Rebel Hot by Comp Arf
#229
Not too concerned about flight time, either, as I rarely fly more than 4-5 minute flights. Fuel consumption specs for this engine are all over the map, but are around 160-180ml/min at 90% throttle, so even 'mostly' high throttle flying should be no issue.
#231
Thrust is not the issue, it’s wing loading. Different designs, different wing sections. Lighter is always better even more so with smaller airframes.
Anyway, I’m sure it will be fine.
#234
Here is a pirotti rebel with a Swiwin sw80b in it. He also has a lot more equipment in his than mine, like cortex gyro and bigger batteries. I am trying to get a weight from him.
It does come in a little hot, but that could be him getting used to it. Only a half dozen flights so far, but it looks like it scoots!
#238
Nice and light. I didn't realize the Xicoy x45 was so light! Probably literally half the installed weight of my CRX 85B. Seems like if a guy was going to go with a 45 in this jet, the X45 is definitely the way to go, or at least a G3 kingtech. The G2 45 weighs almost as much as my 85!
Send pics of your install...
#250
The back of the tank is exactly on the CG point. Ive not seen too many jets with the tank over the CG. I usually CG jets with an amount of fuel in the tank that I expect to have still in it when I land. I usually land with around 1/3 of a tank in my other jets. This one, being so over-powered, I expect to land with a little under 1/4 tank, so I will CG it with a quarter tank.
