Roo, cg and control throws >
Old 05-26-2003 | 10:45 PM
Default Roo, cg and control throws
I have a ROO that I need cg location and control throws......... if anyone has these numbers , may I have them please....thanks....Perry
Old 05-27-2003 | 01:09 AM
Perry,
CG at front flange screws of main gear. Throws at 25 mm on elevator and aileron. However, dual rate the ailerons for 15 mm as the roll rate is quite high at 25 mm. Do a search for Roo CG and throws and you will find more info. Have fun.
Old 05-27-2003 | 03:01 AM
The instructions say 4" in front of the spar. Mine is 4 3/4, test flight was 5 1/4 in front of the spar.
my ailerons are .6" and the elevator is 1.25" each way.
Greg
