Top RC Odesey Heads up
My Feedback: (21)
Don't know if anyone else is run in to this or not on the top RC Odyssey. My second flight on mine, I took off, retracted the gear, and went to neutral the flaps. When I neutral the flaps the plane started banking hard right and pulling up on me. I got the plane trimmed out after I figured out what was going on. And finish the flight. I thought I lost a servo on the flap a linkage on a aileron. This was not the case. After landing I found out what had happened. The section of wing just in front of the flap on the top has a very thin layup of fiberglass. If you push down on this fiberglass and bring your flaps from half to neutral they can hang up on this thin area. This is what happened to me on the left wing during the flight. The air pressure over the wing was enough to push this area down while the flap was in its half flat position. You can actually see a chunk of the area missing on the left wing. I did fly two more flights on the plane and on the third flight the right flap did the same thing. But the server was able to overthrow the bind and finish breaking out the chunk of fiberglass. See the pictures. I plan on putting a fillet of fiberglass and epoxy underneath the thin layer of glass to stiffen the area up.
https://photos.app.goo.gl/NCs3qUL6mzfR66JV9
Check for de-lamination of the live hinge area. The force of the flap under load can cause it to “rise” and catch the wiper (gap seal) like that. I could be that it’s just too thin and/or too far from the drag spar. Several solutions to beef up that area. Easy to add a balsa sub rib every few inches
snir2001 (04-29-2022)
No, you are not the first. Top RC is crap, and this is why they try to hide as much as possible on their Fb page where they moderate and control the content. You’re officially now a “troll” in their eyes (their words in another thread, I kid you not) for having told the truth about their horrible quality.
My Feedback: (51)
This is actually a very common issue with composite wings in general.
i have had the same happen on several manufacturers.
it usually occurs when something was pushing against the thin skin in that area, such as wing covers etc.
its good that you added some glass to stiffen up the area. you can also cut off 1mm all along the hinge line to get more clearance from the control surface.
My Feedback: (51)
i am the moderator of the TopRC group, and im a private hobbyist just like you. i am also the moderator of about 20 other RC groups (including vendor specific), so your claims about any company moderating any of my groups is completely out of line.
i do think the Facebook groups are the best place to get information, good or bad, and genuine information is NEVER moderated. this has been my way for 30 years in RC and the same applies for all my groups, not just TopRC.
i hope its finally clear and we can get back to modelling.
My Feedback: (53)
The following 2 users liked this post by Dansy:
lavi rider (04-30-2022),
My Feedback: (176)
So what I noticed about that brand, I know two friends that they winning today delimited specially the upper skin, my voyager has two close calls, one when my alieron got stock on the winglet and second with similar flap problem, the most important thing is that they don’t use quality epoxy or they have wrong mixture ration because they never fully cured with chemical reaction they look like they dry but not strong and when they heated they turned very soft like vinyl floor specially the skinny edges, they need to fix the quality of their models before they going to end up like fly eagle jets.
My Feedback: (21)
I don't want to turn this thread into a he said she said type of thread I just threw this out here as information. All I wanted to know was if anyone else has had this issue with the Odyssey.
Looking at the wing last night I do not have delamination of the hinge. What I found is the layup is thin in the area where the flap meets the wing on top and the air pressure possibly pushed it down causing the flap to catch this trailing edge. I need to look at it a little more in depth to see what solution I can come up with to fix it. I did have an opportunity to see another Odyssey that was an older kit and it did not have the amount of flex at the trailing edge of the wing in front of the flap, As mine has.
Hi,
Perhaps gap sealing tape can be an easy fix to your problem. It was quite common for sailplanes.
Stick the tape to the wiper and pass it under the wing. The tape has to be wide enough so that it doesn't come out at full flap deflection. The tape will seal the gap and act as a guide for the wiper so it doesn't catch the edge of the wing.
Well, you are not the first, and probably not the last who think that TopRC is crap.
Take a look at my experience with the Odyssey...
Introducing the Top RC Model Odyssey - New sport jet - build thread
OK lets set things clear once and for all. there is only one troll here and its not the OP.
FARRRRRRRRR FROM THAT ..
I got over 40 years experience in composite structure design ..
A poorly designed structure ( or no design of any kind like some of these Chinese copy paste / fudging crap quality glue) of total lack of knowledge or just poor craftsmanship , lack of Q/C . Lead to these and other failures described here .
Unfortunately this will continue to happen as long as the community will keep feeding these companies.
Let’s be honest here .
A . These companies won’t let you surface their faults like proper professional companies do who actually strive for feedback to rectify and improve their products.
B. Products seldom fail . But a product constantly failing without any sign of rectification should ring a bell !
Unfortunately from first hand experience this company’s products are miserably manufactured etc .
I truly hope someone out there read the users comments and do something about it to take their products to a proper level .
snir2001 (04-30-2022)
My Feedback: (176)
You can just summarize it like, TopRC is pure toy grade crap.
I know from first hand....
This is very common on the odyssey.
Toprc is built cheap and are cheap to buy, this is fine except when there is an issue identified the social media fans shoot down the messengers instead of creating threads on how to improve the jets and warbirds sold as it really doesn't take much to make them 100% better and you end up with a cheap great flying plane.
snir2001 (05-04-2022)
