Official HPI MT2 Thread
#3776
RE: Official HPI MT2 Thread
ORIGINAL: thestratcat
I work as a dispatcher for a trucking company... I've already had the truck out in the yard for two tanks of fuel this morning running around
ORIGINAL: friday13
What is it you do at work? Your position?
this morning included more torture tests from me on the way to work. I took the truck to the local state park and ran it... this thing is crazy fun!!! snow hills were nothing, I spent most of the time airborne over drifts... very cool!!!
(now it's killing me to see the truck sitting beside my desk, sounds like it's time for an early lunch!!! )
There was one time I was waiting for a client to have a meeting and by chance had my truck in the trunk - so I ran it for about 10-15 mins. just in time before he arrived. LOL
#3777
This cold weather we are having can damage your motor. Tough it out and wait for good weather. I strongly advise you on this. I havn't ran my RC's in a month. Just give it time. It's cold up here.
It looks like this Saturday it'll be +7 degrees and we'll be in the plus temp. till mid next week. Keep an eye out on the weather forecast.
#3778
My Feedback: (12)
IL
ORIGINAL: friday13
Right on! You're hooked like I am to RC! I look for any opportunity to run.
ORIGINAL: friday13
#3779
I'm thinking about going out and having another run, but I'm feeling kinda guilty, I've got all the guys working and have pretty much bullied them all week and I'm out screwing off.. oh well..
ORIGINAL: friday13
ORIGINAL: friday13
#3781
daggummit!!! I'm screwed... I left the stupid radio on under my desk and the batteries are toast!! OUCH!!!!
#3782
My Feedback: (18)
TN
ORIGINAL: friday13
Nice workstation.
I think I like your old one better. It has more character. Did your old one have more room? Looks like it.
Nice workstation.
#3783
the .18TZ is fast but not as wicked as my .21rg. the previous owner kept blowing diffs with it, but on closer inspection i found the flaw causing it. Operator head space and timing was off and he missed putting the shims in to set the gears closer. all is good now, runs better than ever.
#3786
CA
I went for a Christmas BASH, ( Get it ![>:]) And My Throttle Servo wouldn't respond. [:@] It would just sit there clicking neutral to Brake position than repeated. Once in a while I'll get control of it, But than it goes back to "neutral to Brake" routine. I just recharged my receiver pack! It's hecka cloudy (LITE Sprinkle). And I never had this happend to me before. My steering Servo works find. I wonder if it was the fail safe, it got wet or something? The weather? Interference?[]
Yours Newbie,
[8D]
Yours Newbie,
[8D]
#3789
Guys right i brought a HPI mT2 bout 2 months ago and it went outta range and i hit a doggy bin resulting in a snapped front arm so it been on my desk for this long because my hobbie shops have shut down in the area 2 questions. 1. will it be fine startin and running it agen it will start for def ? 2. i have orderd a venom fail safe but how do you install them could someone please help me ?????
many thanks Blowerz
many thanks Blowerz
#3790
ON, CANADA
it just plugs between your battery pack and the recieverv it should come with the instruction anyway if your not sure.
ORIGINAL: Blowerz
many thanks Blowerz
many thanks Blowerz
#3791
ON, CANADA
check your screw on top that hold linkage may be loose that happened to me when i tighten up the screw on top it was fine afterwords
ORIGINAL: MT 2 in Ca.
Yours Newbie,
[8D]
Yours Newbie,
[8D]
#3792
Aww excellent and my other question the car should start pretty well still after few tries ??? so venom fail safe pretty easy fit no snippin of wires and joinin together ??? hopefully explains all in booklet
im not the cleverest guy in the world im only 17 so just wonderd coz i read on the venom site and i didnt get much of it :P
#3793
ON, CANADA
IT SHOULD START EASY IF YOU,VE TUNED EVERYTHING RIGHT ,I AM NEW MYSELF,i,ve learned some by trial and error ,the jacks may fit and be compatable but i am not sure ,i am just using a spring on the throttle arm to pull it back when transmitter looses signal or something else goes wrong
ORIGINAL: Blowerz
#3794
yer i have a spring on the throttle to but just wonderd how u linked it up so it cuts the engine out when it loses range but ill fiqure it out and yer if it dont start ill turn the high speed needle to get it started. because i only just done the run in then it broke so gotta get it going then tune it proper then i be as happy as larry
#3795
ON, CANADA
there is know garanty that the spring will do the job ,just figured it would pull servoe back to nutral if signal is lost bad advice on my part sorry .found out this mornin that the spring i have doesn,t pull it back when transmitter looses signal, i better get a failsafe to my truck went wild glad i was surrounded by snow mounds.
ORIGINAL: Blowerz
#3797
QC, CANADA
I had a Ofna fail safe to begin with but had allot of problem with it, since than I've replace it with a Venom one and its doing a good job never a problem, I like the set up screw you can adjust it were you want. [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHUH6&P=ML[/link]
#3798
ON, CANADA
THANKS and_des need one now that i know the spring doesnt work.
ORIGINAL: and_des
#3799
yer a fail safe is what im gonna get but can any1 help me because i can buy one but how to fit it all like the tempreture loop just goes round the engine but how do you set it up so it cuts out when you lose signal ?? ?? ??PLEASE HELP ME then ill be well away and can drive everywhere without worryin it go outta range
