 Kingtech turbine >
Kingtech turbine
Kingtech turbine
Old 12-16-2009 | 08:49 PM
Default RE: Kingtech turbine
Dear Marty,
Do you know if Feibao jets are better tha Flyeagle jets?
Marcelo
Old 12-16-2009 | 09:45 PM
kingair41's Avatar
My Feedback: (13)
Hi Marcello,
I looked at the FEJ L-39 and asked around on RCU to get some feed back on their L-39's. Then I contacted Mike at Global Jet Club and found that he puts in extra reinforcement in the high stress areas, in the fuse turbine area, in the landing gear mounts ect...... and the price was close to the same. The FEJ from what I was told was on the heavy side for the size, 1/7 scale, thus a higher wing loading. The GJC L-39 is the 1/6 size which is a little bigger and the weight was the same, 21.5lbs-22lbs wet. The gear was another weak area. This was a couple of month's ago so I don't know what has been done to correct these areas since. I am very pleased with the FB L-39 and GJC. Mike has been very helpful when I needed any info. The jet in my opinion is awesome. It's a sleek jet and quick on it's toes. It looks awesome in the air. I would not hesitate to purchase another jet from Mike in the future. Here's a couple more pics of the landing lights on the tip of the tanks and the nose strut. Sorry about the clarity. Cell phone cam.
ID:	1335951   Click image for larger version
ID:	1335952   Click image for larger version
Old 12-16-2009 | 11:27 PM
JET FX's Avatar
[8D]
Old 12-16-2009 | 11:41 PM
JET FX's Avatar
ORIGINAL: Marcelo Assis
Dear Marty,
Marcelo
Hi Marcelo, Iam not sure I would say one is better than the other, both companies offer some very good value products. Bottom line at the end of the day is what a customers finishing and detail expectations might be... I have not seen the FEJ L-39 ''in the flesh'' myself so cannot comment on pro's/con's between these two particular L-39's. Regardless I do like my FB L-39 quite alot and its overall quality and finish actually exceeded my initial expectations and is very good especially based on price. Woody's FB L-39 RCU build thread does offer a great insight into this model...
Any serious modifications are "NOT" generally required with either brands L-39's from any of my understanding. Common sense issues like the obvious generic ARF check lists goes without saying ie double checking all obvious visual glue joints, Loctiting all fittings and probably just a few personal preference hardware upgrades, such as replacing mechanical gear/door valves with electronic units etc.
Cheers- Marty
Old 12-17-2009 | 06:29 AM
Tks Marty.
Please check your e-mail again.
Marcelo
Old 12-22-2009 | 10:01 AM
  #31
tony5548's Avatar
Enjoy nice video from Brazil.
FeiBao Velox + Kingtech K-80E
High speed fly is so cool.:
[youtube]http://www.youtube.com/watch?v=NB0xAQNGBdo[/youtube]
[youtube]http://www.youtube.com/watch?v=5_W158Wni9k&NR=1[/youtube]
Old 12-22-2009 | 03:46 PM
  #32
cyprusjets's Avatar
Nice!!! it seems like the perfect combo i cant wait to see mine in the sky!!
On the first video it seems that his throttle stick was stack in 100% position, Blast!!!
Old 12-29-2009 | 09:26 AM
  #33
Thank you Tony 5548.
Do you also fly jets in Taiwan?
Marcelo
Old 12-30-2009 | 02:14 PM
  #34
Hello;
I am flying with the velox in the video, Velox + k-80e kingtech the perfect combo.
I will set up a BVM Bandit ARF with a kingtech k-80e I believe that will be excellent.
Fernando (Brazil)
Feibao Velox + K-80e Kingtech
Old 12-30-2009 | 04:56 PM
  #35
Eaglepilot2's Avatar
Those of you that have the Kingtech. Is the throttle response as good as the other engines on the market? It appears to be an excellent engine and very good value for the $$.
Old 12-30-2009 | 05:55 PM
  #36
kingair41's Avatar
My Feedback: (13)
I have about 4-5 second delay from idle to full throttle. Takes some getting used to.
Doane
Old 12-30-2009 | 05:58 PM
  #37
The throttle response and very good and fast.
I have 5 flights with Velox + K-80e, the turbine surprises me to each flight, and a show
Old 12-30-2009 | 06:55 PM
  #38
Shok's Avatar
My Feedback: (28)
its about the same as a JetCentral falcon
and faster than a P70
Old 12-30-2009 | 07:12 PM
  #39
PE YOUNG's Avatar
ORIGINAL: eric_monster
Ronnie,
Is there any info on the K-160X yet?
Eric
Mr. Chang Wen-Fu said me.
"K160 is now in production. Next year(2010), in January published data.
and is expected to release in March."
Old 12-30-2009 | 07:28 PM
  #40
JET FX's Avatar
ORIGINAL: Shok
I have flown the Velox with both the P-70 and K80 and also noticed the K80 seems to also carry less residual thrust, I was able slow the Velox down easier when landing. Otherwise the K80 and P-70 are very similar in performance.
As to throttle acceleration/deceleration time the stock factory set parameters seem to be fine for my "pattern" and "scale" style of flying as Iam not really snapping the throttle open and closed so it feels quite linier to my throttle stick movements. I have not felt the need to adjust the factory set Fadec acceleration parameters.
As to blowing plugs, I think this maybe relative to the battery type/capacity being used. Iam running six cell NiCad 7.2V 2400 mAh packs for my K80 systems and have not blown a plug yet. Check with your Kingtech rep if you are blowing plugs and ask about your chosen ecu batteries compatibity with the stock Kingtech Fadec parameter plug heat range settings.
Cheers- Marty
Old 01-03-2010 | 12:23 PM
  #41
tony5548's Avatar
Marcelo
Hi Marcelo
This is my friend and I recently used K-80E engine, flight Video, I hope you'll like.
[youtube]http://www.youtube.com/watch?v=GNScRXZ4LLw[/youtube]
[youtube]http://www.youtube.com/watch?v=KsfjUbEDIeA[/youtube]
[youtube]http://www.youtube.com/watch?v=tBYDNFKo1qI[/youtube]
Old 01-28-2010 | 06:18 AM
  #42
Hi
I have fitted a K80 in my Velox - The K80 ran great on the test stand but now it has been installed I am getting low RPM related flame outs. I did have to extend the RPM and Temp leads. I think it must be related to that. I will relocate the ecu to the wheel well and not use the extensions and see if this sorts out the problem.
Can someone post some pics of their ecu installation on a Velox.
Jack
Old 01-28-2010 | 06:40 AM
  #43
mdeseve's Avatar
i HAVE A QUESTION FOR KINGTECH OWNER, WHEN YOU START IT DIRECTLY ON PROPANE WHAT IS YOUR SET UP, DO YOU USE A RESTRICTOR, DID YOU CHANGE THE GAS SETTING % .
THANKS
MIKE
Old 01-28-2010 | 08:33 AM
  #44
Pics of my velox with K80
ID:	1366358   Click image for larger version
Old 01-28-2010 | 08:56 AM
  #45
lov2flyrc's Avatar
My Feedback: (24)
ORIGINAL: mdeseve
THANKS
MIKE
Mike,
Is the delivery valve your using regulated or pass through? No restrictor needed, gas setting will control gas flow. Let me know what kind of valve and I can give you a good starting range for gas and glow settings.
Old 01-28-2010 | 09:09 AM
  #46
mdeseve's Avatar
Hi Todd, it is the valve i bought from you, the one that directly go on coleman bottle. thanks
mike
Old 01-28-2010 | 12:56 PM
  #47
Thats great thanks ftgti - looking at your pics you must of extended the leads - have you had any problems - I have moved the ecu to the wheel well now and am not using any extentions - i will post some pic soon - How many flights have you done on yours?
Cheers
Jack
Old 01-28-2010 | 01:30 PM
  #48
I have 6 flights in my velox, very good turbine....
Fernando
Old 01-28-2010 | 01:43 PM
  #49
lov2flyrc's Avatar
My Feedback: (24)
ORIGINAL: mdeseve
mike
Mike,
with this valve set wide open, set gas flow to around 60% and glow to around 32 and you should get clean lights every time.
Todd
Old 01-28-2010 | 02:29 PM
  #50
mdeseve's Avatar
Thanks Todd, i will try that.
Mike
