 Chippy Ho Part Deux >
Chippy Ho Part Deux
Chippy Ho Part Deux
Old 12-17-2008 | 12:07 AM
  #76
454
My Feedback: (9)
Default RE: Chippy Ho Part Deux
I thought that was an arf
Old 12-17-2008 | 11:58 AM
  #77
ravill's Avatar
I've never wieghed mine, so I wouldn't be surprised if it weighed 30#.
454, is this your first f-18? They are heavy.
Raf
Old 01-22-2009 | 10:40 PM
  #78
Hello Raf,
Just wanted to ask if you have any pics of your Chippy Ho turbine mount section.
I just received mine today and studying it a bit.
Orlando
Old 10-17-2009 | 12:46 PM
  #79
rctech2k7's Avatar
Hi! Raf,
I saw your F-18C Chippy Ho with smoke and she’s beautiful! Do you have any thread about how you setup the smoke system on your jet? I have F-18C Chippy Ho and I don’t have enough space where to install the smoke tank without affecting the CG. Can I use the outside tanks for that?
John
Old 10-17-2009 | 07:26 PM
  #80
Knock's Avatar
ORIGINAL: ravill
Raf
Come on Raff wake up .....we want more videos ..... flying chippy....install.....smoke...get the camcorder out....where is your tiger scheme ?...get on the ball
Old 10-17-2009 | 07:58 PM
  #81
Knock's Avatar
Just what I thought Raff....no video .....have you even flown the Chippy ho ....or do you just bring it out to the field to let others see it on the ground ?
Old 10-19-2009 | 11:28 AM
  #82
ravill's Avatar
Well,
I sold this jet to Dantley and he painted over my yellow and boy did it get hard to see.
She wieghs 30 pounds dry and still flies like a champ.
Raf
Old 10-20-2009 | 04:26 PM
  #83
dubd's Avatar
Here is Chippy Ho Part 2.5:
This is the Hornet I purchased from Raffy. I gave her a new coat of paint and then threw her in the air. She flies great. Dry weight is 35 lbs.
ID:	1298833   Click image for larger version
ID:	1298834   Click image for larger version
ID:	1298835   Click image for larger version
ID:	1298836   Click image for larger version
Old 10-24-2009 | 06:32 AM
  #84
rctech2k7's Avatar
Impressive photo of a beautiful jet! Looks like a full scale in the air..!
Old 10-26-2009 | 05:40 AM
  #85
MAX NITRO's Avatar
Hi Guy's
I have had mine in a box for nearly 2 years, it is the Xtreme jets Chippy Ho, was in 2 minds wheather to build it or not because I already have the Skymaster F-18F and I want a more sporty jet but giving it another thought.
I have a Jet Central Rhino available to put in it, and I don't like to derate the engine and I like to haul ***** around the sky, is it a bit of an overkill? can I get away with nearly 40lb pushing it around?
