 Which thread locking fluid do u use ? >
Old 11-18-2003 | 06:29 PM
Default Which thread locking fluid do u use ?
I'm looking for some thread locking fluid for my DF applications (engine carb bolts, ...).
I hesitate between :
Loctite 243 and 222. Which one do u use ?
Thanks.
File Type: jpg
File Type: jpg
Old 11-19-2003 | 11:16 AM
seanreit's Avatar
My Feedback: (60)
Default RE: Which thread locking fluid do u use ?
I've used both, and find them both to work well in all the applications I've used them in, including .91 DF stuff.
Old 11-19-2003 | 12:51 PM
I have used them both. However after experience with both I now use only the blue 242 .
The reason is the "hold" of the purple 222 is simply too light .
As you probably are aware, DO NOT use the red unless you NEVER plan on disassembly.
Old 11-19-2003 | 02:31 PM
patf's Avatar
i use the blue as a minimum. I also have the red and green on hand as well. the red is when I rebuild an os 91. the green is thin and can wick into already threaded applications.
Old 11-19-2003 | 04:54 PM
Thanks to u all.
Patf, what's in your avatar ? I can't guess !
Old 11-19-2003 | 08:50 PM
patf's Avatar
supposed to be my dog, but brown dog on brown background at low res does not look like much...
Old 11-22-2003 | 09:50 AM
NickC5FE's Avatar
My Feedback: (31)
You know, seeing as how its a jet you ONLY want to use BVM Jets threadlock Just joking
