Reload this Page >
Tomahawk-Design Bae Hawk 1: 3.5
Old 05-06-2014, 06:26 AM
  #1001
marc s
marc s's Avatar
There are a few options, two companies Maffs and Axel make pilots, Maffs up to 1:3.5 scale (I believe) and Axel up to 1:2 scale.
Maffs are cheaper and good overall, Axel pilots are very expensive but are incredible, I think you can add accessories like a Rolex watch etc ;-)
Maffs:
http://www.maffscav.de
Axel:
http://www.axels-scale-pilots.de
Couple of Axel pilots from their site gallery....
marcs
ID:	1992973   Click image for larger version
Old 05-10-2014, 10:42 AM
  #1002
roydefiant
Did a design for fuel cell support platform with interlocking tabs. Had a local company do the drawing for laser cutting then glued together with a removable dragon plate top section. Lower section has wide base for plenty of contact area. Tank will have 3M heavy duty interlocking Velcro to secure tank to Dragon plateso it cannot slide and then there are 3 slots in the fuel tank support for Velcro straps to wrap around top of the jettech 6 liter fuel cell. Inside of the structure I have some 90 degree carbon fiber angle glued in at key areas. The support frame is so strong I can stand on it. It drops in like a glove.
I can fit CAT and fuel pump underneath, keep center of gravity low and partially block inlets as there have been complaints about too much air keeping gear doors open.
Old 05-10-2014, 10:48 AM
  #1003
roydefiant
more pics
ID:	1994156   Click image for larger version
ID:	1994157   Click image for larger version
Old 05-17-2014, 02:52 PM
  #1004
hunty
Is it possible to get the file so I could install the same into mine? Your assistance would be fantastic [email protected]
Old 06-02-2014, 06:38 PM
  #1005
roydefiant
Getting ready to fly my tomahawk hawk soon. Am doing radio setup. Wondering if there are pitch changes with flaps down and whether I need to mix in any changes in stab trim?
Roy
Old 06-05-2014, 09:30 AM
  #1006
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Does anyone have a FULL bypass kit for the tomahawk, I have acquired one that is already built but it is using the stock setup with the stock tank, I would like to get a larger tank and also possibly a smoke tank as well. A Full Bypass would be great to solve the gear door issues.
Old 06-06-2014, 02:04 AM
  #1007
schroedm
schroedm's Avatar
Disco,
Full bypass system doesn't exist.
Re the door issue, simply block about 60-70% of the inlet ducts and your door issue should go away. It was proven to be a fuselage internal pressure issue that this solved. Still plenty of air for the turbine.
Old 06-12-2014, 06:44 PM
  #1008
roydefiant
Big air leak from nose air cylinder at pen tip. Any fix for this or need new air cylinder from tomahawk?
Old 06-13-2014, 06:34 AM
  #1009
Inconel
why did you not open it and check the inside ?
Old 06-13-2014, 08:14 AM
  #1010
Mike Haddox
Disco, If you find another one for sale let me know. Mike
Old 06-13-2014, 10:46 AM
  #1011
jetpilot
My Feedback: (48)
jetpilot's Avatar
Roy,
Open up and change the O-ring. I had to do the same thing. the O-ring seemed like wrong size.
Scott
Old 06-13-2014, 12:25 PM
  #1012
roydefiant
Turbo Diddi sent me instructions. The O ring had popped out. Took cylinder apart, reseated O ring and relubed/ All working well now with no leaks in underwater test
Old 06-23-2014, 05:56 AM
  #1013
Blancr
I'm trying to decide whether I should attempt to keep the weight of this aeroplane on or below 44ib or whether I shouldn't even try and go straight for an LMA registration.
Thanks for any thoughts
Bob
Old 07-22-2014, 06:08 PM
  #1014
j.c.a.
Originally Posted by Carsten Groen
Jay,
I can fit my THawk in my Audi A6 (stationcar), and that is even with the wings in the frame that Tomahawk sells for the wings! The nose can be removed with 6 screws (M4). I have made a very long hex driver that can reach the top 2 screws from the two air scoops on the top of the fuse. The bottom 2 screws I can reach from the wheel openings and the 2 screws in the middle also from the wheel openings (reaching up besides the inlets). Assembling/disassembling the two fuse parts takes max 3 to 5 minutes once you have done it a few times.
Hi Carsten would you please post a picture of the wing frame that Tomahawk sells for the Hawk.
Thanks in advance
J.C.
Old 07-24-2014, 12:02 AM
  #1015
Carsten Groen
Carsten Groen's Avatar
Hi JC,
I took some pictures yesterday of my frame. When packing this bird in my Audi A6 the seat next to the driver is also free
Name:	2014-07-23 15.23.24.jpg
ID:	2017040   Click image for larger version
Name:	2014-07-23 15.23.29.jpg
ID:	2017041   Click image for larger version
Name:	2014-07-23 15.23.32.jpg
ID:	2017042   Click image for larger version
Name:	2014-07-23 15.23.42.jpg
ID:	2017043   Click image for larger version
Name:	2014-07-23 15.46.27.jpg
ID:	2017044   Click image for larger version
Name:	2014-07-23 19.15.30.jpg
ID:	2017045   Click image for larger version
Name:	2014-07-23 19.15.33.jpg
ID:	2017046   Click image for larger version
Name:	2014-07-23 19.15.39.jpg
Old 07-24-2014, 12:47 AM
  #1016
schroedm
schroedm's Avatar
Bob
I wouldn't bother for 2 reasons. Firstly, unless you asked Thomas for a WJM lightweight kit you will find it nearly impossible to hit 44lbs. Secondly, 44lb is too light for this model. It may be 'fun' to fly but just looks wrong. Aim to be around 25kg dry minimum I'd say......
Cheers,
Mark
Old 07-24-2014, 12:48 AM
  #1017
schroedm
schroedm's Avatar
Hi JC,
Are you good at Tetris too mate? LOL
How long does it take you to go from opening the boot to ready to fly??
Old 07-24-2014, 12:54 AM
  #1018
Blancr
Mark - thanks for that - will save a lot of grief!
Bob
Old 07-24-2014, 12:57 AM
  #1019
Carsten Groen
The biggest hazzle is attaching the nose to the rest of the fuselage. I guess from opening the car to assembled plane is around 20 minutes. I have made a very long hex driver for the two topmost screws, these I can get to thru the large inlets on the top of the fuse
Old 07-24-2014, 01:08 AM
  #1020
schroedm
schroedm's Avatar
Originally Posted by Blancr
Mark - thanks for that - will save a lot of grief! Bob
Have you ordered/received it yet? If you're looking to avoid the CAA/LMA the C-ARF Skygate Hawk can come in under 20kg
Old 07-24-2014, 01:18 AM
  #1021
Blancr
Mark - No haven't ordered yet but will in the next week or two. That's a good thought - but I can't get past wanting the Tomahawk! It will be a good experience. The examiners seem like a great bunch of people and a lot of experience to impart - so can't be a bad thing.
Bob
Old 07-24-2014, 04:24 PM
  #1022
j.c.a.
Hi JC,
Thanks for the pics Carsten
J.C.
Old 07-25-2014, 12:40 AM
  #1023
Karsten022
Hello Carsten,
will we see the nice plane in Holstebro? Looking Forward to see it.
Best regards to Sunday
Karsten
Old 07-25-2014, 01:34 AM
  #1024
Carsten Groen
Hello Karsten,
unfortunately no, I have already 5 jets packed for the trip
See you in a couple of days!
(PS: campfire has been prepared, 3 cubic meter wood is on site also http://www.jetdanmark.dk/e107_plugin...c.php?19393.20 )
Old 07-27-2014, 06:12 AM
  #1025
Blancr
Mark - having given your idea some further thought the Carf Skygate Hawk is going to be a better route for me so thanks a lot for the thought!
Bob
