Reload this Page >
Skymaster F14 Tomcat
Old 10-01-2014, 06:10 AM
  #1151
mick15
mick15's Avatar
Yeah that looks about right.
Old 10-01-2014, 06:11 AM
  #1152
WimB
WimB's Avatar
ok, thx Mick, guess I'll have to dig up a long drill then, if I need to go through the 3 ribs.......
Wim
Old 10-01-2014, 06:15 AM
  #1153
mick15
mick15's Avatar
One rib, the second rib already has a hole, which you can see inside the flap servo void.
Old 10-01-2014, 06:21 AM
  #1154
WimB
WimB's Avatar
I know the rib next to the void has a hole, but going from there, I do count 3 ribs, or do I see it wrong?
Old 10-01-2014, 06:27 AM
  #1155
mick15
mick15's Avatar
No but the first one is the flat face of the wing where the carbon rod is, so you will be drilling the face in front of the rod and one rib. Just take a judgement from my picture and drill, you will be ok.
Old 10-01-2014, 06:29 AM
  #1156
WimB
WimB's Avatar
Okay, I'll look into it tonight, fingers crossed, don't want to f***** up my wings, lol.........
Wim
Old 10-01-2014, 06:33 AM
  #1157
mick15
mick15's Avatar
Don't be such a wimp wim, just grab a drill and drill !!!!!!!
Old 10-01-2014, 06:36 AM
  #1158
WimB
WimB's Avatar
hahaha, that's me, lol..........a bit to much of a perfectionist I'm afraid.......
W.
Old 10-01-2014, 06:59 AM
  #1159
FenderBean
FenderBean's Avatar
wim you can use a button valve on the gear doors, use the button valve on one and a normal 2 way on servo slow.
Old 10-01-2014, 08:00 AM
  #1160
muzzgail
muzzgail's Avatar
I just drilled a little behind the main rod in the end. I will put the single lead (XBus) through the slit in the wing mechanism.
ID:	2036527   Click image for larger version
Old 10-01-2014, 10:29 AM
  #1161
WimB
WimB's Avatar
Muzz, is that an optical illusion, or do you have hollow rods in the wing??
Wim
Old 10-01-2014, 04:33 PM
  #1162
muzzgail
muzzgail's Avatar
optical Wim. They are solid sir. Just white paint on the ends from the factory.
Old 10-01-2014, 10:45 PM
  #1163
WimB
WimB's Avatar
Muzz,
ok, I thought so....wouldn't trust a tube there.....
W.
Old 10-02-2014, 01:08 AM
  #1164
muzzgail
muzzgail's Avatar
Time for some photos of stuff.
ID:	2036671   Click image for larger version
ID:	2036672   Click image for larger version
ID:	2036673   Click image for larger version
ID:	2036674   Click image for larger version
ID:	2036675   Click image for larger version
ID:	2036676   Click image for larger version
ID:	2036677   Click image for larger version
ID:	2036679   Click image for larger version
ID:	2036680   Click image for larger version
ID:	2036681   Click image for larger version
ID:	2036682   Click image for larger version
ID:	2036683   Click image for larger version
ID:	2036684   Click image for larger version
ID:	2036685   Click image for larger version
ID:	2036687   Click image for larger version
ID:	2036688   Click image for larger version
ID:	2036689   Click image for larger version
ID:	2036690   Click image for larger version
ID:	2036691   Click image for larger version
ID:	2036692   Click image for larger version
ID:	2036693   Click image for larger version
ID:	2036695   Click image for larger version
ID:	2036696   Click image for larger version
ID:	2036697   Click image for larger version
ID:	2036698   Click image for larger version
ID:	2036699   Click image for larger version
ID:	2036700   Click image for larger version
ID:	2036701   Click image for larger version
ID:	2036703   Click image for larger version
ID:	2036704   Click image for larger version
ID:	2036705   Click image for larger version
ID:	2036706   Click image for larger version
Old 10-02-2014, 04:56 AM
  #1165
FenderBean
FenderBean's Avatar
Is the flap setup with the single pin a solid thing? It seems like it could be a problem area over time? Just wondering, if they have used this with any other SM jets.
Old 10-02-2014, 01:32 PM
  #1166
marquisvns
marquisvns's Avatar
I actually found some play with the flaps with this torque rod setup, so I hysol'd a couple of pieces of thin brass sheets in the slot to close it up and for a better overall action.
Regards,
Barry
Old 10-02-2014, 02:08 PM
  #1167
FenderBean
FenderBean's Avatar
Yeah thats what I was afraid of, I will probably beef mine up as well. I even considered using a typical external rod with a control horn. Well see how once I can get in there and look at it.
Regards,
Barry
Old 10-06-2014, 03:10 AM
  #1168
mick15
mick15's Avatar
Maidened F14 yesterday, all good no problems. No video as yet.
m
Old 10-09-2014, 03:15 AM
  #1169
WimB
WimB's Avatar
Congrats Mike!!! I've started the engines on mine for the firts time yesterday....
Wim
Old 10-09-2014, 08:03 AM
  #1170
FenderBean
FenderBean's Avatar
Can anyone suggest what the kind of torq requirement the jet needs for the spoilers? I am looking to go with a smaller servo just not sure about how much torq the need to function. I was thinking on the slats to use something around the 200+ oz of torque, any thoughts?
Im thinking 300ish for the rudders, the stabs and flaps are going to be the maz I can get .
Old 10-09-2014, 11:07 PM
  #1171
WimB
WimB's Avatar
Fender,
I have JR 8911 all round, and Sävox SH1350 on the slats. I did initially opt for the MG version of that servo, but they were out of stock.
Wim
Old 10-10-2014, 12:16 AM
  #1172
mick15
mick15's Avatar
I have 3421s on the slats (factory recommendation) and MKS 660a+ on everything else.
m
Old 10-10-2014, 06:34 AM
  #1173
FenderBean
FenderBean's Avatar
Thanks for the info, I am going to use the BLS173s on the slats, BLS 172s on the on flaps, BLS177a on stabs and BLS175s on everything else. Im doing a Sbus setup like my F-15, my only beef with futaba right now is the lack of a good 300ish Sbus servo. I think with a single servo running the flaps have a higher torq will be easier on the servo and due to the extreme loads on the servo mounts for the stabs I opted for the metal top half of the servo with the 177s.
Old 10-11-2014, 09:25 AM
  #1174
marquisvns
marquisvns's Avatar
Congrats Mick, did you lower the peak RPM?
Here's my servo count:
Savox SB2231 for the two stabs,
http://www.savoxusa.com/Savox_SB2231...avsb2231sg.htm
SB2270 four in each wing and everything else except air valve I used 1250:
http://www.savoxusa.com/Savox_SB2270...avsb2270sg.htm
Cheers,
Barry
Old 10-11-2014, 02:41 PM
  #1175
DrScoles
My Feedback: (18)
DrScoles's Avatar
Sure like the price on those savox servos. Hung up on sbus though, and if I use the robbe 2018, it's still $40 a pop for the node.
