 Elevons Vs Alerons on F-16's >
View Poll Results: A poll
Elevons Only
32.14%
Alerons and Elevator
37.50%
Flaperons with Elevator
8.93%
Elevon with only Flaps on wing
21.43%
Voters: 56. You may not vote on this poll
Old 12-21-2007 | 12:07 PM
AndyAndrews's Avatar
Default Elevons Vs Alerons on F-16's
Had a problem with My Skymaster alerons and I am now thinking that I should just glue them and use Alevons only. What is the best setup?
Old 12-21-2007 | 12:24 PM
Jim Cattanach's Avatar
Default RE: Elevons Vs Alerons on F-16's
I am using elevons & the ailerons as flaps at only 1/4 inch of travel.
This is on a Jet Legend F16 weighing less than 14lbs & powered by a Wren MW44 with Wren tailpipe.
It flys very well & lands at walking pace.
Old 12-21-2007 | 01:22 PM
ianober's Avatar
My Feedback: (12)
Using just elevons on my TJ 16 and it flys good. Simpler setup, lightweight, less servos.
Old 12-21-2007 | 01:38 PM
My Feedback: (9)
I have elevator and ailerons. Dialed out the flaps. Flys well.
Old 12-21-2007 | 02:05 PM
My Feedback: (16)
What kind of problem did you have? I am curious.
Maddogg
Old 12-21-2007 | 03:17 PM
My Feedback: (9)
I wondered the same thing with Sm's Aileron's.
One thing about the JetLegend's aileron. servo boxes are Micro.
Old 12-21-2007 | 10:13 PM
I've flown both setups on many different F-16's and I've never found any cons to using either setup, the elevons do have one advantage that is worth mentioning and that is at low speed high AOA they provide much more aileron authority. personally out of the many different ones I've flown none have ever needed flaps and if you're removing the ailerons I'd just glue them, when you pull power back and stand the nose up you get all the braking action you want and it's Almost impossible to stall one flaps just aren't worth the weight of the servos IMO.
Old 12-22-2007 | 12:50 AM
FalconWings's Avatar
My Feedback: (57)
Has anyone tried spinning (Flat spinning) without ailerons? Is this possible? You normally require Rudder, Elevator and some opposite aileron to keep the wings flat.
Can you do this on elevons?
Old 12-22-2007 | 12:55 AM
tp777fo's Avatar
My Feedback: (28)
I have an Avonds F15 and 16 both have elevons only and fly great.
Old 12-22-2007 | 07:48 AM
ORIGINAL: FalconWings
other then roockie's with thrust vectoring and the occasional stalled out F-4 I've not seen that many other jets flat spin, it's a bit difficult to recover from with no prop wash or vectored thrust and takes allot more altitude to do so.
Old 12-22-2007 | 12:39 PM
We had try. But it just to stable it won't do that.
Old 12-22-2007 | 12:46 PM
ORIGINAL: KC36330
There is another advantage using elevons. Gusty crossing condition it handle better than ailerons.
Since the wing are fix washout. It kept the plane stable all time.
Superman 2006 we prove it all day long. It was so windy and everyone just sit around.
Dave Presta took the F-16 demo how it do in cross wind. It suprise a lot pilots how will elevons F-16 can do.
Old 12-22-2007 | 03:14 PM
ORIGINAL: maddogg
Maddogg
Regarding your question please check out my post:
http://www.rcuniverse.com/forum/m_48...10/key_/tm.htm
Old 12-23-2007 | 10:47 AM
tony5548's Avatar
I have an skymaster f-16 and yeallow f-16 both have elevons only and fly great. Simpler setup, lightweight, less servos and like small cat for landing.
[link]http://www.rcuniverse.com/forum/m_4562482/tm.htm[/link]
Old 01-27-2008 | 09:59 PM
Guillermo Ibanez's Avatar
Everybody talks about ailerons, flapperons, elevators,etc.
Have anyone tried Ailevators setup in this model?
G. Ibanez
Old 01-27-2008 | 10:07 PM
whaledriver's Avatar
My Feedback: (154)
I tried to set up my TJ F-16 with them but with the Futaba 14MZ setup, you don't have any aileron trim to the Ailevators. Futaba assumes that there are ailerons as well, so the aileron trim is for ailerons only, and elevator trim affects the Ailevators. I'm sure theres a way around it, but I passed.
Old 01-27-2008 | 11:52 PM
jetspud's Avatar
Guillermo
Do you fly jets there in Colombia. I have been to Cali many times. Would be great to visit Barranquilla and see some jet action.
David Elizondo
Old 01-28-2008 | 08:34 AM
Hi David:
Yes, a friend of mine is flying jets in Barranquilla since 2003. He has 3 Bobcats, 1 Kingcat, 1 Rafale, 1 Ultra Bandit, 1 Boomerang, etc. I have flown the Boomerang many times. Now, I decided to get a Skymaster F-16 1:8 and it is almost ready for its maiden flight.
My son started to study in Cali and is in contact to belong to Los Halcones Club with Javier Ospina.
Let me know when you are coming to Colombia.
My mail is: [email protected]
Regards
Guillermo
Old 01-28-2008 | 08:55 AM
Ron S's Avatar
Whaledriver,
with the 14MZ, you certainly do have aileron trim when using elevon setup. If you like, I can PM you later today how to do it, but if you use the Elevon as the wing setup method, it should be ready to go.
