 Sky Master F-16 Conversion and Facelift >
Old 05-11-2010 | 03:13 PM
  #76
k_sonn's Avatar
My Feedback: (32)
Default RE: Sky Master F-16 Conversion and Facelift
ORIGINAL: gunradd
The dynamax wont fit inside and would have even bigger ducting problems.
Hey Kris. This guy just needs to be ignored. He's the kind of guy that walks into a thread and doesn't contribute anything useful. This guy is anti-BVM andjust likes to stir up trouble. Lookat his post history. A real leach who doesn't havethe nads tofigure out how to make a conversion sucessful.He's not really worth the time to respond to.
Old 05-11-2010 | 03:20 PM
  #77
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: pbusa1400
Kirk,
Just for kicks try the spike BV sells for the Sabre arf. By the way the f-16 looks great.
Hey Pablo. Good to hear from you. I do intend to put the spike in the intake. Iadded the intake spikeon my Starfire last year and it made a difference.
I've been comparing videos of the Skymater 1/8th scale F-16 with a P-70 to my video from the weekend and on the straight and levelI am getting the same performance with the EVF but I have more verticle than what I've seen so far.
Kirk
Old 05-11-2010 | 03:44 PM
  #78
AndyAndrews's Avatar
A little off topic but what did you settle on (powertrain wise) for your Starfire? I want to do the same for mine. Its really light and I think perfect for edf.
Can you give me the complete list of items needed for the conversion?
Andy
Old 05-11-2010 | 04:15 PM
  #79
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: AndyAndrews
Andy
Hi Andy,
I ended up using the BVMEVF 5612 fan. I also used the BVM inlet adapter. Its a fiberglass adapter designed to fit the BVM fan in the ducting from the glow fan days. BVM no longer sells the EVF 5612 fan, it has been replacedwith the new EVF-2 fan. The EVF-2 is a few ounces lighter, produces 1/2 pound more thrust, and runs at a lower amp draw.
A list of things needed for the conversion:
- BVMEVF-2 fan (includes motor and controller) it's a true plug-and-play setup.
- BVMInlet adapter
- Batteries Thunder Power 12 cell45C 6400 mAh batteries
- Mylar to make an exhaust tube
Everything else was stock from the kit, including the glow fan ducting. Mine weighed 15 pounds ready to fly with batteries.
If I can help in any other way, please feel free to contact me.
Kirk
Old 05-11-2010 | 05:14 PM
  #80
My Feedback: (41)
earth pounds?? 15-??? 22 awile ago.. lmao...
Old 05-11-2010 | 05:35 PM
  #81
ORIGINAL: k_sonn
Andy
Hi Andy,
I ended up using the BVM EVF 5612 fan. I also used the BVM inlet adapter. Its a fiberglass adapter designed to fit the BVM fan in the ducting from the glow fan days. BVM no longer sells the EVF 5612 fan, it has been replaced with the new EVF-2 fan. The EVF-2 is a few ounces lighter, produces 1/2 pound more thrust, and runs at a lower amp draw.
- BVM EVF-2 fan (includes motor and controller) it's a true plug-and-play setup.
- BVM Inlet adapter
- Batteries Thunder Power 12 cell 45C 6400 mAh batteries
Kirk
has anyone tried to use a SS turbine pipe for a thrust tube?
Old 05-11-2010 | 05:43 PM
  #82
ORIGINAL: RAPPTOR
I think he was talking about the Starfire not the F16.
Old 05-11-2010 | 06:03 PM
  #83
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: k_sonn
Andy
Hi Andy,
- BVMInlet adapter
Kirk
Not to my knowledge but I don't see why it wouldn't work if it met a couple of conditions. First, the front openingwould have to have an open large enough for the fan to slideinto and still get anair tight seal at the back of the fan. Second, the opening at the end would have to be the correct size for the fan. In the case of the EVF, the front openeing that mates with the fan would need to be 4.6 inches (if I am correctly remembeing the diameter of the EVF) and the rear opening would need to be 3.5 inches. Most use mylar because it is very light and fairly easy to get the shape needed.
Old 05-11-2010 | 06:25 PM
  #84
Bob_B's Avatar
We use a rolled mylar sheet for the thrust tube.
Old 05-12-2010 | 08:26 PM
  #85
ORIGINAL: R_Belluomini
I am assuming that BVM sells the mylar correct?
Old 05-13-2010 | 11:03 AM
  #86
k_sonn's Avatar
My Feedback: (32)
BVM does sell precutmylar exhaust tubes for their jets. You could get the one for the electra. You'd have to cut off some of the length and overlap it in such a way that the rear of the opening is 3.5 inches.
Or, you could get a roll of mylar from Taps Plastic and make your own. http://www.tapplastics.com/shop/product.php?pid=255
Kirk
Old 05-13-2010 | 01:28 PM
  #87
BVM custom cut one for Gunrad when he installed the EVF in his Byron F-16, so they could probably custom one for any jet if you give them the dimentions.
Old 05-13-2010 | 03:06 PM
  #88
k_sonn's Avatar
My Feedback: (32)
ORIGINAL: skyhawknut
Thanks Mark. That's good to know. Are you planning to attend Jets Over Whidbey this year? It would be great to have another electron consumer at the event.
Kirk
Old 05-20-2010 | 03:26 PM
  #89
k_sonn's Avatar
My Feedback: (32)
This conversion was a proof of concept and I am happy with the level of performance of the BVM EVF in a 22 pound airframe after fixing just one of the three intake ducting issues.  This airframe is 5 years old, has had three different power plants (P-70, TJ100, EVF 5612), and has had move damage repaired twice.  The turbine intake ducting was replaced with the ducting for the TJ100, which has also been replaced with 120mm intake ducting and the airplane has been repainted.  Because all of this has added weight and the newest version of the airframe is lighter out of the box than the version I have (when it came out of the box), I have decided to purchase a new airframe.  When the new airframe arrives, I'll continue on where I left off.
Kirk
Old 05-20-2010 | 06:18 PM
  #90
Kirk - I really like the paint job on this one - you going to do it again on the new one?
I'm going to try to make it to Whidbey this year..........You mean your wife is going to let you go play with toys on the other side of the country???!!!
Old 05-21-2010 | 10:25 AM
  #91
k_sonn's Avatar
My Feedback: (32)
Hi Mark - Yes, I will most likely do the same scheme on the new one.
Cool. Whidbey is a great place to fly. Jets Over Whidbey is a great event to attend. It is truely a pilot's event with no vendors or sponsors. The wife doesn't mind if I go off to events across the country, but in this case I'm already in the Pacific Northwest. I returned for another contract.
Kirk
Old 05-21-2010 | 10:48 AM
  #92
NickC5FE's Avatar
My Feedback: (31)
Kirk-NOW THAT IS AN AWESOME SCHEME!!
Old 05-21-2010 | 12:17 PM
  #93
k_sonn's Avatar
My Feedback: (32)
Thanks Nick.
