Nitro models pusher Bobcat?
#902
My Feedback: (38)
RE: Nitro models pusher Bobcat?
ORIGINAL: i3dm
can anyone give me some details on how to install the retracts ?
thanks.
thanks.
I haven't started on mine yet but I'll probably be conservative so I don't have to recover like this.
#903
HEy all
I order one of these and will be doing the E conversion, I have a ROssi 81 that is designed for the DF Byron, reverse rotation ect..I only want 150.00 for it...
Bruce
Bruce
#904
Hey Matt Grant, Your Bobcat looks great! Did you recover your plane or did you paint it?
Do you or does anyone know if putting mechanical retracts in this bird would be tough to do. I have a set of retracts that need a home. And this bird sitting along side my F20 at the field would look great.
#905
Original Question:
Answer: I had the body painted at a body shop and I used ultracoat on everything else. I had to redo my landing gear and in doing so, I noticed that there was lots of room in the wing and that the mods. should be easy. Reading some some of the blogs it looks like it is easy to do. That is next on my list, but for right now I am enjoying the landing gear that I put on her.
#906
AB, CANADA
I'm assuming with this though that you are using a CG sling which is a simple enough device to make. It consists of two large loops of heavy cord or light rope hung from a central point,
#907
Original question:
Mattgrant, nice job! I have one that I'm just about to glass the wings, retracts are installed and just finishing the details on the booms and off to the paint room.
Where did you get the clear canopy?
Angus
Hey Angus:
I actually cut out the plastic of the old canopy and used it as a template on clear plastic. I then used shoe goo to the frame. It actually was quite easy, and looks alot better. I am planning on putting a pilot in the plane and the smoke look of the original canopy I did not like.
Angus
Hey Angus:
#910
Thanks Gary Don:
I have flown it twice and it handles very nice. Just was not quite sure on the CG on a pusher. Point the plane in the direction you want to go and she goes there with no problems. Check the landing gear because after my first flight the blocks gave away and I had to re mod and everything is fine now. Check out the pictures about. It is the black Bobcat. I have a magnum .52 with a 10x6 prop. need to change to a 11x7. I think I will get more speed. One of the funnest planes I have.
#911
ON, CANADA
I removed most of the underside and built up some of the spars as well as add another one. Then I glued in a mount for the retracts similar to a flex plate. I moved the servo well over for the ailerions. When I pulled off the balsa sheeting to remove the existing mounts and do the build up, I sure noticed the poor and lack of gluing done inside.....I'm not sure if I would put a turbine on one, it's going to give sooner or later. Anyway I re-glued everything and did full sheeting so I can glass it.
Angus
Angus
#914
SC
Balance with the fuel tank empty.
ORIGINAL: mattgrant
Well here is my baby. Using a Hobby People Magnum .52 with a 10x6 APC prop. Not getting the speeds I want. Looks like from the feedback I should try a 11x7. First flight the stock landing gear craked the wing on one side. With her new stems she now lands nice and smooth. It looks like everyone's CG is about 10.25 to 10.5 from the leading edge. It that with the fuel tank full or empty??? Still one of the funnest planes I have had and she turns some heads at the field.
#915
SC
Awesome looking Bobcat!
ORIGINAL: mattgrant
Here is some more. None of the colors they were selling really did anything for me, but the bunny does.
TOPGUN---THERE CAN ONLY BE ONE!
#916
Banned
ORIGINAL: mattgrant
Fit a Tower or GMS 47 muffler, it'll give you *significantly* better power and only costs $15. Not as good as tuned pipe but waaay better than the stock "quiet" muffler you're running.
Then try a 10x7 prop. I think 11x7 might be a bit big, loading that 52 down a bit much -- and with a 7" pitch you'll need revs to get speed.
#917
ORIGINAL: mattgrant
Can anyone tell me if they are finding the CG of the Bobcat with the tank full or empty?
Thanks.
Thanks.
Here's a picture of a SIG Akromaster in the CG sling. This one has the loops through a piece of dowel and the dowel supported from the rafters. The plumb bob hangs from the center of the dowel and the weighted string is pointing right to the joint between canopy and fuse.
#918
SC
The fuel tank is over the CG at 10". If you balance it at 10" there is a slight change in trim between full tank and nearly empty.
ORIGINAL: Clean
Is the fuel tank in front of or behind the CG. You never want the change in fuel level to put the aircraft behind the recomended CG placement. Now I know in this airplane there is a debate on where that CG should be, and I think the latest is around 11 inches, but if it flies sensitive at 11 and you go putting fuel in behind the CG, it will move back and make it more sensitive and possibly, dangerous.
ORIGINAL: mattgrant
Thanks.
Thanks.
#919
Banned
1 Post
Detailed build thread
If any of you are interested I am doing a detailed build thread here:
http://www.rcgroups.com/forums/showt...14#post6724014
on RC Groups
Dennis
www.densplanes.co.uk
on RC Groups
Dennis
#920
Original Response:
Are you saying to move the fuel tank forward? Right now as we all know, it is installed in the rear compartment, right be hind the engine. Just curious, can the manuel be that in correct?
#921
My Feedback: (51)
Guys,
An important question - my brother is in NY and i would like to order a BobCat 50 to him and have him bring it back with him, so i really need to buy one RIGHT NOW !
Does anyone know where i could buy one ASAP over the phone ? maybe even buy from someone on RCU ? ill pay full price for a new kit + shipping to NY.
thanks.
thanks.
#922
Original Questions:
thanks.
Answer:
I am in CA and the company that you want to buy it from is in ca called NITROMODELS. But the are at the AMA show in Ontario, CA this weekend. Call them mon at 1.626.369.2301. Or, if you know anybody in CA, have them go to the show this weekend and buy it for you.
thanks.
Answer:
#924
AB, CANADA
#925
SC
I wouldn't move the tank. Moving the tank forward will make the plane more nose heavy with a full tank and better balanced with an empty one. It's a very minor trim change in mine and most of the time I don't both giving it any elev trim to compensate (1 click). Most planes take off nose heavy with a full tank since the planes are balanced empty and the tank is in front of the CG.
ORIGINAL: mattgrant
Original Response:
Original Response:
