Another Skymaster Viper
#1502
RE: Another Skymaster Viper
ORIGINAL: OttoKranz
Very very nice Hans! In HD the video is almost perfect. Perhaps the operator should improve a little bit himself
Ciao
Alessandro
Ciao
Alessandro
Hans
#1503
ORIGINAL: Carsten Groen
Congrats Hans
(PS: Are the ''Barbie'' Rookie flying ?)
Congrats Hans
the Rookie is still flying (a lot actually, some 100 flights since I got it from you ) - but barbie had to go (she almost cost my my club membership )
#1504
ORIGINAL: NightSwan
Hi Carsten,
Congrats Hans
Congrats Hans
No, congrats on the maiden flight. I have about 75 flights on my VJ now and I LOVE IT.
#1505
CG question.
The manual says 220-250 measured from the leading edge at the root.
However, exactly how do you determine where the root of the wing is, due to the sweep at that point.
Can someone please give me advice as to where I should be measuring to.
I would have thought that the leading edge where the wing joins to the fuz, (which is a sharply defined point) would have been better.
Ross
Ross
#1506
My Feedback: (40)
ORIGINAL: zl1wn
CG question.
Ross
CG question.
Ross
Where the wing leading edge joins the fuz is the root. What you have thought to be logical, is!
Craig
#1507
Thanks Craig,
Hmmm I have a problem in that case, I am way too nose heavy. I measure 200mm at that point, so it looks like I will have to reposition
the A123 batteries I am using. Which is a pity as they are nicely packed around the noseleg.
Regards
Ross
Regards
Ross
#1508
ORIGINAL: zl1wn
Thanks Craig,
Regards
Ross
Thanks Craig,
Regards
Ross
TRY 230 -240 Will be about it, So that makes it more N/H
REGARDS
JOHN
#1509
Thanks for the info, unfortunately, it means I have to find another spot for the A123's (four packs), and they looked so nice up along the nose.
The 4 packs are 2 for the Receiver, one for the ECU and one for lights..
Well now to see if they will fit under the front cockpit..
Thanks for the help.
Regards
Ross
ps The weight is 18.7kg empty but ready to go, ie 41lbs.
Is that too heavy or not a problem??
Regards
Ross
#1510
ORIGINAL: zl1wn
Regards
Ross
Regards
Ross
Regarding to CG : I tied a string to the wing-tube and balanced it on the wing-tube as a starting-point. (slight nose-down attitude)
I only needed a few grams of lead. IIRC I needed a few clicks of down, and Koen (who flew after my first flight) needed a bit of down inverted. So I think the CG could move a little further aft, but right on the wing-tube is a good starting-point.
Don't worry about the weight. Mine is a tad over 20kg dry, and it floats forever. I flew around half throttle most of the time. (P200) so I think you will be fine.
Hans
#1512
Hi Nicolo
Thanks. This is a helpfull information even for me.
Just started to built in the aileron- and flapservos.
A lot of space inside even for my BLS155 Servo. Could anyone provide me with some photos how to built them in ?
From my point of view i need a separate wooden plate inside to mount the servos, or i need 75 mm Servoarms
Kind regards
Rainer
Kind regards
Rainer
#1516
NAh they are fine where they are mate lol
coming back from the honeymoon to go the the British Nationals and race pylon
#1518
Hi "Yeti"
Thanks for the Pictures. Now i understand what SM meant with "L-Shape".
Did you have/found enough wood inside the aileron to fix the horns or did you put a lot of glue inside ?
Kind regards
Rainer
Kind regards
Rainer
#1521
Hi All,
Am maidening my Large Skymaster Viper this weekend, and am a bit nervous since we fly at 6300 feet and with the summer heat and the high altitude, the air is thin and planes DONT LIKE TO SLOW DOWN on our 625 foot runway. [sm=idea.gif]
DOES ANYBODY USE CROW??? IF YES, COULD YOU EXPLAIN HOW MUCH, AND WHEN YOU SET IT ON APPROACH????
Thanks in advamce guys!
Shaz
Shaz
#1522
Hi Nico
Thanks for the pictures. There are some nice Ideas how to mount the components.
I hope there is no copyright on how to mount them :-)
Kind regards
Rainer
Kind regards
Rainer
#1523
Hi at all
A little bit surprised while mounting the rudder to the fin.
The drillholes are not alligned to the drillholes in the rudder. After i added some 4mm plywood with 5mm holes to shorten the distance between for the hinge mounting between rudder and fin, i find out the drill holes are not correct alligned. The two middle ones have a deviation of app. 3 mm. Originally the rudder fitted, probably the wide distance between fin and rudder allowed that, but now if have to sand out an oval hole for a correct alignment of the rudder. Hopefully the fixation with 2K glue comes well.
The carbon tube of the rudder is not correct mounted in the middle of the rudder. Deviation of 1.5 mm. At the moment i have no idea how this affect the flight line, because the small metall one in the front of the rudder is exacteley in the middle of the rudder. Correction is not possible, or i have to remove the passtube in the fuselage, remove the carbon tube of the fin and replace everything to correct them.
My youngest boy suprised me with the ultimate servo fixation :-)
Heavy Grade Airplane Aluminium and only 48 grams. For the screws he inserted self locked heli coils into the aluminium to have more resistance for the screws.
This Fixation will placed on a plywood plate in the wings for flaps and aileron. Total additional weight of servo mounting and plywood plate and and stabilizers 59 grams. Not too bad ..., or :-)
The L-Shape Aluminium hasn't had really my certification for high power servos :-). Pictures of the wing mounting will come later on.
Rudder Horns and reinforcements for the landing gear from Sandor arrived today and the complete Illumination of Optotronix too.
Kind regards
Rainer
Kind regards
Rainer
#1524
Hi Shaz
I wouldn't expect really problems with air speed. I would expect problems with the turbine settings, because an altitude of 6300 feet (app. 1920 m) ANDa "flight level" of app. 1000 Feet (300 m) could disturbe the turbine. I would ask the manufacturer of the turbine if you have to adjust some settings for this altitude. Perhaps the fuel pump or something else.
A runway of 625 foot (200 m) should be long enough,... if you use the whole distance and/or your brakes are working well :-)
Kind regards
Rainer
Kind regards
Rainer
#1525
My Feedback: (46)
Shaz I know nothing about the Viper, but I do use crow on my Flash. This is what I do. I have the crow mixed in with my flaps on a mix switch so I can land with or with out crow. I find that in high winds crow turns the Flash in to a kite. So I don’t use it on landings in high winds 20+ MPH. I drop my gear, then flap and crow. Make a lap or two to get the feel of it and the speed right then come in for a normal landing. You will find it will come in a little nose high like your F-15. When you cut the throttle it will sink faster than with out crow so be ready.
You must be standing on a high point at Chatfield. When I fly the elv is about 5400ft. But at 95deg the density alt is about 9500ft...
