T-One Models Micro T1
#103
My Feedback: (7)
That’s hilarious! Maybe I should read my emails a little closer. Well, you’ll be the first one of the public to get one so I’d appreciate it if you’d let me know when yours shows up. Looks like it’s going to be a great plane. I did go ahead and order the K45 too and I appreciate your advice on this Jet.
#105
#106
For those who were curious where Micro T1 #3 went.. See pictures below.
First I would like to thank Dirk (Pacific RC jet) and Danny (Aeropanda) for this beautiful little jet. We maiden the jet yesterday and it was a perfect. A few clicks up up elevator and one click of right aileron and this jet was flying nicely. Dirk has a few videos of take off and landing. On the maiden day I had 9 flights and enjoyed every single one. At the time of assembly (was not pnp) there was no manual. We now know the exact CG and the amounts of travel for each surface. From the pictures you can see the equipment installed, but here is the list:
Xicoy X45 with telemetry
MKS 93HV servos throughout. Nose door servo was installed at factory and was an HV servo
Jeti REX12 and R900 (backup) with Jeti remote turn on switch
Cortex Pro
Digitech 100ml UAT
JP gears and brake
Jeti Mspeed 450
The entire system runs on a single 2800Mah. Each flight consumes about 385Mah. The Micro T1 with 100ml UAT full weights at 9.9lbs.
According to Dirk, more have been delivered and others are on the way. The factory can not keep up with the orders.
David
#108
Cortex Pro
Digitech 100ml UAT
JP gears and brake
Jeti Mspeed 450
David
Cortex Pro
Digitech 100ml UAT
JP gears and brake
Jeti Mspeed 450
David
This one seems “underpowered” by your usual standards
How do you like the JP gear / brakes compared to the Electrons?
How was your fuel consumption?
Best of luck with the new plane !
#110
With 100% throttle most of the flight I was able to get a good 5 min on a 1.0L tank with 25% left...
This jet flies so nice it’s relaxing... it’s definitely a keeper
#112
Cortex Pro
Digitech 100ml UAT
JP gears and brake
Jeti Mspeed 450
David
Cortex Pro
Digitech 100ml UAT
JP gears and brake
Jeti Mspeed 450
David
Are the 93hv's drop in?
maybe the Jet Factory can chime in....
Also you put th 45 in the middle?
why so?
#113
#115
I believe the K30, K45G3 and X45 are of approximately the same weight and size... Maybe due to loss of thrust through the pipe, the factory recommends the K30 to be installed through the back end.. CG is at 175mm from LE
David
#117
There is no back hatch (like most EDF) and unlike other T1’s the engine is accessed from under where the wing mounts. It’s a lot easier to install and access the engine where we have it.
David
Cheers
#118
