Powerbox Core radio and set up thread.
#626
I learned in IT, no matter how much you trust data or a device, back it up.
Any time i create a new model, especially something complicated, I export it a memory stick and put a copy on my laptop. Same with my DX20 for that matter. Like a fire extinguisher, better to have it and leave it gather dust than to need it and not have it.
#628
I know this is happening with other radios, a friends Jeti dumped his BVM F-16 file. Another friend is on his third iX20, all software related.
These radios should be reliable first, cutting edge technology second.
But yeah good advice.
#629
My Feedback: (99)
#630
However it's easier than you're making it.
Plug in a USB stick
Go to the model change screen, select the model you want and hit EXPORT (note that you don't have to load the model to export it, just highlight the model you want and hit EXPORT)
Save it somewhere because if you use the same USB stick to do a CORE update it will format it.
#634
I took a moment to save my other models today and yeah, a moment is about how long it took. I spent more time formatting the drive. Hopefully I learned enough that reprogramming the Mephisto will go easier this time.
The response on the Powerbox Support Forum and from Powerbox America is basically that there is a known problem with the radio losing model files during transfer. The problem is not fixed yet. But apparently it is a different part of the radio than when flying so if your model loads you are safe to fly, and if it does lose a file it is safe to reload the model from your back up USB drive.
#635
My Feedback: (99)
#636
You know, I have been flying RC since 1975 (Heathkit/Andrews H Ray/Enya 19) a ton of radios, and this has never happened to me. Let's just say it is a "modern" thing. We seem to be losing control of our tech. I only just retired from flying (Boeings for the last 26 years) this month and honestly, it was a little bit like this at work, the whole, "what is it doing now" question regarding flight computers and auto everything. So I have a bit of an attitude that it shouldn't be necessary to back everything up and prepare for the worst. But I'm being unrealistic.
I think I can do a better job this time around at using the radio to its potential and being retired time is not a problem. I reported my experience to help others to do the right thing and be prepared. Both you Sheldon, and a local Powerbox rep who is my flying buddy, and I, have all backed up our models today in case this glitch happens to us so I've done my part.
I still love my new radio but the manufacturer and distributors should really be sending out these messages, not me!
clavin (09-26-2020)
#643
I am having problems with the configuration of the Core throttle trim and Jetcentral SE and SP turbines.
I'm not sure how I set the Throttle trim to on and off the turbine.
Could someone please upload a picture of the throttle trim setting?
thanks in advance
thanks in advance
#647
We from CB Elektronics are proud to introduced the first fully integrated 24Bit IAS speed sensor for the CORE telemetry. This sensor technique is so advanced in performance terms like low noise and resolution.
CB P2B DIAS-440 digital IAS Speed Sensor compatible with all CORE PowerBox Systems telemetry products
Firmware Version 1.0
Use and Features:
CB P2B DIAS-440 Speed Sensor Specification
Input voltage range: 4,6-10Volt
IAS speed meas range: 12-440Km/h
Speed calculation error: +- 4Km/h
Meas-System: Static and dynamic
Optical signalisation: Yes CORE Bus activity
Connection: At the P2B CORE receiver connector
PowerBox CORE P2Bus: Yes supported
Dimensions: B x L x T in mm 36 x 46 x 13,5
Weight: P2B DIAS-440 Sensor without Pitot and tubbing 18gr.
Delivery: Pitot, Silicone tubbing aprox. 50cm and sensor electroncis, manual (complete kit)
*All Trademarks in relation to CORE based products belong to PowerBox Systems GmbH.
For quote please be so kind and use our contact form.
If you have further questions regarding IAS speed measurement don`t hesitate to contact us.
https://www.cb-elektronics.com…as-440-digital-24bit.html
https://www.cb-elektronics.com/contact.html
https://www.cb-elektronics.com/index.html
Best regards
Dirk CB Elektronics
Use and Features:
- Easy initial operation ( assemble pitostatic tube, plug in, switch on and read IAS meas result) No PC is necessary! Plug and Play!
- Unique "One-tube- system" for easy installation. If you prefer you can build your own scale pitot tube.
- Measurement range from 12- 440Km/h
- CB P2B DIAS-440 speed sensor design based on our thousand times proofen range of IAS speed sensor family
- New 24Bit digital pressure sensor, low sensor noise
- Speed display in kmh (kilometer/hour), mph (miles/hour), m/s (meters/second) or kts (knots)
- Top-Speed display via the CORE TX telemetry display
- Supports ultra short CORE voice announcement, selectable via the P2B DIAS CORE TX sensor setup menu
- Supported ICAO pressure speed curve
- Simulation mode for easy speech setup at the CORE TX
- Compatible with all CORE telemetry receiver (P2B)
- 40Mhz RISC CPU (fast converting of test results)
- Automatic nullification (sensor calibration)
- Small, light, also fits into small models
- English printed manual
- Dynamic and static pressure interpretation for speed measurement ( comparison to real airplanes)
Best regards
Dirk CB Elektronics
IAS and GPS (Powerbox GPS 11) speeds very close differing only by wind values.
Seems to be very accurate and quite a lot of fun to see max speeds on the Core after landing !
Very nice device!
( but don't connect the pitot with silicone tubing, use solid coloured Festo tube ! )
Core on 2.20 working perfectly.
