Bavarian Demon Cortex PRO is here!!
#501
Y-connector off a port used for a low power device like the ECU throttle input.
#502
My Feedback: (28)
After an expended period with my Cortex Pro on the workbench due to its past issues I am about to get it out and install it in my new BVM F-16. But I am still not 100% confident in its performance. I have re-read this entire thread today, will recheck all my firmware updates and try it again. I will however only run RX 1 through the CP. I will run RX2 directly to the CB200. Can someone give me some good vibes that this thing is now working as it is supposed to. Thanks!
#503
Tom, I have six CP's installed and constantly flown. They have worked flawlessly since day one. Have never had any issue.
The feeling of CP is second to none ... effective and transparent. (I had other brands installed prior to the CP, so I can feel the difference ).
I have them connected as you are planning to (just for peace of mind).
Jack
#504
Arnaud
#506
I adjust the max gain value so that the aileron moves about 1/16" to 1/8" up and down when I lift the wing. That should be a good starting point. If it's too much, reduce it via the slider and reprogram the value. I like to fly with the slider at the full up position ... no guessing.
I program a 10 points higher gain with gear down.
If I have reduced the gain during flight, a transmitter voice reminds me to go to full gain for landing when I lower the gear (or flaps).
To make the slider able to lower the gain to zero (gyro off), program a "negative" value identical to the programed gain, in the gyro "tuning" window (left slider is P6 btw).
I can upload a pic of the screen if necessary.
Jack
#508
My Feedback: (22)
I currently have a Cortex Pro installed in my Viper Jet. I'm using one of the Cortex channels to stabilize the nose steering. When I retract the gear the steering servo is disabled thru the retract switch in my Jeti DS 16 but the Cortex still stabilizes the servo. Is there any way to disable stabilization on one channel while the gear is retracted?
I didn't realize at first it was still stabilized when retracted and the servo jammed and ruined the servo. Luckily I have sufficiently large flight packs so the stalled servo didn't take the plane down!
#509
David
#510
My Feedback: (22)
YES... Copy BANK 1 to BANK 2 so both banks are "Gyro" NOT HEAD HOLD (you can do that on the PC software). Then in bank number two (2) set the gain for steering to zero (0)....Then set your Gyro control on Transmitter to "Separate modes" flight mode depended. set your cruise mode to access Bank two (2 - Green light)) where steering gain is zero. Leave Take off mode and Landing mode to access Bank 1(amber light)
David
David
#511
New Firmware and Software available from Bavarian Demon, the main thing it gives is dual serial inputs when driving servos DIRECTLY from the Cortex Pro.. the Dual serial throughput is unchanged.
V 2.0 Update-Details (Release 25.04.2018):
Supporting the DualRX feature. See manual and software info for details.
This software will automatically update any device (AXON and CORTEXpro) on firmware < V2.0 to V2.0 when connected. Any previous configuration will stay unchanged.
- Text field for device name, for easy identification via bluetooth / app.
- „DualRX“ option (serial input only): via button in the software/app, a second and redundant receiver can now also be added to port A, when PWM ouput (servos directly connected to the unit) is selected. So far, this was only possible using serial I/O in combination with a servo distribution box. The corresponding software and app packages featuring the switch function are to follow until mid of May. Manual V1.6 available for download.
- Programming via bluetooth and app integrated. The B module, available separate, to follow until mid of May.
- Channel-clipping (channel signal limits) ehanced on all channels (stabilized and non-stabilized) from 110% to 125%.
#513
My Feedback: (28)
I've got a strange one. Installed my CP in a BVM F-16. Setup was fine all the lights blinked as advertised but when I did the control setting I didnt get a double bump on any control surface. I got the single blink,the double blind and the multiple blink. The flight controls work as they should but there is NO stabilization. Move the nose nothing...move the wings nothing. Suggestions?
#515
If the sequence doesn't go this way start over.
#518
My Feedback: (28)
I do have a a red light...... when the gyro switch in my "off" position. Yellow in the next two 20% & 60%. As I said, all the setup worked just as advertised except the "bump" and servos responding to airplane movement in the dampening mode. Speaking with Danny I went back and looked at my servo travel. It was less (50-55%) than I thought it was (85%). I will increase the travel when I get a chance to work on it again and try again. I figured it was some operator induced error and may be right.
#520
Some advice, please. I am planning to install a CP in an Ultra Flash. I intend to use the 2 x serial input options with one Jeti Rex 10 and a Rex 3 plugged into the CP. I will drive servos for the stabilized channels and throttle directly out of the CP. The other functions (flaps, gear, steering, brakes) taken from the Rex 10. That way, I figure that if I lost the primary Rx I would still have flight control and worst case could do a gear up, flaps up landing. Of course, if the CP locks up, then I am truly going to have a bad day! I don't really want to go down the CB200 route as I figure that this introduces additional complexity and uncertainty.
What I would like some help with is understanding what the current feeling is about the reliability of the CP. Since the 1.5 update came out I have not seen any reports of lockout . Is this because nobody is relying entirely on the CP or has the problem been resolved. I'm just trying to assess the level of risk here and feel like I could do with some help. Thanks.
#521
I have been using CP on firmware 1.5 in several of my jets and they are very solid with no issues. They simple configure and work great. For your purpose you need to upgrade to firmware 2.0. (If not already) so you can plug servos directly into outputs 1-6
David
#522
Thanks David. Yes, I have 2.0 installed and it's all working as expected on the bench. Good to hear that you have had no issues - that's the way it should be !
#523
