 WREN 44-Airframes??? >
Old 01-09-2005 | 09:22 AM
rcguy!'s Avatar
My Feedback: (69)
Default RE: WREN 44-Airframes???
ORIGINAL: jacksonretlaw-RCU
I am sorry gentleman.Here is the linkis,[link]http://www.mirage2000-model.com/[/link.
I will try to post some pictures later for you.The jet is not an arf.But should be an easy build for those with experiance.I live in the United States.So the shipping was easy for me.Mr.Lahaie was quick to answer my emails.Will be buying another kit from him.Any more questions feel free to ask.I am just starting to lay out fuel tank placement and turbine.
Thanks! Pictures please and info. Very interested! Wren 44 power!
Dave Rigotti
Old 01-09-2005 | 11:02 AM
My Feedback: (16)
Here are some pictures.Just started working on the jet.I will post more pictures with all included with kit.
ID:	212661   Click image for larger version
Old 01-15-2005 | 01:51 PM
My Feedback: (16)
Hey guys.What happened to this forum.Lets keep it going.To many of you are waiting for the Savex L-39.This Mirage you can have a lot sooner.We should be out flying not waiting to.Here are some new pictures of what comes with the kit.
Old 01-15-2005 | 01:55 PM
My Feedback: (16)
Here are the pics.
ID:	215552   Click image for larger version
ID:	215553   Click image for larger version
Old 01-15-2005 | 02:05 PM
Wayne22's Avatar
Do you have the larger one, or the medium size Mirage? There is a huge price difference between the two....
Old 01-15-2005 | 02:44 PM
  #31
My Feedback: (16)
This is the 63" inch version.The larger version I believe is the Mirage 4000.That airframe is probly more suited for the larger tubine.
Old 01-25-2005 | 08:58 AM
  #32
Alexdu's Avatar
Jackson:
The Mirage looks great. How's the build going? Keep us posted.
Regards
Alex
Old 02-02-2005 | 11:38 AM
  #33
What about the upcomming kevlar rafale C from aero naut...
http://www.aero-naut.de/aeronaut/en/allg/
Click on the aircraft tab, then aircraft model kits.
In the right column, under military aircraft.
Yann
Old 02-02-2005 | 08:52 PM
  #34
A few here.
Hello we had the web address incorrect, it is fixed now. Thank you for the report that it was wrong.
F-16, F-18, L-39,F-86 Others. All about 1/10 scale.
[link]http://www.ductedfans.com[/link]
Old 02-03-2005 | 03:42 AM
  #35
Ductedfann,
Your link doesn't work...
Yann
Old 02-03-2005 | 05:32 AM
  #36
Yellow aircraft sells a bunch of airframes where the MW44 could fit in.
http://www.yellowaircraft.com/jets/index.htm
F16, F18, Douglas A4, Starfire or stingray.
Old 02-03-2005 | 07:36 AM
  #37
Alexdu's Avatar
Yep. Remove one n from the link.
Regards
Alex
ORIGINAL: Yann
Ductedfann,
Yann
Old 02-12-2005 | 09:46 PM
  #38
My Feedback: (16)
Back to work on the Mirage.I wish I had more time to work on this jet.I would like to have finnished before spring.Here are some pictures of the wing work in process.I had to cut out for servo's and landing gear mounts.
ID:	228519   Click image for larger version
ID:	228520   Click image for larger version
Old 02-12-2005 | 09:49 PM
  #39
My Feedback: (16)
Here are pictures of elevon work on wings.
ID:	228523   Click image for larger version
ID:	228524   Click image for larger version
ID:	228525   Click image for larger version
Old 02-12-2005 | 09:58 PM
  #40
My Feedback: (16)
Started on the turbine mount.Jetcat P60 mounting bracket.Using two sullivan 12oz ducted fan tanks and 16oz boat tank.Will be using
6 oz hopper tank.
ID:	228528   Click image for larger version
Old 02-13-2005 | 10:29 AM
  #41
Shok's Avatar
My Feedback: (28)
Our fully composite F7 getting paint for this season of flying.
Made just for 7 lbs. thrust turbines.
ID:	228721   Click image for larger version
ID:	228722   Click image for larger version
ID:	228723   Click image for larger version
Old 02-26-2005 | 01:38 PM
  #42
J.F
Shok, thats a nice looking plane.
Anyone flown a jetwelt.de 1/10 Phantom F4 with a MW44 yet?? Looks like it would be perfect.
James
Old 02-27-2005 | 03:04 PM
  #43
A BTE Vortex delta is designed for engines up to .91 size and it could easily be converted to suit the MW 44 turbine.
duthie.
Old 03-02-2005 | 07:48 PM
  #44
Jetset's Avatar
H.Dale,
If you find anyone who has converted a Sport Shark please fill us in ok?!
I have one that's in need of an overhaul as well and I often thought it would be perfect for those smaller turbines!
What a FAN tastic flying little plane it was in it's day!
Also, i have one of Marcels midsize Mirages and it used to have an OS .91 setup. It would scream!
Myles
Old 03-03-2005 | 05:23 AM
  #45
The fouga CM 170 from Christen Diffusion is an other
perfect match for the wren44...
This plane has been designed around a 30N turbine thrust.
http://christen.diffusion.online.fr/
then click on the modeles tab, then fouga reacteur.
Yann
Old 03-03-2005 | 05:41 AM
  #46
David Gladwin's Avatar
That Magister looks really suitable , big wing low gear and simple layout, except for bifurcated exhaust. Looks like a trend is starting !
Anyone ordered one yet?
Regards,
David Gladwin.
Old 03-03-2005 | 05:48 AM
  #47
David,
They provide the bifurcated thrust pipe for 120 Euros.
I called the guy,Here is the price list:
FOUGA CM 170 kit 630 €
retract 200 €
thrust pipe 120 €
carbone cone 28 € (necessary for pipe mount)
I'm seriously considering this plane, while waiting for my Savex F16...
Yann
Old 03-03-2005 | 06:05 AM
  #48
Here is what you get in the basic kit:
Old 03-03-2005 | 09:11 AM
  #49
Hi,
How about the new Hawk from Daniel Schuebeler which will probably go in production.
wingspan 1210mm, weight 3,5kg
More info + video:
http://www.rcgroups.com/forums/showt...3&page=3&pp=15
http://www.rcgroups.com/forums/showthread.php?t=338805
Greetz.
Chris
ID:	237435   Click image for larger version
ID:	237436   Click image for larger version
Old 03-03-2005 | 09:56 AM
  #50
Christopher 2,
That plane is just a prototype...
At least 2 other hawks are already available for the wren 44.
One from PJPJET, and one from AMD !!!
Yann
