Boomerang Nano!!!
#1076
RE: Boomerang Nano!!!
Nose steering in, tubes glued to the botton sheet hold the wires clear of the leg. Also my std silicon glue on each end of the wire to stop it looping back when retracted.
Also some new Retracts we are offering for the Nano, air up air down and full air support, they come with oleo legs which are not really suitable, but for just over £100 it's does not matter!
Dave
Dave
#1077
ORIGINAL: iflyjets
what about a cockpit or pilot for the nano. any suggestions on size or places to look at?
Ryan
Ryan
http://www.hobbyking.com/hobbyking/s...dProduct=15440
#1078
WI
I ordered one of those t-45 pilots so we will see in a couple weeks from Hong Kong.
Anybody that has used the Eflite retracts , can you post how or where you mounted the front retact. they are setup kinda opposite of springairs so there would be quite a bit of the retract below the fuse/outside.
Thanks Ryan
Thanks Ryan
#1082
Looking good ! Braving the elements today for maiden?
I just poked my meter outside -36 mph! [X(]
it's nice and sunny tho [8D]
#1083
Yep, team M&R are "proper" modellers and hopefully we will test fly two Boomerang models today as one on our early customers has an Elan ready too.
Dw
Dw
#1084
Test flew the Nano today in 10-12mph winds, it feels really good-three good flights with minor expo changes had snaps, knife edge, rolling loops, multiple spins. the P60 is a great combo.
Looking forward to some calmer weather so I can finish trimming it.
I've also set up split rudders so I can angle them out for additional landing drag on flat calm days.
Dw
Dw
#1085
Hi, my Nano sits on its undercarriage with a slight nose down attitude, will this be ok or will it be reluctant to rotate?
thanks in advance
chris
thanks in advance
chris
#1086
Chris
It's bad, if possible extend the nose leg. For grass use (where you get a fair amount of bounce and "kick") you can set the lower fuselage surface flat, but ideally a tiny tail down sit would be better. Some models won't like that as they keep flying and bounce on landing, but the Nano is fine. I have my landing Flap going the full 90 degrees, plus 8mm crow to slow it up. I might get to fly it in the morning as I've been asked to test fly a new CARF prop plane and will probably take the Nano, we might try and get some video too.
Dw
Dw
#1088
i am just about to start the build of my navy boomerang nano. great thread which will help me out loads!. jetcat p60 turbine, going for a cheap build using robart 520 tri spring air retracts, futaba digi servos.
has anone else fitted robart 520 retracts??
#1089
Several people we sold Nano's to also went that way, you will need to do some cutting and trimming around the nose set-up. We will have the Oleo main legs I used that will fit these and other units this week, but not a cheap option. My original Intro has been on wire legs for 3 years without an issue.
We did a video which Colin will post if he managed to catch any model in all the sky camera waving! (note don't buy a video camera without a view finder if you want decent model videos!) I have never seen our field so wet and boggy and the Nano was still off in 35-40m
Dw
Dw
#1090
Heres the video of Dave's Nano shot yesterday. As Dave said he had a very damp patch...
Sit back, turn the sound up and enjoy!
[youtube]http://www.youtube.com/watch?v=xi6AfQQLFXM[/youtube]
#1091
A couple of people have asked about flight time, the video was not the whole flight as Colin was struggling to keep the model in the view finder, this flight was 6 1/2 minutes total with a 50oz Dubro and M&R UAT tank, the main tank ends up with 10mm (3/8") of fuel and a tiny bubble in the UAT.
Dave
Dave
#1092
Flight was long enough with the youtube obsession of adding music!
As I normally do, with model flying videos that contain music, watch the takeoff then fast forward to the landing, music had stopped then so it was the best part
#1093
ORIGINAL: Xairflyer
#1095
Nothing wrong with the song and no good turning it down, as it is the engine/turbine you want to hear, dont know why but for some reason everyone who puts up a video on youtube has to dub it with music, it is a disease of some sort [:'(]
#1097
I moved it forward 1/4" also right from the start, I had flown my friend Trevor Skedge's Nano at Xmas and that told me it wanted to be slightly infront. He tried it on the instruction point and found it a little loose in pitch for our tastes, the tail area is not huge so this makes sense. I'm still finalising expo and movements, this video was flight four and I'm close now. It's a nice flying aeroplane with great slow speed characteristics. I'm going to use it to introduce new people to turbines, there are a few guys in the local club looking and a model like this will suit perfectly.
Dave
Dave
#1098
The Nano legs have arrived! They have 4mm axles and 4 or 5mm pin holes
Dw
Just heard Nano special finishes end of this month too! (UK/Europe)
Dw
#1099
ORIGINAL: Dave Wilshere
I moved it forward 1/4'' also right from the start, I had flown my friend Trevor Skedge's Nano at Xmas and that told me it wanted to be slightly infront. He tried it on the instruction point and found it a little loose in pitch for our tastes, the tail area is not huge so this makes sense. I'm still finalising expo and movements, this video was flight four and I'm close now. It's a nice flying aeroplane with great slow speed characteristics. I'm going to use it to introduce new people to turbines, there are a few guys in the local club looking and a model like this will suit perfectly.
Dave
Dave
It really sticks when it lands, and you can just drop the gear/flap and land from almost anywhere. I take it to the jet meets to fly a bunch of times to get used to the field before flying the larger birds. I do miss my Elan though.. it was a little more graceful..
Im adding lights this winter to it so I can comfortably fly it right up to dusk. I will post pics when done. its a real basic package
#1100
just been doing some building to my nano. mated the wing with fuselage. is it correct that its just epoxied to the wing?, just dosnt seem a strong bond!!, would have though it would be like the sprint which has spigots on the front of the wing that goes into the fuse and screws on rear.
