 ECU position >
ECU position
ECU position
Old 11-08-2009 | 01:09 PM
Default ECU position
I am fitting out my latest model, a Jet Legend L39. The idea is to be able to start the engine without removing the cockpit, therefore the ECU will be in the engine bay. having installed everything I am now worried that the ECU might suffer if it got too hot. Here is a photo of the installation.
Old 11-08-2009 | 01:20 PM
Default RE: ECU position
Doesn't look like a good spot due to heat. What happens when the engine flames.
Old 11-08-2009 | 01:46 PM
Wayne22's Avatar
Under normal conditions, it looks okay....you could put some ceramic blanket over it if there are concerns from heat
RCISFUN's Avatar
My Feedback: (44)
Very simple fix, make yourself a partition wall out of ply and cover with aluminum tape, or just use thin sheet metal
look at post #203 in this thread
http://www.rcuniverse.com/forum/m_70..._9/key_/tm.htm
Dom used thin sheet metal to make protective covers for his servos...
Old 11-08-2009 | 04:33 PM
gooseF22's Avatar
ORIGINAL: RCISFUN
I would move it a bit forward and over and do what rich says... It will be more in front of the motor. I ran my wren two seasons in a similar setup.. but it was near the intake, not the exhaust.. IF its in the airflow you are ok.
Old 11-08-2009 | 07:52 PM
lov2flyrc's Avatar
My Feedback: (24)
Partition would not be a bad idea.... Or you could use one of [link=http://dreamworksrc.com/catalog/product_info.php?products_id=709]THESE[/link] and mount the ECU outside the engine bay up to 18"!
Old 11-08-2009 | 08:58 PM
SAP_2000's Avatar
Hi.
On my SM L-39, I also wanted to access everything without having to remove the cockpit. The ECU, pump etc is placed in the front, but 1/0 panel, Emcotec BIC, all charging and fuel and air filling are all on the panel in the engine bay.
Works great and no need to open the cockpit.
Old 11-08-2009 | 08:59 PM
kingair41's Avatar
My Feedback: (13)
Here's what I did out of roof flashing. Bent four plates, two for the top half and two for the bottom half of the servos. After each flight I touch them to see how hot they are. Barely feel any heat from the exhaust cone.
