Reload this Page >
Preparing a fuselage for a former - question
Old 11-09-2009, 11:37 AM
marc s
marc s's Avatar
Default Preparing a fuselage for a former - question
Guys currently building a Skygate Hawk and wanted to check something with you pros.
The fuselage is a sandwich construction with a layer of foam (guess nomex or similar) between the outer skin and the glassed inner surface finish - should I just scuff well (120 grit) clean and fit with Aeropoxy or does the foam need removing in the glueing areas to make a good joint?
marcs
Old 11-09-2009, 12:28 PM
ianober
My Feedback: (12)
ianober's Avatar
Default RE: Preparing a fuselage for a former - question
If the foam is sandwiched between layers of glass I would see no reason to remove the foam. Is the inner layer of glass really thin?
Old 11-09-2009, 12:36 PM
marc s
marc s's Avatar
I'm guessing it will be OK fitting it as is with good surface prep, the glass on the surface is of reasonable thickness. Looking at the Stage 1 option from Skygate it looks as if this is how they do so at the factory.
marcs
Old 11-09-2009, 12:53 PM
invertmast
My Feedback: (23)
invertmast's Avatar
I've often seen this with some of the pattern planes.. and have typically just glued it to prepped inner layer of glass. I vaguely remember someone mentioning (on another forum) to drill a few small holes on either side of the bulkhead position thru the inner layer of glass and foam to the outer layers to give the glue some extra "bite" to all 3 layers. Not sure if this was good advice or not, but it made sense to me. i just haven't had a chance to try it..
Old 11-09-2009, 01:00 PM
Gordon Mc
Without some pic's, I'm not sure exactly what you are facing.
Depending on the material, I sometimes just scuff it up a bit ; other times I use a 'Woodpecker" to make a bunch of small holes in the foam to allow for better epoxy penetration.
Woodpecker : http://www3.towerhobbies.com/cgi-bin...P?I=LXHZ26&P=8
Old 11-09-2009, 01:07 PM
schroedm
schroedm's Avatar
Marc, keep things simple and just scuff and aeropoxy. That's how Skygate did mine.
Also, all the bits I glued in like that stuck like s**t to a blanket!!
Cheers
mark
Old 11-09-2009, 01:11 PM
olnico
olnico's Avatar
Marc, as far as I remember, the Skygate Hawk has a vacuumed sandwich. This basically means that the inner layer has been layed up and covered with bidim/peel ply/absorbing falter.
The inner surface shall look slightly grainy. If not you can scuff it lightly with a perma-grit drum/ball passed at slow speed before gluing. In any case do not remove the inner layup.
By the way, the foam is called Airex. Nomex is an aramid honeycomb.
Old 11-09-2009, 01:14 PM
marc s
marc s's Avatar
Thanks Mark, did suspect this was the case but wanted to double check.
marcs
Pics for those who wanted to see.
ID:	1310852   Click image for larger version
Old 11-09-2009, 01:17 PM
olnico
olnico's Avatar
Yes that is Airex, and yes you need to scuff it.
Old 11-09-2009, 01:19 PM
marc s
marc s's Avatar
Cheers all.
marcs
Old 11-09-2009, 01:43 PM
ianober
My Feedback: (12)
ianober's Avatar
I was under the impression that essentially if you use peel ply then the inner surface is ready for bonding, no scuffing necessary Oliver? Isn't the purpose of the peel ply to remove the waxy surface layer that forms when the epoxy cures ?
Old 11-09-2009, 06:47 PM
hooker53
My Feedback: (106)
Marc, Do so scuff it but do not drill it. Drilling that would be the same as preffing it to tear.
Old 11-09-2009, 08:58 PM
SPLIT S
SPLIT S's Avatar
Alcohol wipe, scuff it, alcohol wipe and go....
Dan
Old 11-10-2009, 01:27 AM
olnico
olnico's Avatar
ORIGINAL: ianober
Yes absolutely Ian.
The purpose of the peel ply in the sandwich process is not to remove the waxy surface but to isolate the bidim from the absorbing falter so that you can remove everything when the bonding is completed. The grainy surface is only a consequence of that.
However if you look at the pictures provided by Marc, it looks like the inner layup was laid down by hand ( technical choice ). In that case the inner layup has to be prepared before the gluing process, of course.
Old 11-10-2009, 04:26 PM
hooker53
My Feedback: (106)
Speaking of which you guys, If you have to buy just one or two diff types of hysol, Which (number) one would you get? I have not used any yet but looks like I might as well take the plung!!!
