PST F-84G Build Thread
#502
after long time i done another successful flight with my Thunderjet
https://www.youtube.com/watch?v=9zhIqV5Q0-A
#503
My Feedback: (14)
CO
I finally have cured my problem with the mains not going into the wheel wells. I have robart main gear and added the electric motor from Dreamworks. Now I have six successful flights with the gear totally retracting. It now has 30 total flights. But my nose gear is wearing out and also the tires on the mains. Does anybody have a solution for the nose gear? Did PST ever redesign the nose gear retract? Are they still in business, the emails I have sent them have all bounced back.
Uncle Joe took some great pix of it yesterday
Brian OMeara
Brian OMeara
#504
the rubber tyres are from Sullivan skylite http://www.sullivanproducts.com/WheelsMainFrame.htm
PST work on UAV sector but you can find them on FACEBOOK , they will reply to your ask..
At today no update on F-84G
#506
My Feedback: (30)
F84, My first flight with her
Hey gentlemen, here is my F84 fully finshed and flying, it actually maiden last fall, but my buddy did for me. this video is here second flight and its my first flight on her.
http://youtu.be/pssWYM38jew here is a video of the second flight.
Paul
Paul
#508
Paul
Paul
#509
My Feedback: (30)
Thanks for the info. On the wheels bushings. Should I change it too bearings or by opening the clearance good enought?
i was going to add more take off flap to help take off. What amount of take flaps are you using?
to chmage AOA means I would have to shorten Main gear or length front nose, which is not good as it is already long.
Paul
Paul
#510
Paul
Paul
#512
1/2". I had to custom machine new main struts.
Regarding flaps, the more you deflect them, the more pitch down effect you get, which increases the force required by the elevator to rotate the plane for takeoff.
You need to sort out your AOA problem first before fiddling around with the flaps.
I went through all these problems when I built the 4 Queens. I wrote a 30 page article in RCJI about all the mods and building process in 2008. The article was split in 3 parts over a 6 months period.
#513
Brian OMeara
Brian OMeara
I can compile gcode for Solidworks, Catia or Autocad.
