Reload this Page >
Bob Cat Copy Falcon 120 Jet
Old 07-28-2011, 06:49 PM
  #4076
jetflyr
Default RE: Bob Cat Copy Falcon 120 Jet
DANG Ray!
Those look nice!
Greg
Old 07-28-2011, 08:12 PM
  #4077
Aussie1
Mate, that combo looks brilliant! I actually cracked my canopy the other day, and what do you think the total cost of tub, canopy and postage would be to Australia? Also what is your peferred payment option?
Thanks, Dave
Old 07-28-2011, 08:22 PM
  #4078
Aussie1
C of G should be 13inches BACK from root leading edge. IE- where the very front of wing, butts up against fuselarge. Check c of g with a empty main fuel tank. Also make sure that you have a slight nose up attitude when at rest on the wheels. With 15 degrees of flap for take-off it will just take-off by itself in about 50-80 metres. Great model!
Old 07-28-2011, 10:23 PM
  #4079
bigplumbs
Banned
ORIGINAL: alasdair
Last year (when I bought my Falcon) I checked back in the thread and people were using retracts and legs sold by Digitech specifically for the model.
Digitech no longer seem to do retracts, so does anyone know an alternative UK or European source for suitable retratcs & legs?
Jeff at Jetlegend. www.zedjet.com
http://www.zedjet.com/index.php?act=...d&productId=25
You just need to do a small mod to the nose leg
These retracts are very strong, I have about 6 sets
Dennis
Old 07-29-2011, 06:18 AM
  #4080
jaybeevee
I would be interested in a couple of these, including the inner tray, if the total price is reasonable. If you were bulk buying, I would have to take into account getting them from you to me
Old 07-29-2011, 10:02 AM
  #4081
noray1
Please contact me at: [email protected]
Ray
Old 07-29-2011, 10:05 AM
  #4082
noray1
Ray
Old 07-29-2011, 11:11 AM
  #4083
noray1
Canopy = $20.00 + $10.00 S&H in USA Sorry, I no longer have the cockpit/tub.
If you have a PayPal account you can post payment to my E-Mail address.
If not I can send you a PayPal money request that will allow you to pay with a credit card.
Please let me know.
Ray
Old 08-02-2011, 04:34 AM
  #4084
Dblex
My Feedback: (81)
Dblex's Avatar
SO is this a rail mount or firewall mount on the nose gear? read everything but now confused. 102HD spring airs seem to be popular fits?
Old 08-06-2011, 07:21 PM
  #4085
Mitchell-RCU
My Feedback: (49)
Anybody had any problems getting off the the groung with a Ram 500 on grass. I have tried twice to takeoff from a 300ft bermuda grass runway. Not getting enough speed.
Mitchell
Old 08-07-2011, 01:01 AM
  #4086
Xairflyer
Xairflyer's Avatar
check your angle of attack you might have your nose too low
Old 08-07-2011, 01:20 AM
  #4087
tim777jet
hey bud, as per the previous reply, check the nose is slightly high when it is on its wheels. If not, you can put packers under the nose retract mount but the wheel wont fully retract then, but will be fine for a test flight.
Check your engine down thrust (upthrust), if the rear of engine is pointing down more than a few degrees, then it will be pushing the nose leg down hard during take off. You could take a degree of down thrust away, again use packers under the engine mount.
Try reducing your fuel quantity, how much do you carry, try a 3/4 full tank and fly for say 5 mins, at least you will be airboune and see how she flys.
You could try a small amount of flap, although i didnt see any benifeit at my field, but others do, worth a try.
Are your wheels large enough for rough ground, small wheels will dig in, i use large wheels.
are the wheels free, and if brakes are fitted, are they releasing properly.
Check your c/g , too nose heavy will hinder rotation.
All the best tim
Old 08-07-2011, 06:54 PM
  #4088
Mitchell-RCU
My Feedback: (49)
I have a +2 angle of incidence level with no fuel. Its actually a little more with fuel and the compression of the struts. It seems to do fine on asphalt, but i dont have anywhere i can fly from asphalt. Im thinking about putting a p-80 i have on it.
Old 08-07-2011, 08:02 PM
  #4089
jetster81
Hi Folks, without having to rummage through this mighty thread can anyone please let me know from experience the best balance point on this plane? thanks.
Old 08-08-2011, 11:23 AM
  #4090
w4sm
w4sm's Avatar
ORIGINAL: jetster81
The easiest solution is to go to the top of this page, click on "Search this Thread" and enter "C.G." You'll find a number of posts quickly.
Old 08-08-2011, 12:06 PM
  #4091
bigplumbs
Banned
ORIGINAL: Mitchell-RCU
Somthing must be rong as this plane should easily get off with a 60 size turbine. I have also seen them fly and take off fine on a Wren 44 gold 10 lbs of thrust. You should need a P80 it is too big
Dennis
Old 08-08-2011, 04:11 PM
  #4092
ticketec
ORIGINAL: bigplumbs
Dennis
Yep, I have an older Wren 54 (Mk2.5 to be precise) which is putting out about 14-15lbs thrust, I takeoff with about 1.8lts of go-go juice and I've only ever flown off grass I would estimate that she need about 100-150m to rotate and the performance is pretty good. The first few flights were with the full 2.1lts my tank will hold and it needed more realestate to take off but nothing out of this world.
dave
Old 08-08-2011, 09:40 PM
  #4093
jetster81
ORIGINAL: w4sm
ORIGINAL: jetster81
Many thanks for the tip, I will be using it often in the future Cheers
Old 08-21-2011, 12:54 PM
  #4094
vease
vease's Avatar
my dads falcon has been flying for a good few years now but a couple of months ago got damaged on an arrival. Today though it finally took to the sky's again after a full re-spray/cover.
Old 08-30-2011, 05:33 AM
  #4095
vease
vease's Avatar
The Falcon's new scheme has now been finished and we flew it a few times this weekend at the British Nationals. I'd forgotten just how smooth and nice it was to fly. Had no issue at all with the high crosswind.....
Old 08-31-2011, 04:06 PM
  #4096
Mitchell-RCU
My Feedback: (49)
If your using 150m to rotate with 14 to 15 lb thrust im not surprised that i can't get off of 300 feet of grass with 12 lbs of thrust.
Mitchell
Old 08-31-2011, 04:09 PM
  #4097
Mitchell-RCU
My Feedback: (49)
I have removed the Ram 500 from the falcon and started installing the Jetcat P-80. I have the P-80 turned down to 18#. I believe this setup will get off of the 300 ft grass strip without any problem. I have a 90oz kevlar tank plus the UAT.
Mitchell
Old 08-31-2011, 11:37 PM
  #4098
BaldEagel
BaldEagel's Avatar
Mitchell
With a JetCat if you install the Pitot system you can restrict top speed without dialling down thrust, so full thrust for take off and verticals, but top speed electronically limited. you will also need to do a lot of reinforcement to the turbine mount on the fus to resist the bouncing crack with that weight turbine, I drilled 10mm right through the rear cantilever into the fus and Hysoled in two 10mm Carbon rods all the way up to the wing spar against the root rib.
Mike
Old 09-01-2011, 01:02 PM
  #4099
Mitchell-RCU
My Feedback: (49)
I was surprised that when i weighed the Ram 500 and the Jetcat P-80. The Jetcat is only 7.8 ounces heavier than the Ram 500. The support to the engine mount sounds like a good idea and i am going to do that as well.
Mitchell
Old 09-01-2011, 04:27 PM
  #4100
Todd Jackson
Got a older P-80 in mine and just got her in the air after a long wait on bearing replacement. It is very smooth and a joy to fly.
A friend of mine put his GPS in it Sunday and I was floored. On a flat pass no diving it clocked 238 MPH. I think I am still nose heavy.
The P- 80 will be just fine...ENJOY
Todd Jackson
