RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Which Engine?
Old 10-30-2004 | 08:40 PM
Default Which Engine?
i need a engine for my nitro evader. the stock .18 has gone bad and i need a new one that will fit. what ones do you think are good that will fit the evader? my price range is less than 100$
Old 10-30-2004 | 08:43 PM
Default RE: Which Engine?
Well I'd rebuild it instead of getting a new engine. There aren't many "good" engines under that price. This is the only engine that is really under $100 http://www2.towerhobbies.com/cgi-bin...?&I=LXFDJ3&P=0 but I wouldnt spend the money to get it.
Old 10-30-2004 | 08:47 PM
i see that your signature says your a engine rebuilder and you think i should rebuild my engine. does that just mean buy a new piston and sleeve?
Old 10-30-2004 | 09:06 PM
I have faith you can do it on your own, in fact, I will get you the part numbers...
Piston/Sleeve: LXCLV8 PRICE: 30.99
Head Gasket: LXCLW2 PRICE: 1.79
Pretty cheap to revive the engine if you like it .
Old 10-30-2004 | 09:39 PM
thanks alot rccars. i'll post pictures of the sleeve in a few.
Old 10-30-2004 | 09:40 PM
alrighty dude... i'll be here.
Old 10-30-2004 | 10:15 PM
heres some pictures of the sleeve: i tryed to get some pictures of this yellowish spot inside the sleeve. could this be the worn out part?
Old 10-30-2004 | 10:26 PM
That yellow spot could either be a castor oil build up, or rust... I'd say if you like that engine, perform an engine rebuild. If I started buying, rebuilding engines and sold them... would u guys consider it at all? I have always wondered, its an idea at the moment. I know this guy who wants to sell me TRX Pro .15s by the dozen that all need rebuilds.
Old 10-30-2004 | 10:33 PM
so what would i need to buy to rebuild the engine? you should rebuild engines.
rccars, do you have AIM or MSN?
Old 10-30-2004 | 10:34 PM
all u need is the piston/sleeve and a head gasket. I should buy/rebuild/sell the engines... it would be cheaper than buying a new one... I'll ponder that idea.
Old 10-30-2004 | 10:36 PM
would rebuilding it garentee it to run and start correctly again?
Old 10-30-2004 | 10:39 PM
yeah, it would be like a new one... if u did it right.
Old 10-30-2004 | 10:42 PM
ok. im goin to head out to my hobby shop tomorrow and see if they have the right parts. if not, i'll get them from tower. thanks alot rccars.
how would i not do it right?
Old 10-30-2004 | 10:44 PM
some people are goofs... its impossible with common sense
Old 10-30-2004 | 10:46 PM
aha! i have common sense. so i think i could do it right. i just gotta make sure to line up the exost holes though.
Old 10-30-2004 | 10:52 PM
well if u dont have confidense, I'd do it but I'd only charge you 10 bucks for a rebuild instead of 20 so u can get an idea of how "good" i am. I can get u a rebuild guide if u want one.
Old 10-30-2004 | 10:57 PM
a rebuild guide??
dont you just put the piston in and sleeve in then gasket in?
Old 10-30-2004 | 10:58 PM
yeah, that and clean it up really good. If u lose those g clips, they are extremely hard to find though lol.
Old 10-30-2004 | 11:09 PM
Frost_'s Avatar
That almost gold appearance isn't rust or buildup.... It's the inner coating (don't know it's chrome or not on this model) that is WORN AWAY... The gold is the brass part of the sleeve. With that big a patch I'd wager that for your last quart or so you were having real problems with heat and it cutting off.... not to mention being impossible to tune.
Old 10-30-2004 | 11:13 PM
lol, forgot about that... thats extreme wear if u got down past the nickel/chrome plating.
Old 10-30-2004 | 11:16 PM
so my sleeve is EXTREMLY WORN?
Old 10-30-2004 | 11:20 PM
ORIGINAL: Frost_
yeah, my truck would always get too hot and stall. and i would have to tune it alot.
Old 10-30-2004 | 11:25 PM
sure sign of a rebuild well needed
Old 10-30-2004 | 11:28 PM
ok. then i'll go to my LHS and get the parts and see if i can put it together. what should i clean the engine with?
Old 10-30-2004 | 11:30 PM
hmm... sometimes paper towels is all it takes.
