Futaba FASST feedback and TESTING
#651
My Feedback: (10)
RE: Futaba FASST 6
ORIGINAL: Woketman
I thought that Matt said that the channel expander was working on the 12FG too, even though Futaba said it does not. I could be crazy, but I thought he or someone said that.
Nope I was trying to find out that answer. I have heard, however that with the latest software, the 12FG is also 14 channels (12+2) just like the 14MZ and the 12Z.
To me the use of the MPDX-1 is worth the extra cost of the 12Z all by itself.
#652
RE: Futaba FASST 6
OK, sorry Matt. I know that the Spektrum 2.4 allows recording and playback of such things as antenna fades, missed frames and such with that little module. Does the Futaba 2.4 system allow any reporting of data for diagnostics to know how close you are to disaster? Thanks.
#653
RE: Futaba FASST 6
ORIGINAL: mr_matt
ORIGINAL: Woketman
Steve
#654
RE: Futaba FASST 6
ORIGINAL: rjbob
What is the difference between the R607FS and R617FS receivers?
Steve
#655
My Feedback: (10)
RE: Futaba FASST 6
ORIGINAL: Woketman
Not that I am aware of. There is a mysterious extra port on the receiver, so maybe they are going to add features in the future, so far nothing though.
#656
RE: Futaba FASST 6
ORIGINAL: Woketman
I know we had the GUID issue on the 6 and 7 systems, but one thing that has never raised any issues is the RF link, it just seems to be rock solid. (plug and play).
I have not seen any posts to the contrary and my own experience confirms it.
Paul
#657
My Feedback: (13)
RE: Futaba FASST 6
ORIGINAL: mr_matt
ORIGINAL: Woketman
Yes, 12FG is indeed a 14 channels radio (12+2)
Yes, there are post by a known flier indicating that the 12FG was able to use the expander. However it turned out that is not the case. Never figured out why the claim was made.
#658
CO
RE: Futaba FASST 6
Good news for the R608FS receivers! They don't seem to have the same signal voltage issues that the 6014's have. Or at least they seem to work well with all of my stuff which I can't say for the 6014's. (Just sent 5 brand new powerboxes back to Germany for component changes which will allow them to work with the lower signal voltage from the 6014's) Anyway, all seems good with the 608's but I did ask Futaba to verify this in their forum. See link below for results.
[link]http://www.rcuniverse.com/forum/fb.asp?m=7252541[/link]
Cliff
Cliff
#659
RE: Futaba FASST 6
Well, I have just taken delivery of my FASST 12FG
Great looking radio, good balance.
It is going into my test plane at the moment, and then next week end, into the L39 [8D]
I will update as needed.
Paul
Paul
#660
RE: Futaba FASST 6
ORIGINAL: GrayUK
To be honest, it does not seem to need that option; it just seems to work very well with out having to analyse the data after every flight to find the optimum positions of the extra RX’s.etc.
Paul
ORIGINAL: Woketman
Paul
We can not wait for using the FASST in Japan officialy.
#662
RE: Futaba FASST 6
Hi Guys
Question here... I've read the FAQ on the FASST website, but I am still not sure about that region coding. If I'd buy a complete set of a T12FG FASST with module, receiver and transmitter, will I be able to use it in Ireland without restrictions? As far as I understood the only problem would be that I need to continue buying any additonal receivers with US region coding as well, is that correct?
Hajo
Hajo
#663
RE: Futaba FASST 6
Hi there!
I bought one 12FG 2.4Ghz from US (love the radio), I live in France. As long as you stay 2.4 and by your Rx:s from the US I guess you'r OK. The problem starts when you want to use the radio with EU modules on "regular Frequenses" like 35, 40, 41 or others. Then your TX need to be region coded for Europe, that's when the hazzle starts!! Look in to fhttp://www.helifreak.com/ web sajt. They have everything about it!
Good Luck,
(next time I by a radio I'll be sure that I decided were I use it, not the manufacturer)!
rgds/krokko
Good Luck,
rgds/krokko
#664
RE: Futaba FASST 6
ORIGINAL: krokko
Hi there!
Good Luck,
rgds/krokko
Hi there!
Good Luck,
rgds/krokko
#665
RE: Futaba FASST 6
Well today was test day, weather was unbelievable! [8D][8D] Considering yesterday was like a tropical monsoon!
Flew the 12FG in my prop aerobatic plane, rock solid all the time even at extreme range, very nice TX
Had many flights with no issues at all, so it is into the L39 for next weekend, cant wait now.
Paul
Paul
#666
RE: Futaba FASST 6
Flew my 14Mzh with the 2.4 module for the first time today. It's installed in a small WWII Tony that has retracts and split flaps. The plane had it maiden with the 2.4 set up.
I did some longish range checks and everything was solid. So I put 3 flights on the new plane and there wasn't a single issue for any flight.
I'm getting ready to install another 2.4 reciever in my Trex 450 now. Seems like this Futaba system is rock solid IMHO.
#667
My Feedback: (29)
ON, CANADA
RE: Futaba FASST 6
I have flown a Hot spot, Boomerang Intro, 50cc Yak , cermark F20 and an electric mig 20, all with 2.4. Other than the occasional voltage issue when setting up, all has been well. The range check has been excellent. Not a single glitch while flying.
#668
RE: Futaba FASST 6
Thanks for the input guys, keep it coming. [sm=thumbs_up.gif]
What comes over very hard is the RF link on the FASST systems is just amazing, i have not had one negative report. [8D]
Paul
Paul
#670
TX
RE: Futaba FASST 6
I tested a new 8 channel FASST 2.4GHz receiver this evening and found the signal voltage on all 8 channels to be between 3.02 to 3.05 volts. So that receiver should be compatible with Hitec or any other servo that specifies a 3 to 5 volt signal requirement. To further demonstrate this we connected two 5955 servos on a "Y" connector and then attached an additional 72 inches of servo extensions leading to the receiver. Servo control was still rock solid.
We also found that new Hitec 5955 servos recently purchased still operate well below the specified 3.0 volt minimum signal voltage. They were flawless down to around a 2.0 volt signal. That apparently leaves a big margin of safety if they would be connected directly (no power expander) into any of the FASST receivers including the R6014FS that put out around a 2.65 volt signal. Infact all of my newer Hitec 5955's worked flawless when connected directly into my R608FS and R6014FS receivers.
Is it possible that some older Hitec digital servos that may not contain the most current software could be the real culprit in the low signal voltage issue? The signal voltage issue is just not a concern with my 5955 servos and the 8 and 14 channel FASST receivers that we have tested.
Doug Williams
Doug Williams
#671
RE: Futaba FASST 6
Found the following and don't understand.
It would seem totally bizarre for an engineer to intentionally design different signal voltages for different channels. After all the designer cannot presume to know what servos will be used in what locations.
Clarification is needed.
Bill
Apparently the signal voltage on the 6014FS is lower than norm on channels 3-14. 1 and 2 are 3.3V, the rest are 2.7 I believe (not an expert, just read it somewhere, search the jet forum for more info).
Bill
#672
My Feedback: (29)
ON, CANADA
RE: Futaba FASST 6
ORIGINAL: BillS
Bill
Bill
If we could get some feedback from Futaba or Bax other than the over used reply of Futaba not being able to guarantee other brand servos with their Rx.
#673
My Feedback: (61)
NJ
RE: Futaba FASST 6
ORIGINAL: dww
ORIGINAL: Gary Arthur
#674
My Feedback: (22)
RE: Futaba FASST 6
I'm sure you guys picked up on this one already
but tower now has a futaba 10c fasst TX for half the price of the 12fg coming out the end of april ( I hope there right this time)
that looks like the one for me
http://www3.towerhobbies.com/cgi-bin...?&I=LXUEW6&P=0
#675
RE: Futaba FASST 6
ORIGINAL: Ron101
Me too. The new 10C looks like a lot of radio for the buck.
Also I'm thinking I am going to go with the new Futaba BLS451 Brushless High-Torque/Speed Servos. I figure if I go all-Futaba all-the-time, I should never have any issues with servos not working with the rcvr.
Regards
JC
