Reload this Page >
** Digitech Central Telemetric Unit for Jeti **
Old 10-20-2019, 03:55 PM
  #326
wgdenge
Thank you very much for the reply. I am using a Mercury and KingTech 210G2
So, I understand about the REX instead of just the R3. If I get a REX Rx, can I still get PowerBox telemetry?
Kind of on the fence about just moving to a CB200 or 210, and Cortex. Bit I already have the PowerBox, and have always like PB products.
V/r
Wayne
Old 10-20-2019, 04:05 PM
  #327
clavin
clavin's Avatar
Yes.. You just run a servo wire from the telemetry output of the Mercury to a telemetry input of the R3 or a telemetry port you configure on the REX receiver you decide to go with..
Im a powerbox fan.. The primary thing is the power distribution followed a close second by speed compensated gyro gains.....
Chris
Old 11-04-2019, 08:18 PM
  #328
DepecheMode101
Where is firmware .96? it keep asking for .96 or better... help please.
Thank you
Old 11-05-2019, 03:50 AM
  #329
Dansy
My Feedback: (53)
Dansy's Avatar
What keep asking for 96 ? I don’t get that warning...
Old 11-05-2019, 04:32 AM
  #330
DepecheMode101
When I open device explorer it ash for .96 or better.
What is the most current firmware?
Old 11-05-2019, 05:17 AM
  #331
Dansy
My Feedback: (53)
Dansy's Avatar
I will look later, but I think the most I have which I think is the latest is 92
Old 11-05-2019, 05:20 AM
  #332
digitech
My Feedback: (10)
digitech's Avatar
Guys hang on just writing a post ;-)
Old 11-05-2019, 05:37 AM
  #333
digitech
My Feedback: (10)
digitech's Avatar
Release 0.96 Auto Throttle is released!
Principles of operation
The CTU device has an auto-throttle function built in (usage is optional nd at own risk!).
The auto-throttle function’s job is to try and keep the plane flying at a specific IAS.
Basically, the auto-throttle function is a “black box” inside the CTU device and is fed with the current IAS and the IAS it has been set to achieve (setpoint).
The output from this box is a throttle setting.
This setting depends on the error (difference) between the current IAS and the setpoint.
The larger this difference is, the higher the change in throttle setting will be.
To help soften the reaction to the throttle output 3 parameters are also input to the auto-throttle “black box”.
These parameters allow the algorithm to select an optimum throttle output.
The algorithm in use is called a “PID controller”.
The PID controller looks at the difference in the IAS and control the throttle output according to this difference using the 3 parameters (kP, kI and kD).
The parameters are quite sensitive to changes.
The default values in the “CTU Configuration Tool” seems to work well with most JetCat engines, being not too aggressive nor too soft.
Download the Firmware AND bin file here : https://www.digitech-aerosports.nl/product/783681/ctu
look in the list
there are 2 files one is the BIN file for your TX , if you have the latest definitions you do NOT need to update your TX your tx wont report anything .
if you have a old verson (your tx will report on the CTU that there is a newer version).
copy the BIN file in your TX under the map Devices.
upgrade your CTU to 0.96
Please read the Manual for the AT function Carefully.
use at OWN risk.
we tested this in lots of flights without any issues.
please remember for the AT function to work you MUST have a Digitech IAS with special firmware.
if you own a Digitech IAS allready 480kmh version only you can upgrade the Fimrware easy yourself.
otherwise order the IAS for AT at your local dealer.
LUA script
Dave WW2BIRDS will later tell you more about this extreme cool item for your Jeti.
Old 11-05-2019, 05:45 AM
  #334
Dansy
My Feedback: (53)
Dansy's Avatar
Is this update just for the AT or here also change on the CTU (engine side) as well?
So do I need to update all mine don't intend/want to use the auto throttle.....at this time.
Old 11-05-2019, 05:49 AM
  #335
Carsten Groen
Carsten Groen's Avatar
Simply put: "no"
This version is primarily "only" the autothrottle
Old 11-05-2019, 05:50 AM
  #336
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by Carsten Groen
Simply put: "no"
Thank you..
Old 11-05-2019, 05:56 AM
  #337
digitech
My Feedback: (10)
digitech's Avatar
you WILL get a Warning all the time in the explorer menu that you need to upgrade.
Old 11-12-2019, 04:20 AM
  #338
digitech
My Feedback: (10)
digitech's Avatar
the Autothrottle LUA script has been released.
Old 11-12-2019, 05:52 AM
  #339
DepecheMode101
Do I need Digitech airspeed kit or will Jeti one work?
Old 11-12-2019, 05:56 AM
  #340
Carsten Groen
You need the Digitech SB-IAS with a software version for this (autothrottle). This one feeds the info to one of the ports on the CTU
Old 11-12-2019, 05:43 PM
  #341
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Carston,
I want to use one of my CTUs in a Freewing F-22 EDF foamy turbine conversion. It will be useful nose weight.
Can you tell me if the CTU is powered from the ECU or from the receiver. I have to use a 5 volt BEC to power the receiver, servos, and retracts, but need to power the Kingtech ECU with at least 6v. The CTU connects between the ECU and receiver, so I want to know where the power for the CTU is drawn from. Using Jeti REX12A, DS-24, and K-45G3 ECU.
This would be a good platform to play with Dave's auto throttle also.
Gary
Old 11-12-2019, 06:03 PM
  #342
DepecheMode101
Are there 2 different Air speed options? One for auto throttle one without?
Old 11-12-2019, 07:30 PM
  #343
DepecheMode101
https://www.digitech-aerosports.nl/p...for-ctu-480kmh
Where to purchase in US?
Old 11-12-2019, 11:01 PM
  #344
Carsten Groen
Originally Posted by Viper1GJ
Carston,
Gary
Gary,
The CTU is powered from the receiver. The ECU connection is "data only"
Regards,
CArsten
Old 11-12-2019, 11:06 PM
  #345
Carsten Groen
Well, kind of
The SB-IAS can be used as a standalone airspeed sensor, in that case you connect it to EX Bus "as normal". This will give you airspeed and distance travelled on the transmitter.
You can also get the SB-IAS with a special firmware where it will deliver its data as a simple stream of airspeed info, this the plugs into one of the extra ports on the CTU. You then enable the autothrottle function on the CTU. Together with the AT functionality, you will also get the airpseed down on the transmitter (the airspeed is basically sent from the SB-IAS (with the special software in) via the CTU to the transmitter.
Hope this clears it up
And yes, you can update the firmware of the SB-IAS yourself, I have made all my devices so that you just can use the Jeti USB-to-Serial cable to do this along with a small program I made for this (named "Progammer"). The CTU updates via a SD card, or using USB cable).
More info etc at Digitech's homepage
Old 11-12-2019, 11:07 PM
  #346
Carsten Groen
There is a list of distributors on Digitech's page:
https://www.digitech-aerosports.nl/dealers-distributors
Old 11-12-2019, 11:21 PM
  #347
digitech
My Feedback: (10)
digitech's Avatar
https://www.aeropanda.com/collection...s-speed-sensor
here it is , ask them to allready flash it with the CTU-IAS firmware.
Old 11-12-2019, 11:26 PM
  #348
digitech
My Feedback: (10)
digitech's Avatar
YAU!
Yet another update.
we just updated the LUA script
1. changed translation so that each language has its own file (e.g. nl.jsn). Trans.jsn now is just a list of languages. It only reads and loads the one it needs.
2. Replaced kph with kmh everywhere
3. added knots to speed units selection on the menu.
Please be adviced :
Best is first:
1. uninstall CTUautoT from your applications.
2. delete the digitech folder and the CTUautoT.jsn from your TX folder : apps.
3. copy again the latest files back to this folder (apps).
4. reinstall the LUA in applications.
Old 11-13-2019, 08:41 PM
  #349
ravill
ravill's Avatar
Do we need to buy two of these for twins?
Old 11-13-2019, 08:56 PM
  #350
Carsten Groen
Ravill,
yes! Each CTU can be configured either as a "Master" or "Slave 1" to "Slave 3". The only difference between a CTU that is "Master" or "Slave" is that a master device sends down altitude and G force. The Master also takes care of the Autothrottle function if that is enabled.
All the slaves (up to 3) sends down only engine info and fuel info for the connected turbine.
So yes, you need one CTU for each engine (up to 4) in your plane.
