Another Skymaster Viper
#326
RE: Another Skymaster Viper
ORIGINAL: Selleri
Congrats Hans.
Now I'm getting pretty excited to get mine in that scheme!
Congrats Hans.
Colors turned out better than I hoped for. I didn't know the blue was metallic [8D][8D]
@Ali: Rookie is in the bin, Viper on the table
#327
Niice Hans!!! I started mine on sunday, although I've not had a chance or room for a bench flight like you have Have fun with the build, it looks like Pampa 2010 will be a viper fest !!
Cheers
Duncan
Cheers
Duncan
#329
LoL with just the vipers Ali has sold in the last week, that would break Pampa's rules for the number of models in the air at one time
#330
I have removed the brace at the back of the canopy, and made to "hooks" instead, works perfectly. That enabled me to place the filling couplers for air and fuel behind the backseat.
I also made some reinforcements, particularely the "spine" from the vertical fin (the raised part) is very soft on the sides, that one got some carbon, made a lot of difference. Also the front part of the plane is soft, both the sides and the bottom, carbon there too (not too much to shield 2.4 GHz )
Cables and airtubing has been installed, planning the install of the equipment now (the Weatronic and the valveblock makes a nice and simple install!)
Thrustube for the P200SX ordered, so it's getting close
#331
Murray,
I can give you dimensions with gear up? Do you need gear down height? Surely you can't fit the VJ in your van with the wings on and gear down?? [X(]
cheers
Mark
cheers
Mark
#332
Hi Mark, I am putting a shelf through the van to make two levels, one for planes, one for wings. Gear down measurement would be great.
#333
Murray, the mains are mounted in the wings, so unless you are going to put the viper in the ute with the wings on, you should only need the measurement with the gear up
What alot of people are doing is to make 2 cradles for the fuz. These can be screwed down to the shelf in the van, with bungee's securing the fuz to the cradle.
You can also make the rudder removable, which makes transporting it even easier. It's a simple enough mod which Ali has on his and i'll be doing on mine. I'll post some pics when i get to that bit
Duncan
Duncan
#334
My bad. Didn't think about the wheels in the wings. I will keep the tail on, so that will be the right measurement, Fuse to top of tail height. Thanks for the advice, look forward to seeing the photos Duncan.
#335
Made my tail fin removable. I drilled & tapped the forward carbon rod. 3mm allan screw through the side of the fuz just down from the tail root. I drilled holes either side of the fuz, under the stabs, in line with the clamp bolt & nut for access. It 's a five minute job to remove & fit. Very secure.
#337
Mark,
I saved the photo, thanks. Nice paint job you have there, it's my favourite scheme of all the VJ. I ordered the Ali colours, that being my second choice. It should arrive here soon, it's been 5 weeks since they confirmed my payment and placed the production order. Is that paint scheme on your plane done by Skymaster factory, or did you get that done privately?
#339
HI GUYS
Would appreciate any shots of you turbine fitouts, am on to my finale fitout on my of all the bits and pieces and any would help, This forum has been more than helpfull the viper is sure one great plane,This is only my second jet am currently flying a PST REACTION it also is a pleasure to fly as a trainer not much better,Shall add some shots of my viper fitout.
REGARDS
JOHN
REGARDS
JOHN
#340
Anyone know when the new 2 metre Viperjet will be shipping? It does say end of the year on the website but from experience dates can go either way.
http://www.skymasterjet.com/xviperjet.htm
#341
Can someone post a link for suitable landing lights to fit the viper. Not just the link to the site, but the actual item in the site. The few sites I have found do not give size details, so it is difficult to select the right item for the job.
#342
Hi Jim,
I think thats what your looking for http://shop.optotronix.de/index.php?...JET-2-40m.html
Zack
Zack
#343
ORIGINAL: Jet_Addict
Hi Jim,
Zack
Hi Jim,
Zack
#345
ORIGINAL: muzzgail
Mark,
Mark,
A friend of mine who sprays the McLaren F1 cars sprayed this for me privately.
@Dento, what's the bad news? [&:]
Stig, loving that!!
Cheers,
Mark
#346
ORIGINAL: schroedm
Murray,
Stig, loving that!!
Cheers,
Mark
ORIGINAL: muzzgail
Mark,
Mark,
Stig, loving that!!
Cheers,
Mark
#347
Hi Murray
Here are the pics of the rudder mod, making it removable for travel, it's only a 20 minute job (after the hysol has dried). I first drilled a hole under the stab and in line with the metal clamp which holds the rear carbon rod in place. Then on the inside of the fuz i added a fillet of hysol either side of where the front ali peg sits. Then with the rudder in place and locked by the rear clamp, i drilled a 2.5mm hole in the side of the fuz and through the ali peg. This was then tapped to 3mm and a countersink ground, so the 3mm bolt sits flush with the fuz when in place.
hope that helps
Duncan
hope that helps
Duncan
#349
You must know the right people there Mark. Lovely paint, well done.
Thanks Duncan, I copied the photos into my build folder. It arrives tomorrow!
#350
