Reload this Page >
*** CG Wizard *** by Digitech
Old 04-06-2017, 04:05 AM
digitech
My Feedback: (10)
digitech's Avatar
Default *** CG Wizard *** by Digitech
Like to share with you our latest addition the CG wizard.
Designed by Daniël Maiorano & Sandor Kruise
Build in the EU.
CG wizard is a Helpfull tool that lets you find the CG of your aircraft in 5 easy steps.
we looked carefull to our competition and we seen that most of them around are difficult to use and set up.
and sometimes needs a 50 pages manual to use it.
also we thought to implement all tools you WILL need , and not to buy external stuff.
all is connected thru USB cables.
The CG wizard is easy to setup and use.
5 steps needed only!
1.Set CG mark on aircraft
2.Measure aft Sensor to front sensor
3.Point the build in laser to measure the CG
4.Give distance in app
5.add or lose weight , you can see on app when CG is reached!
Thats it!!! no usage of plumbs , tape , giving to much data.
extremely easy to use!
Complete CG set contains the following :
3 x sensors Laser cut of 6mm CASTED acryl
1 x Central box with BlueTooth and Build in LaserHelp (C)
3 x USB cables to connect sensors to Central Box
1 x Charge Lead
1 x Powerbank 2900 Mah to power the device
Works both on IOS and Android Apps are for FREE!
Max aircraft weight 40 KG
Price is less then a decent Digital high end servo!
Manual here : https://www.dropbox.com/s/niyjwse55q...anual.pdf?dl=0
any questions ? shoot!
Br Sandor Kruise
ID:	2208630   Click image for larger version
ID:	2208631   Click image for larger version
ID:	2208632   Click image for larger version
ID:	2208633   Click image for larger version
ID:	2208634   Click image for larger version
Name:	WhatsApp Image 2017-03-29 at 20.41.42.jpeg
ID:	2208635   Click image for larger version
Name:	WhatsApp Image 2017-04-01 at 08.31.57.jpeg
ID:	2208636   Click image for larger version
Name:	WhatsApp Image 2017-04-03 at 22.45.35.jpeg
Name:	WhatsApp Image 2017-04-03 at 22.45.37.jpeg
digitech is offline
Old 04-06-2017, 04:16 AM
roydefiant
Pricing in euros?
roydefiant is offline
Old 04-06-2017, 05:15 AM
digitech
My Feedback: (10)
digitech's Avatar
179,- incl 21% taxes
If you live outside the eu its 148,- euros
I think it is a fair price
digitech is offline
Old 04-06-2017, 06:08 AM
Ricardo Forte
Hi Digitech,
Max 5 kg per sensor?
total weight 15kg or 40kg ?
Ricardo
Ricardo Forte is offline
Old 04-06-2017, 06:25 AM
Custmachr
Originally Posted by Ricardo Forte
Hi Digitech,
Ricardo
I believe the pictures show 5 kg on nose wheel and 25 kg on the main wheel scales
Custmachr is offline
Old 04-06-2017, 06:36 AM
Ricardo Forte
truth
Old 04-06-2017, 07:48 AM
sirrom
Really like the idea of the built in laser for marking the CG and making it that much simpler to measure.
Patrick
sirrom is offline
Old 04-06-2017, 07:55 AM
digitech
My Feedback: (10)
digitech's Avatar
Yes 25kg on mains and 5kg for front.
digitech is offline
Old 04-06-2017, 07:59 AM
digitech
My Feedback: (10)
digitech's Avatar
That is exactly what we thought this way you will have less chance of a error.
Also we will later inplement a share function.
You can search a database to get the correct settings for your model.
It will again leave out one more step!
digitech is offline
Old 04-06-2017, 08:14 AM
MJD
MJD's Avatar
CG Wizard? Shouldn't that be in the control line section?
Ha ha. All kidding aside, great system, bedankt.
MJD is offline
Old 04-06-2017, 11:48 AM
do335a
Don't understand how this works and the pix don't help.
How about a video demo?
By the way, what are those red pix? What are they demonstrating? And the piece of music wire next to a tape measure and a sensor? What's that for?
do335a is offline
Old 04-06-2017, 12:06 PM
digitech
My Feedback: (10)
digitech's Avatar
Video Demo will come soon...
digitech is offline
Old 04-06-2017, 12:27 PM
MJD
MJD's Avatar
Looks like the model size version of the wireless digital scale setup to do weight and balance on full size light aircraft. Makes perfect sense.
MJD is offline
Old 04-06-2017, 01:36 PM
invertmast
My Feedback: (23)
invertmast's Avatar
Can you get it with 25kg sensors in all 3 positions?
5kg on the nose isnt nearly enough for some of my projects coming up and currently being worked on.
invertmast is offline
Old 04-06-2017, 06:03 PM
Bob_B
Bob_B's Avatar
How do I order a unit?
Bob_B is offline
Old 04-06-2017, 06:35 PM
David Searles
My Feedback: (49)
+1
David Searles is offline
Old 04-06-2017, 11:59 PM
digitech
My Feedback: (10)
digitech's Avatar
www.digitech.nl
pre order delivery in may
digitech is offline
Old 04-07-2017, 01:16 AM
invertmast
My Feedback: (23)
invertmast's Avatar
Originally Posted by digitech
www.digitech.nl
Old 04-07-2017, 01:34 AM
digitech
My Feedback: (10)
digitech's Avatar
yes this is possible , however you need to mention it before ordering it.
there is no price difference
keep in mind! the 5kg sensor is very sensible and precise.
with the 25kg sensor in from it will be less precise.
we calculated the is a 1-4 times less precision when this sensor is used on the front
what is your average nose weight? maybe we can source a different sensor 10kg?
as for people with small aircrafts like a f3a we can make also a lighter edition with smaller sensors, all possible
digitech is offline
Old 04-07-2017, 02:38 AM
Bob_B
Bob_B's Avatar
So if my largest model was 20 pounds or less do I want the smaller sensor in all three positions?
Bob_B is offline
Old 04-07-2017, 04:23 AM
digitech
My Feedback: (10)
digitech's Avatar
No that is fine as it is
I just test weighted a mini avanti 4kg and is spot on
digitech is offline
Old 04-07-2017, 08:29 AM
kelly vallee
Do you know they will be available for shipping? Kelly
kelly vallee is offline
Old 04-07-2017, 08:55 AM
invertmast
My Feedback: (23)
invertmast's Avatar
I have two aircraft that the mains are roughly 38-44 pounds each and the nose' are between 26 and 48 pounds each. The heaviest of the two models is 124.6 pounds
Old 04-07-2017, 09:51 AM
causeitflies
causeitflies's Avatar
Looks good and the price is right. If I didn't already own the competition I would order one. This makes it easy to CG large planes.
causeitflies is offline
Old 04-10-2017, 11:59 AM
digitech
My Feedback: (10)
digitech's Avatar
"De Luxe "Version packed in a Waterproof case like Pelicase
Name:	WhatsApp Image 2017-04-07 at 11.19.11.jpeg
ID:	2209183   Click image for larger version
Name:	WhatsApp Image 2017-04-07 at 11.19.31.jpeg
digitech is offline
