Reload this Page >
Kingtech presents the all new T1 sports jet
Old 09-11-2016, 11:39 AM
  #551
gunradd
My Feedback: (9)
gunradd's Avatar
Originally Posted by bjnginge
So a k170 would work if turned down a bit? Would the residual thrust be too much?
i know you have flown it with a 170, just want to know how it performed with one.
170 isn't to bad. Crow and allot of flap helps.
With the 210 it will almost fly at idle. Its a challenge to get it down with it.
Old 09-11-2016, 02:04 PM
  #552
Digital Pilot
Digital Pilot's Avatar
rcpete
Will you bring your T-1 to best in the west?
Old 09-11-2016, 02:50 PM
  #553
TonyBuilder
TonyBuilder's Avatar
Door is all done short of painting the inside black, I will do that when I do the mains.
Started to fit the internal equipment, air tanks are going under the fuel tank. One large for the gear and two small for the breaks.
TB
ID:	2180688   Click image for larger version
ID:	2180689   Click image for larger version
Old 09-11-2016, 03:27 PM
  #554
Desertlakesflying
My Feedback: (28)
Anyone bringing one of these to Madera in two weeks?
Old 09-11-2016, 04:55 PM
  #555
rcpete347
My Feedback: (251)
rcpete347's Avatar
Originally Posted by Digital Pilot
rcpete
Yes, will bring to BITW
Rcpete
Old 09-11-2016, 04:59 PM
  #556
rcpete347
My Feedback: (251)
rcpete347's Avatar
Built a battery box, clamp till dry, only takes a second to mount the batteries.
Rcpete
Old 09-11-2016, 05:16 PM
  #557
Elvis Olmeda
Originally Posted by TonyBuilder
Got some progress on the noes wheel gear door.
I am using robart aluminum door hinges.
Threw bolted them with 2/56 button head screws.
I also glued a ply skin to firm up the door, it would not take the twist out as I hoped.
Not sure if I will cut the door even though it won't close 100% at the front.
Air cylinder has more strok then needed so I set it at max open and when it closes its still pulling.
The way I set my hinges is with the door closed I lay the hinges in to where I want them then tack them in with CA. I can always break them loos if I need to adjust. Once I like them I drill holes then bolt them.
The block for the cylinder is tacked in with epoxy and I will hit it with aero poxy later, might even run a couple screws threw.
I still need to adjust the door by shimming the hing as once it closes it locks in and binds.
The he door is removable.
TB
Which cylinder are you using for the door?
Old 09-11-2016, 05:18 PM
  #558
Elvis Olmeda
Originally Posted by rcpete347
Anyone want the stock pipe for $50, good to a 120 size Kingtech.
Rcpete
Version 1 or 2? Mine came with version 1. Text me or call me 615-810-2312
Old 09-12-2016, 05:01 AM
  #559
TonyBuilder
Dreamworks 2" I think as it has been laying around for a while.
TB
Old 09-12-2016, 05:11 AM
  #560
TonyBuilder
Rcpete
Man that's fast
mine takes 5 seconds...I take it your using Lipos!
TB
Old 09-12-2016, 08:53 AM
  #561
rcpete347
My Feedback: (251)
rcpete347's Avatar
Man that's fast
TB
I am using lipos and a PB Mercury .
Rcpete
Old 09-12-2016, 01:07 PM
  #562
DMichael
TB
Looks like one of the first two on this list:
http://www.dreamworksrc.com/catalog/...words=cylinder
Old 09-12-2016, 02:39 PM
  #563
Desertlakesflying
My Feedback: (28)
Ordering mine (Navy Jolly Roger) regular tank, just cant justify that much for a split tank, soon VERY EXCITED. Even though there is a wait. That will give me time to get the rest of my internals. Too bad the Boomerang buyer flaked
Old 09-12-2016, 02:44 PM
  #564
Digital Pilot
Its worth the wait...
Old 09-12-2016, 05:39 PM
  #565
TonyBuilder
The time will fly by!
TB
Old 09-12-2016, 07:37 PM
  #566
marquisvns
marquisvns's Avatar
Rcpete
I ended up with batteries all around nose gear and under the canopy. The inside of nose cone is all empty.
Barry
Old 09-13-2016, 04:04 AM
  #567
TonyBuilder
Has anyone pre balance the fuse by the wing tube? In the past builds I can do a pre balance as I setup the interior eqiupment and then do final balance with the wing and CG stand! My gues is if it is tail heavy on the tube its tail heavy. It gives you a decent mesure of what you need to move around as you install it.
TB
ID:	2180916   Click image for larger version
Old 09-13-2016, 05:43 AM
  #568
rcpete347
My Feedback: (251)
rcpete347's Avatar
Barry
Hi Barry, are you balancing right on the front of the wing tube
Rcpete
Old 09-13-2016, 05:45 AM
  #569
TonyBuilder
hi barry, are you balancing right on the front of the wing tube
rcpete
[attach=config]2180942[/attach] [attach=config]2180943[/attach]
tb
ID:	2180942   Click image for larger version
Old 09-13-2016, 01:25 PM
  #570
raron455
My Feedback: (38)
raron455's Avatar
Guys, If you want to order the newer larger tank while your plane is still on order, it really is very easy, just call Dirk, he can invoice you for the tank. I called and ordered it last night, quick and easy. I have read some folks crying about the price, get over it, they are not raking us on the price. It is a larger Custom fit built Kevlar tank with an secondary tank on top of it, for smoke or even more fuel if you choose. The tank comes with good hardware as well, screw in fittings and bungs, with Elbows, the hardware alone will cost over 60$ at any place you can find it. I can hardly wait to get mine, I seen Clays Ferrari scheme jet in person at our jet rally last week, it is beautiful Inside and Out. There is not a jet on the market that can compare to this one even close to the price. Thats my .02
Old 09-13-2016, 04:01 PM
  #571
TonyBuilder
I totally agree, I would get one but I can't wait that long. You guys flying with 140 and 160 will want the extra fule!
TB
Old 09-13-2016, 04:03 PM
  #572
lfierro1
got my tams pipe today, it's well made but smaller in diameter so some fitting is in order. I don't have my engine yet so lets see how those of you that do are mounting them.
Old 09-13-2016, 04:10 PM
  #573
TonyBuilder
I should have mine any day now!
TB
Old 09-13-2016, 04:37 PM
  #574
Digital Pilot
Make carbon fiber tabs to mount the pipe. Tams pipes have short tabs to limit flexing. This is normal..
Old 09-13-2016, 05:46 PM
  #575
lfierro1
My plan at the moment is to make a new ring for the rear of the pipe similar to the one for the original pipe, and mounting it on the original mount. that will hold the rear, but with no engine yet i can't do much at the front of the pipe where the tabs are going to mount.
