Reload this Page >
Swiwin Turbines
Swiwin Turbines
Old 02-14-2021, 07:42 PM
  #126
CRX Turbines
Our manual seems to get around. I need to change the default settings that are listed. These were straight from Swiwin and are just starting points. We update the manual all the time. Here is the location of the manual. I also have a 5.5" X 8.5" formatted version that we release with our engines if anyone would like a copy.
swiwin_manual_02262020.pdf
Sw-jets and hobby king both have older versions posted.
As a note, we service motors 8 days week from 8 am to 10pm, if anyone has any questions call us or write.
CRXturbines.com
swiwnusa.com
716.946.7493
As for testing engines I think most people selling engines know to test them. We have a full lab and shop and every engine is tested extensively.
Andy
Originally Posted by Agrav8ed
^^^^^What he said^^^^. You will most likely have to increase your ACC a bit to get the throttle response that you like. The manual from CRX was just revised last year so it should be accurate and I would follow it. I know, because I called Andy with some questions for a project while he was working on it.
Tone
Old 02-14-2021, 07:43 PM
  #127
CRX Turbines
There are some idiosyncrasies about this especially Jeti. I do have the Vspeak unit and it works very well.
Andy
Originally Posted by rangerpaul
Andy - Thanks for providing clarification. I will add my throttle to PPM cable back. It is interesting though that it seems to work with our without the cable for Futaba. Thanks again!
Old 02-14-2021, 07:51 PM
  #128
Skunkwrks
Skunkwrks's Avatar
Andy
Andy I have the Xicoy Telemetry 6 for my JetsMunt to display on my Jeti TX. My buddy has the vspeak on his Jeti and he has to toggle to Jetibox to display it.
Old 02-14-2021, 07:53 PM
  #129
CRX Turbines
This is/was a production by Warped Perception. We sold the 300 engine to them and something did not seem to work as planned. We are working with them and had planned on a retest but with the new video from CM, I am not sure this is necessary. We'll see in the next few weeks. The one thing to note with the WP video is that for the RPM reached by the 300 on diesel, the output is spot on with the thrust curve. See below.
Andy
Originally Posted by camss69
I’ve seen that one, I think he needed to redo learn RC between fuels. Only the first fuel got to 100% rpm.
Old 02-14-2021, 07:55 PM
  #130
CRX Turbines
I'm still getting to know it ... It took a while and the help of Doug Ives and James from Esprit to figure it out. I will be adding an update to our manual. Any input is greatly appreciated.
Andy
Old 02-14-2021, 08:08 PM
  #131
CRX Turbines
Hi Paul,
I am playing some catchup here... our manual yes. Call us anytime 8am - 10pm. If you have not figured this out yet, send me some pics of your setup screens then call. These parameters were taken straight from Swiwin.
[email protected]
716.946.7493
I am getting started and have a Swiwin 60B. I have found many manuals online but they vary with information. The one I am using is one I got from the CRX site. But, comparing the actual ECU parameters between the CRX Manual and the actual entries from the unit they too do not agree. I have listed below the differences. Can someone take a look and tell me what the correct parameters are for the Swiwin 60B? Thanks!!
ECU Parameters - Brushless Starter Serial Number SW60B-1139
ECU Ver 2.00.92 GSU Ver 1.02.24
RCX Manual Actual ECU
Pump Voltage 1.1 to 1.3 0.8
Glow Plug 6.2 6.0
Max RPM 160000 150000
Min RPM 40000 35000
Restart Glow Plug 6.6 6.0
Pump Limit 7.5 10.0
Idle Pump State 5.0 8.0
Eject Voltage 4.0 3.5
Cooling RPM 6000 5000
Old 02-14-2021, 08:23 PM
  #132
Skunkwrks
Skunkwrks's Avatar
Andy
Harry Curzon video does explain it .
Old 02-14-2021, 11:05 PM
  #133
Halcyon66
They are in final stages of the 80kg turbine test phase and it should be coming out soon
Regards,
Old 02-17-2021, 09:23 AM
  #134
rangerpaul
In most of the videos I have seen, it looks like stainless steel safety wire is being used to secure some of the fuel line connections. I assume this technique is the same as being used in the full scale aircraft industry. Is it necessary to safety wire all tubing connections or only those without barbs? Also, what diameter stainless steel wire is to be used? Thanks!!
Old 02-17-2021, 09:35 AM
  #135
patf
patf's Avatar
I use this, really I'll safety wire everything, dont want air bubbles sucked in, or spray fuel anywhere
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 02-17-2021, 10:58 AM
  #136
Skunkwrks
Skunkwrks's Avatar
I have a roll of .025 stainless lock wire from my aircraft day. I personal like a larger diameter so it doesn't pinch into the hose.
Lockwire all tubing onto lines and filters to prevent any air from entering the system and causing a flame out.
Lock wire is used to prevent bolts and nut from completely coming apart when they get loose from vibration.
Blue UN anodized fitting are commonly used in aircraft.
Old 02-17-2021, 12:22 PM
  #137
AEROSHELDON
My Feedback: (99)
AEROSHELDON's Avatar
I asked on FB but I know not everyone is there--does anyone know if we will see a 350N size?
Old 02-17-2021, 12:38 PM
  #138
Halcyon66
https://www.sw-jet.com/sw-400b.html
Already available.
Regards,
Old 02-17-2021, 01:09 PM
  #139
CRX Turbines
I am pretty sure I answered you directly on this on FB. I suggested to turn a 400 down if the dimensions and weight are within the bounds of what you need. I have not heard of a 350 coming up but I can ask.
Andy
Old 02-17-2021, 02:06 PM
  #140
AEROSHELDON
My Feedback: (99)
Thanks Andy
Old 02-19-2021, 03:30 PM
  #141
rangerpaul
The manuals for both my Futaba and HobbyEagle gyros state the are to be used for electric models only. What is the best gyro to be used for our turbine models??
Old 02-20-2021, 04:43 AM
  #142
BarracudaHockey
BarracudaHockey's Avatar
PowerBox iGyro, Demon Cortex are probably the best and most popular
Old 02-20-2021, 06:21 AM
  #143
rangerpaul
Thanks! If you disregard price, is one better than the other?
Old 02-21-2021, 01:31 PM
  #144
rangerpaul
My fire extinguisher finally arrived so I was able to run my SW60B for the first time today. Everything was perfect. No flames, smooth quick start, throttle and telemetry working just fine. Many thanks to everybody here, CRX, Nova-Jet and Bad Boyz RC for all of the help!!! I appreciate it!!
Old 02-21-2021, 02:59 PM
  #145
RC_MAN
Is there a turbine between the 220 and 300 on the horizon?
Old 02-21-2021, 03:07 PM
  #146
AEROSHELDON
My Feedback: (99)
They announced a 240
Old 02-21-2021, 03:24 PM
  #147
F900
I'm ordering a 240 this week. Its the same size can they use as the 220, but here in the mile high club every extra lb of thrust helps lol
Old 02-21-2021, 04:12 PM
  #148
RC_MAN
Are they doing this with more RPM or is it a larger compressor? I hope they come up with a better fuel pump with less connections.
Old 02-21-2021, 04:24 PM
  #149
arizcowboy
My Feedback: (14)
theres only 2 connections on the fuel pump. one from uat and other to turbine
Old 02-21-2021, 04:25 PM
  #150
arizcowboy
My Feedback: (14)
on all the swiwin fuel pumps
