Jet building services
My Feedback: (71)
Clean installs.
I cringe when I see festo's on THE most negative suction side. Its obvious that jet central uses it on their set ups and that many people do that right now with success but that little piece of tubing is subject to the most vacuum in the jet.
Great paint too! How much do you charge for paint like that?
A couple more years when I'm settled I'm going to start adding paint to my building options for folks. It will really helps in the re-engineering to be able to cut and modify without restriction.
