RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
filter oil?
Old 11-03-2004 | 11:49 PM
aero528's Avatar
My Feedback: (9)
Default filter oil?
is wd-40 ok to use for filter oil on a xxxnt stock air filter? thanks!
Old 11-04-2004 | 03:40 AM
Default RE: filter oil?
my guess would be no, but ive never really tried it, a motor oil works though i think (correct me if wrong guys).
Old 11-04-2004 | 04:02 AM
ive heard of people using WD-40, but ive also heard it doesnt do a good job at keeping fine particles out... i would definatly stick with a regular filter oil... why bother with anything else...its 3 or 4 dollars and your engine is at least 100, so i would just get it.
Old 11-04-2004 | 09:12 AM
WD40 is great stuff but it has solvents in it so I would not use it for the air filter, go to the local motorcycle shop and pick up a can of air filter oil, I use dish soap to clean the filter let dry completely if you have 3 or 4 foams put them in a baggy with some oil and squeeze them together with the oil in the bag. Make sure that you remove the extra oil from the filter, RED
Old 11-04-2004 | 09:14 AM
RC_Tobias's Avatar
aero-
I would not use WD-40 as a substitute for air filter oil. As snowball said it's only a few bucks and it's designed to make sure nothing gets through the filter except air. I however have used WD-40 before as a sub for after-run oil......but that's when I was in a pinch and didn't have any after-run on hand.
-RCT
Old 11-04-2004 | 03:55 PM
aero528's Avatar
My Feedback: (9)
yeah, i was just wondering, thanks! i looked on tower hobbies and some of the motor saver filters said that you could use wd-40. could i use after run? when ever i go out to my lhs next i will buy some filter oil, but will after run work? thanks!
Old 11-04-2004 | 04:07 PM
Go to a motocross shop (dirtbikes) and pick up some foam air filter oil in a spray can. I have this 2 foot tall bottle I picked up for 7 bucks. It will last for the life of 2 rebuilds (or so i estimate at my rate.)
Old 11-04-2004 | 04:33 PM
aero528's Avatar
My Feedback: (9)
ok i will if i can find a shop like that somewhere. so does anybody knwo if after runn will work? im just wondering. thanks.
Old 11-04-2004 | 06:07 PM
aero528's Avatar
My Feedback: (9)
i called my lhs and they said that i could use juist about any synthetic oil, so i am going to use my after run oil. thanks for your help guys!
Old 11-04-2004 | 07:11 PM
Nitro Rustler Racer's Avatar
ya, never ever use wd-40, because the air filter oil is sticky and wd-40 isnt
Old 11-04-2004 | 08:30 PM
i use mineral oil and haven't had a problem yet i use it as after run oil too
Old 11-04-2004 | 09:14 PM
i am just going to stick with the sticky stuff from TEAM ASSOCIATED AIR FILTER OIL
Old 11-04-2004 | 10:21 PM
The problem with WD-40 is that it evaporates from the filter.
Old 11-05-2004 | 01:40 PM
My Feedback: (16)
i use 3 in 1 oil works great.
Old 11-05-2004 | 03:20 PM
Go get some cheap synthetic oil, I completely forgot that you can use some of that. get a quart of Valvoline synthetic or Pennzoil... they are both low priced and they should get the job done [:-]
