Tomahawk-Design Bae Hawk 1: 3.5
#751
RE: Tomahawk-Design Bae Hawk 1: 3.5
a guy told me, when the skygate hawk was new, before it was named skygate, the used 3 liters og kerosine in the nose to keep it balanced, so maybe in the older days it was tail heavy? - and today with herex sandwich, they just keep the old well known system?
I was there when Volker test flew his production Hawk in Hungary (a few days before the JWM 2005). The only upgrade to the original model since that time was the vertical stab and empennage as the model suffered some flutter.
Best BAE Hawk Mk66 ever, in my opinion, that's why I have TWO.
Darryl
#752
Darryl,
I remember watching that flutter and landing and wondering a) how the fin stayed on and b) how a model that big could land at that angle of attack so slowly without damage!!
Awesome model
Awesome model
#753
ORIGINAL: darryltarr
Hi Kasper, Not TRUE at all.
Darryl
Darryl
#754
Guys i am thinking to use the new jetcat P300 in the Hawk.
Not to get more speedy, but to have more vertical performance... i saw the video of Victor Cavo using 2 - p160 ...
what do you guys think about?
#756
as i see it, theres no use anymore for the P200, the p300 is about the same size, and weight.
its funny with the jetcat engines..
p20rx, p60se, p80se, p90rxi, p100rx, 140rx, 180rx, 200sx, p300RX and the P400RX
those i have marked with red shouldent be in production today... WHY should you ever want a P140rx???
#759
Hi Kasper,
I agree with you 100%.
For Models that require 7 to 9 KG Thrust I would use the JetCat P-100RX
For Models that require 10 to 12 KG Thrust I would use the BF Turbine (B100F which produces 127 Newtons)
For Models that require 13 to 16 KG Thrust I would use the Behotec 180 Gold
For Models that require 17 to 20 KG Thrust I would use the Behotec 220
For Models that require 20+ KG Thrust I would use the B300F or the JetCat P-300RX
#761
I have small hitec flat wing servo just behind wood frame that holds nose retract. I have a pushrod on that servo that runs parallel to wood frame for the nose gear. I cut hole thru wood and pushrod attached to control horn which is part of hinge that holds the small nose gear door. I would take picture but airplane currently in process of being painted
#763
Is neutral stabilator (for level flight) when leading edge of stab is in line with the seam where rear hatch meets fuse? Thanks
#768
My Feedback: (48)
Finally! 1 year and 3 months!!
I thought for sure this one would come out nose heavy because the nose is longer and I even added carbon in nose section. right on the money or slightly tail heavy. Its right on 330 right now.
54.8lbs
P200SX
Down and Locked Retracts
Marc Scully GBR Electric Brakes
GBR UAT
GBR formers
Jettech 6.2 L fuel tank with baffle
powerbox smoke system with OLD School Skygate small fuel tank as smoke tank
Schroeders plugs for fins and scale parts
Ralle Tailormade Decals, mask, dry transfers, and siupplied Dupont Paint
Custom hatch
Test flights any day now
Scott
54.8lbs
P200SX
GBR UAT
GBR formers
Custom hatch
Scott
#773
My Feedback: (48)
Thanks Marc!
Brakes working good!
Scott
https://www.youtube.com/watch?featur...&v=wH92BXNdPdM
http://youtu.be/wH92BXNdPdM
Scott
