RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   spark ignition for turbines (https://www.rcuniverse.com/forum/rc-jets-120/8677488-spark-ignition-turbines.html)
SpiderJets 04-29-2009 02:31 AM
RE: spark ignition for turbines
I remember using spark ignition on JPX turbines drove the 35 MHz FM RX nuts. Same with your system, or did you test it with 2.4 Ghz ?
It was rather dangerous as it also drove the servos beyond the mechanical limits of both the gears and the surfaces+links.
I had to switch off the RX as long as I had the spark ignition button pushed in, and moved the throttle servo by hand.
Personally, I do not see the big advantage of a probably rather expensive and "heavy" system over replacing a cheap and light glow plug every now and then...?
Forgues Research 04-29-2009 08:16 AM
ORIGINAL: SpiderJets
I keep repeating, there has been no problems whatsoever , not with the starting or with regular operations.
The system is not that expensive and quite light.
I am using 72 mhz.
Roger
Forgues Research 06-02-2009 11:00 PM
Just to let you know , we are now shipping the spark ignitions for propane start turbines.
Our new price is $89.95 plus S&H
This includes the ignition module, 1/4*32 spark plug, Y harness, and everything else you need for a plug and play.
Regards
Roger <span class="info"> </span>
Forgues Research 06-20-2009 08:46 AM
1 Attachment(s)
Just to put everyone at ease, Ihave now about 10 flights with the turbo prop laser using exclusively the spark ignition you see here.
Roger
i3dm 06-21-2009 05:50 AM
Looks great Roger ! cant wait to test one myself.
rolsen12 06-21-2009 06:53 AM
My first turbine had spark ign.
It was a Tubomin.
Nothing new.
Forgues Research 06-21-2009 07:56 AM
ORIGINAL: rolsen12
It was a Tubomin.
Nothing new.
What's you're point???
Roger
AFTERBURNER1 06-21-2009 10:28 AM
ORIGINAL: rolsen12
It was a Tubomin.
Nothing new.
http://www.rcuniverse.com/forum/js/f.../sad_smile.gifhttp://www.rcuniverse.com/forum/js/f.../msn/47_47.gif
Niels30 06-22-2009 01:07 PM
Hello, I would like to reccomendForgues, becourse I did order ignistions for my turbines and Roger deliverd quickand ferry good stuff.
He also is attentively when it comes on payingto mutch. The products are verry good!!!! No problems with the acu.
Greetings Niels.
