 Yippee !!!!!! MW 44's Arrive >
Old 10-24-2003 | 04:44 PM
SJN
Default RE: Yippee !!!!!! MW 44's Arrive
My guess is that both engine start at the same time then??
SJ.
Old 10-24-2003 | 05:02 PM
If you are using the manual start FADEC, you can simply leave the throttles at idle and start. You just start one, then the other. The throttle channel just remains at idle for start anyway.
Old 10-24-2003 | 06:25 PM
My Feedback: (81)
I would like to get this kit where can you get one?
Old 10-24-2003 | 06:28 PM
I think the MW-44 is only available pre-built, not as a kit.
Old 10-24-2003 | 06:34 PM
SJN
ME-262 kit
http://www.airworld.online.de/Englisch/Index.htm
SJ.
Old 10-24-2003 | 06:38 PM
  #31
Oh
(Oh dopey me!)
Old 10-24-2003 | 10:32 PM
  #32
uncljoe's Avatar
My Feedback: (8)
Dave
Have you install Flaps? and do you have any pictures of the fuel system installation / ECU etc
Semper Fi
Joe
Old 10-25-2003 | 04:31 AM
  #33
Vincent
Yup as the Muliplex guy says, you just leave the throttles at idle and start both one at a time.
Each MW 44 comes with it's own starting wand so two people can do it or just one.
I'm using a single large tank feeding hoppers-so one can be started first and it doesn't leave me with different levels in each tank-hopefully they will both run dry together!
8 minute flights are easy on the two litre pop bottle tank I'm using.
I'm expecting to be well throttled back with the power to weight we have.
Dave Wilshere
Old 10-25-2003 | 07:05 AM
  #34
Vincent's Avatar
My Feedback: (61)
Dave,
You fit a 2L soda bottle in there as a main tank?? do you have a pic of that setup??
Vin...
Old 10-25-2003 | 10:47 AM
  #35
Gaspar's Avatar
You are correct about starting the engines. Connect all the fadecs trough a "Y" arness, set the throttle to idle, and start one, and then the other. No problems at all. We used this system in the Artesjet Hotspot that was powered by 3 JF50 bees. The 3 fadecs where connected together to the throttle channel, and to start we set the throttle to idle and started the 3 engines, one after the other. The engines where installed very close one to another, and we used the data terminal of the fadec to see the egt to detect when the gas ignited. After a bit of practice, we had the 3 engines running in a couple of minutes.
You will be very pleased with the MW44. I own one, that I'm using for setting up the autostart installed on a Savex L39, and it is a very fine engine. The tank is of 950cc (32oz) and I have 6 minute flights, plus a couple of minutes more of taxi, and always stop the engine with 1/4 of the tank left.
Regards,
Gaspar
