Bob Cat Copy Falcon 120 Jet
#3726
RE: Bob Cat Copy Falcon 120 Jet
ORIGINAL: mk1spitfire
Don't you mean up thrust as engine at back?
Down thrust is always down thrust, the tailcone (exhaust) of the turbine may be pointing up but the thrust is pushing down, no matter if the turbine is at the front or back !
The way I get people to understand it is, thrust is a reaction force, so think on a rocket, the force out the back pushes it up (up thrust), which ever way the nose or front of the turbine (starter) is facing is the direction of thrust.
#3727
Hi Alasdair, it is a Wren Supersport with a 2 litre coke bottle as a tank and Spring air retracts with a nose leg from Ali Machinsky as sold for the boomerang intro. Hope that helps
Rod
Rod
#3728
13lbs? My mate has same engine but 2litre on it weight is 17.5lbs with light retracts, im told.
#3729
ORIGINAL: Xairflyer
Here we go again, this has to be the biggest deja Vu subject on RCU it pops up multiple times in multiple threads
Yer aussie, 13lbs is great for you!! I think that other guy said his was 13lbs with supersport though.
#3731
lol, how about this? What I meant is with turbine on the back its not like an engine on the front angled down, its angled up at the back!!
#3733
Thrust lines are relative to the Datum line drawn through the fus, the relative thust is a reaction so points in the direction it is pushing or pulling, therefore if the turbine being at the back is pointing up at the front, i.e. starter motor end it is up thrust.
When considering the need for up thrust on the Falcon we must consider the speed of the air under the tail having an effect, as we know the faster the air over or under an airfoil section compared to the relative airflow above or below will produce lift, in this case it has the opposite effect it pulls the tail down and therefore the nose up, this has to be compensated for either with up thrust or trimming of the tail incidence.
Mike
Mike
#3734
NY
Has anybody heard of a new plane like the Falcon 120 that is going to be for sale soon? I over heard some people at the hobby shop talking about a plane that looks like the Falcon but is turbine ready with retracts and fuel tank for $475.00. I have been looking every were with no luck. If thats true it a hell of a lot cheaper with out the work. Please email me if anybody knows any info
#3735
ORIGINAL: 747junky
http://www.flyeaglejet.com/en/Trainer.html
And in relation to the definition of downthrust and upthrust, check out this discussion! I'm too chicken to buy into it!
http://www.rcgroups.com/forums/showthread.php?t=597244
#3736
That is a rip of from Aviation Design, they did not even change the name: http://adjets.free.fr/ the Phoenix is the smaller version.
Mike
Mike
#3737
NY
I will call the hobby shop and ask, but no its not fly eagle I think and besides fly eagle plane is over $1000 dollars. This plane there taking about is from the conversation I heard was $470 dollars complete with gear and composite fuel tank.
#3738
NY
I just found out the story on that new jet I posted the info on the thread " New Jet Question andy info would help". Seems to be something to look for
#3740
NY
I just spoke to Terry from Warricks Hobby Super store in Ft. Lauderdale FL and he told me that this new plane is made by Modellbau USA. It is called the Tornado, ( twinn boom bobcat type airplane) with factory installed Spring Air retracts and composite fuel tank . He told me that price is still not firm but will be around $475.00. Terry was going to speak to some guy named Henry at Modellbau USA to get more info on when it will be released.
#3741
NY
quote]ORIGINAL: Modellbau USA
Hello my name is Henry Castellanos, I am one of the new owners of Modellbau USA. We are releasing a new airplane called the Tornado. this airplane is a twin boom design that resembles the Bob Cat. We are not ready to post any pictures at the moment due to the expected release date being 2-3 months away. As stated in the previous posts, the airplane will come with Spring Air retracts and Composite fuel tank for around $475.00. We are currently flying one of the factory's prototypes in Florida. The kit is being made in our new factory in Ecuador. As soon as all the flight testing is complete we will begin pre-sales approximately November 15, 2010. If you have any further questions please feel free to email me at [email protected] or if you need spanish sales or assistance you may contact Alberto Enriquez at [email protected]
[/quote]
I guess it is true then.
[/quote]
#3743
The plane will be available with out the retracts by special order only, since they are being factory installed. We have partnered up with Spring Air Products to produce a custom set of retracts that are sold with the kit. Spring Air is making up a package of struts, wheels and brakes for this airplane that will be well under any thing that you can get on the market. What are goal with this project and our next jet (F86D) that we are expecting to release early next year is to give the consumer a good quality product with out having to break the bank. All of our kits will have composite fuel tanks, Spring Air retracts, and composite control horns. We will also be having special package deals with Jet Cat turbines
#3745
Hi ,
i've noticed, that all you guys,giving 3 to 6 degrees down thrust to turbine?.Why is that?I mean , you're doing this is for not to burn the elevator or for flight reasons?If i install the turbine at 0 degrees is a mistake?
Thank's in advance for any replies....
#3746
Hi
I have my 54 Wren angled down around 4deg, this is done so when you go full throttle the aircraft remains level. Having 0deg can cause the aircraft to climb when going to full throttle!
Alan
Alan
#3747
ORIGINAL: POWER JET
Hi ,
Hi ,
Yes it will help prevent the tail from getting hot/burnt, but it is not down thrust but up, the tail/rear of the turbine is angled down, which will also help it get off the ground better. Zero setting is still ok, but most find pointing the tail down a bit helps.
#3748
ORIGINAL: fireblade5437
Hi
Alan
Hi
Alan
#3749
But that is not why it is there. The issue is that the high velocity turbine exhaust causes the air flowing under the horizontal stab to be faster than the air going over it. Bernoulli's effect then causes the stab to lift downwards, thereby creating a nose-up pitching moment that increases with turbine power. The exhaust down angle helps to alleviate this.
#3750
ORIGINAL: Xairflyer
If you have the rear of the turbine angled down and it stays level at full throttle then having it at 0deg will make it go down not up
Hi
Alan
Hi
Alan
