Skymaster Gripen Almost there
RE: Skymaster Gripen Almost there
ORIGINAL: MMallory
I don't see the brake lines either. But these pictures are a bit dark.
Mark
Mark
I think you hit the nail.....
My Feedback: (24)
ORIGINAL: MMallory
Mark
Mark
Shoot me your address Mark to [email protected] for your free tube of Hysol
Good Eye
#31
...and your spanish seems to be better than my english[X(] , which is not to dificult....[]
Thanks for the comparation....[sm=RAINFRO.gif]
Hasta la vista,
Miguel
Hasta la vista,
Miguel
ORIGINAL: lov2flyrc
¡Da las gracias Miguel! Mis instalaciones miran casi tan bueno como suyo
#32
My Feedback: (24)
To answer the other questions asked....
The clear line hanging out the gear well is the propane fill line, propane tank sits below the canards attached to the front of the intakes. A Faux carbon plate will be attached to the front of the hatch opening as I have done in the rear which will have a holder for the propane fill festo. Tygon line hanging out the gear well is the tank overflow. Revolution whip antenna will be used along with Duralite ECU and RX packs and a Duralite 6V switched regulator. Also using Skymasters new wheel/brake set which use a new type of brake mechanism, see picture below....
Todd
Todd
#33
My Feedback: (29)
ON, CANADA
After you stated to ignore the fact that the front section was incomplete IE the valves(wich by the way have no airlines), we could all assume that the brake lines were part of the aircraft that was incomplete. We were then steered to engine bay compartment?
#35
My Feedback: (24)
ORIGINAL: KAPTAN KAOS
Sean,
Daves brakes are a disk/caliper type setup, Skymasters resembles a drum brake...
Todd
#36
My Feedback: (60)
No worries Todd, I gave that engine a hard look myself. I noticed there where no zip ties on the struts (something I know you do) but from the picture it's at best a guess as to whether there were lines on it as the brake system doesn't have the tell tale brass fitting 90 degrees to the wheel. Something I've never seen before.
There appears to be an extra hole behind a fuel cell in that bay, that's the only thing I could come up with besides the missing zip ties. Other than that, this is a typical Todd Whitkoff installation, clean, and nearly perfect.
Call me tonight (after 8 easter), I'm considering sending you some large business that I've lost interest in.
#37
My Feedback: (29)
ON, CANADA
I saw those brakes at the skymaster tent. They look neat. It started me thinking of other ideas for brakes that I may try in the future. I thought that with the brake shoes hinged at one area, that one may try to lock up due to the direction of the wheel. If the brakes were hinged at oposite sides they would free up when released. A cam can be used to push the brakes outward like the skymaster set, or even a smaller hub inside the shoes with an O ring similar to what we use now. Just different ideas!
On my previous post, all I was saying is that we were steered away from the brake valves and lead to the engine area. I just misunderstood.
#39
My Feedback: (29)
#40
My Feedback: (29)
ON, CANADA
ORIGINAL: grbaker
In my 20 years as a medium duty fleet mechanic, all of the drum brakes that I have ever seen, had both shoes pivot on the same end. That way, you only need one actuator to move both shoes.
Yes but they would have heavy springs to pull them back to center when released. Direction shoes would self release and could be activated by an expandable O ring like what we currently use.
#41
My Feedback: (29)
The springs on the shoes have more to do with preventing premature wear (due to the shoes dragging against the drum when released) than to keep the shoes from locking up. It takes a lot of force to make a brake shoe lock up the drum. I have pulled apart brake systems in which some or all of the springs were broken, and the driver never noticed a difference.
But if you have a single brake shoe that wraps almost all of the way around the drum, then it has to be directional. I have a set of brakes using this design on 1/5 scale P-39 that weighs 30 pounds, and they are the best brakes I have ever owned.
#42
My Feedback: (59)
VA
Looks sweet Todd!
Im gonna pack mine up, send it to you, and let you finish it for me!! I can't seem to get the motivation to finish the darn thing![]
Take care dude.
Joey.
Take care dude.
Joey.
#45
My Feedback: (20)
ORIGINAL: lov2flyrc
Got a little trivia for you guys. In my rush, I forgot to make an important connection which you should be able to figure out from the pictures. First 100 members to identify it will get a free tube of Hysol! Can you figure it out?
Todd
Todd
#46
My Feedback: (24)
Where did that quote come from Ben...????
As you can see from the original post it stated first person to identfy what was missing would get a free tube of Hysol??
#47
ORIGINAL: lov2flyrc
Ha Ha I think Ol' Ben is just yankin' your chain, Todd!
#49
My Feedback: (24)
Sorry guys,
plane is ready but still unflown. Last weekend my local field had an IMAC meet and I was unable to fly, this weekend I was tied up with family.... Maiden no schedualed for next sunday!
Todd
Todd
