 EV5U setup? >
EV5U setup?
EV5U setup?
Old 05-13-2010 | 06:34 PM
Selleri's Avatar
Default EV5U setup?
I tried mine for the first time today and I'm a bit puzzled.
Settings are:
Brakes proport.
Mode 1
Gear (reverse), time 2.0
Door (normal), time 6.0
When I turn on the radio the valve tries to close the doors and then opens them back again, when I retract the gear it closes the door first then the gear.
When I connect the programmer to the unit I get a steady blue, it doesn't appear to blink.
Any idea what I might be missing in the setup?
Old 05-13-2010 | 08:55 PM
Default RE: EV5U setup?
Sverrir - can you try a quick test ... change the gear setting to NOT be reversed, and simply achieve your reversal by switching which airline you plug in to which port.
I seem to recall having all sorts of problems like this on my Jag initially, and IIRC it was that the unit does not properly handle gear reversal - gets confused about the start state, or something like that.
If that doesn't solve it, I will go hunting for the instructions that I wrote down while I was figuring the system out.
Gordon
Old 05-13-2010 | 08:58 PM
Selleri's Avatar
Cheers, I'll try that Gordon, either tomorrow or sunday, and report back.
Old 05-13-2010 | 09:35 PM
Selleri, The door up and door down label on the EV5U is backwards. Change these air lines and I bet yours will work just fine.
thanks
Old 05-16-2010 | 11:14 AM
Selleri's Avatar
Put the gear back to normal on the valve, reversed it in the Tx, crossed the up/down lines for the doors and it works, good enough for me!
Old 05-16-2010 | 05:33 PM
Good news !
Old 06-29-2011 | 12:34 PM
My Feedback: (12)
I'm trying to figure out how to program this valve with the card. It's written in german/ english. I want simply to have function gear up & doors close later in flight doors open (stay open) and gear down. Also program brake function program. Thanks much.
Old 06-29-2011 | 03:30 PM
3DHELINUT's Avatar
ORIGINAL: Jjet
1. What you need to do is first plug a battery into the programing card, each time you make a selection a led will stay lit when you hit enter
2. press the enter button till you are in the mode selection section and select mode 1
3. press the enter button now set the function to gear
4. press the enter button and set v1
5. press enter and set valve to nor/on
6. press enter and use the arrow keys to set your delay (3 to 5 seconds has always worked)
7. plug you ev5u into the programming card and a blue light will start to blink 5 times indicating that you have a connection and it has completed uploading your perameters.
you are now done and can test the valve.
Alan
