needed so I set it at max open and when it closes its still pulling.
The way I set my hinges is with the door closed I lay the hinges in to where I want them then tack them in with CA. I can always break them loos if I need to adjust. Once I like them I drill holes then bolt them.
The block for the cylinder is tacked in with epoxy and I will hit it with aero poxy later, might even run a couple screws threw.
I still need to adjust the door by shimming the hing as once it closes it locks in and binds.
The he door is removable.
TB
ID:	2180648   Click image for larger version
ID:	2180649   Click image for larger version
ID:	2180650   Click image for larger version
ID:	2180651   Click image for larger version
ID:	2180652   Click image for larger version
ID:	2180653   Click image for larger version
Old 09-11-2016, 10:49 AM
  #532
Digital Pilot
Looks great Tony.
Just an FYI, I setup my door cylinder the same way and got a lot of pull flex in the fuselage where your wood mount is. I recommend putting some hard clear fuel tubing on the shaft to limit the pull from the cylinder when the door is closed.
It work very well..
Old 09-11-2016, 10:52 AM
  #533
Digital Pilot
Are you going to run a button valve for the nose door?
Old 09-11-2016, 10:53 AM
  #534
TonyBuilder
Thanks DP, I will look at that.
TB
Old 09-11-2016, 10:54 AM
  #535
TonyBuilder
I have a UP3 valve I had for my scraped Mister build I will be using, still might do inner gear doors on the mains. I can slow the door down with that valve.
What is a button valve?
TB
Old 09-11-2016, 10:55 AM
  #536
Digital Pilot
Mine creased alot but i also had started with a smaller block than yours. Just dont want to se anyone crack there fuse.
UP3 is one of the best valves!
Old 09-11-2016, 10:57 AM
  #537
TonyBuilder
I might install a CF former in as weight up front will be needed so I will beef it up. BTW did you have to add weight to balance?
TB
Old 09-11-2016, 11:02 AM
  #538
TonyBuilder
The skin is supper soft with the foam(y) skin on this jet
the screws just suck in till they hit something solid!
TB
Old 09-11-2016, 11:04 AM
  #539
Digital Pilot
All my packs where in the nose along with a Dubro lead strip. However my UAT was in the side pocket just past the intake on left side
Old 09-11-2016, 11:07 AM
  #540
TonyBuilder
I'm trying to get everything as far forward as I can that has weight to it, three batts up front and led if I need it. Will have to see if Tams pipe is heavier as I would think it will be being beefier.
TB
Old 09-11-2016, 11:08 AM
  #541
Digital Pilot
This is the reason its light weight. Great composite design and workmanship.
Thats why I just Hysol min on..
Old 09-11-2016, 11:09 AM
  #542
Digital Pilot
Tam pipe will be a little heavier in sure..
  #543
TonyBuilder
How does hysol bond to foam as aposed to reg epoxy?
TB
Old 09-11-2016, 11:10 AM
  #544
rcpete347
My Feedback: (251)
rcpete347's Avatar
Did the balance this morning, with the new pipe, 6oz. heavier than stock, needed all batteries plus one more in the nose, at 240 CG., which is in front off the wing tube.
Rcpete
ID:	2180658   Click image for larger version
Old 09-11-2016, 11:12 AM
  #545
Digital Pilot
Hysol bonds well to pretty much any good prepped surface but whatever substrate (Foam) its bonded to will have its structural limits of course.
Old 09-11-2016, 11:13 AM
  #546
TonyBuilder
Did your pipe come with the mounting tabs or did you add them?
TB
  #547
Digital Pilot
That clamp is going to look funny in flight...lol
What pipe is that?
Old 09-11-2016, 11:14 AM
  #548
rcpete347
My Feedback: (251)
rcpete347's Avatar
Anyone want the stock pipe for $50, good to a 120 size Kingtech.
Rcpete
Old 09-11-2016, 11:15 AM
  #549
TonyBuilder
Rcpete
Your kidding right
TB
Old 09-11-2016, 11:16 AM
  #550
TonyBuilder
What pipe is that?
Counter balance!
TB
