Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
 servo saver question and fail safe question >
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 02-13-2005 | 09:23 PM
Default servo saver question and fail safe question
what do servo savers help do to your car. do you recomend me buying one for my xxx-nt
and what is a failsafe
Old 02-14-2005 | 09:24 AM
gerwen's Avatar
Default RE: servo saver question and fail safe question
A servo-saver is designed to absorb some of the impact on a collision that would normally damage the servo (ie hit the front wheel on something that would cause it to turn rapidly and strip the servo)
Are you sure your car doesn't already have a servo saver?
Failsafe brings your car back to a pre-set condition (usually neutral or brake on) in the event you lose radio contact, or the battery drops below a certain voltage (if your batteries get knocked off the car, it won't help, so you better get a throttle return spring). It basically prevents a runaway. These come highly recommended (mostly by folks who have had to chase down runaways)
Old 02-14-2005 | 09:49 AM
when my crystal fell out i didnt have a throttle return spring on my xxx-nt and it went wot and hit a tree
thought about getting a fail safe but just put to springs on my throttle arm and i dont need a fail safe now
i saved $20
Old 02-14-2005 | 10:07 AM
gerwen's Avatar
The springs wouldn't have saved you when you lost the crystal, the receiver went buggy and pushed the throttle wide open. I don't have enough experience to tell you whether or not a fail-safe would have prevented your crash though. I think that's what they're supposed to do, but i'm not sure if they would kick in for a lost crystal.
Old 02-14-2005 | 10:24 AM
the springs work becuse when i tested it from wot and turn the radio off it closes the carb
Old 02-14-2005 | 10:49 AM
Yea but your servos still had power because the radio was on. When u loose the crystal it doesnt turn the radio off it looses communication.
Old 02-14-2005 | 02:48 PM
I can't believe that a company with the reputation Losi has would ship an ST without a servo saver. You probably already have one in there.
A failsafe is a must-have. I ran an Ofna micro failsafe in my GT, and it works great. Just remember to secure your battery pack and route your wires safely around the engine, 'cause if you lose power the failsafe won't do jack for you.
If the crystal just fell out the servo was probably still getting a signal to stay at WOT. There's no TRS that could fight that, but a failsafe would probably have saved it.
Old 02-14-2005 | 04:29 PM
does the stock xxx-nt come with a throttle return spring and a servo saver
Old 02-14-2005 | 05:05 PM
Yea the Rustler says it comes with a Throttel return spring ,but i crashes into my house when the battery fell out why didn't it do anything. WHat is a good TRS. I want one or a failsafe not sure which. Maybe both. Better to spend $30 on them thab 300 on a car or even $50 for pieces + the hassle.
Old 02-14-2005 | 08:21 PM
ORIGINAL: xxx-nt racer
Sigh. You have a manual don't you? Is it so hard to open it and read?
I think most stock TRSs are just to pull the carb closed if the throttle linkage comes off. Some people claim to have them strong enough to overpower the servo (if the batteries come out) but I'm somewhat doubtful of that.. it would take a beefy spring.
Old 02-14-2005 | 10:22 PM
it dosent take a beefy spring 2 just takes 2 weaker springs
it will over power the servo when it has lost power
http://img.photobucket.com/albums/v3...t/DCP_2383.jpg
Old 02-15-2005 | 05:28 AM
I use a Kyosho Mad Force TRS spring, with enough tension to overcome the unpowered servo. The servo is dual ballraced which helps, and has enough torque to overcome the spring tension with ease.
A TRS is also useful to guard againts servo power lose (broken wire, battrey pack gets smashed out in a crash, etc.).
IMO you always need to run with a TRS (set to overcome dead servo) and an intelligent failsafe.
Old 02-15-2005 | 08:29 AM
No, the Losi doesn't come with a failsafe... not many trucks do. My RC10GT and my MGT didn't... but I added them. The failsafe will kick in if there is radio interference or if there is a drop in voltage.. not a complete loss of power. If my receiver batts get too low, then the failsafe will just make the servo go to where I programmed it to go... which is full brake.
Get a failsafe and run a throttle return spring. I had an incident where the pin came off the servo on my RC10GT, and it took off down the road (i took off the TRS because I thought it allowed the servo to move faster).. luckily i escaped with no damage, but needless to say.. I have the TRS on both cars now.. hehe
Old 02-15-2005 | 02:08 PM
just curious, but it seems a TRS that is strong enough to move a regular servo without power would cause the servo to suck LOTS of power in normal use... (might be the reason for the spring is to compensate for the constantly dead batteries caused by the spring! [8D]
Old 02-15-2005 | 03:28 PM
the spring in mine is just when the linkeage on either the servo or carb pops off. I would also think that a spring/s that is powerful enough to turn a servo with no power would really make it harder for the servo to turn, especially a stock servo.
Old 02-15-2005 | 07:46 PM
If you have a fully ballraced servo, of more than standard torque (I'm actually running a mere Hitec 325HB single bearing 51oz servo), then having a TRS set up to close a dead servo at WOT works fine. Yes the servo has to work harder, but it hasn't slowed it down any (which I'm suprised at). And the battery depletion concern is really pretty inconsequential, that's like not upgrading to a more powerful steering servo because of battery life concerns.
I've never had a battery go flat whilst out bashing in any car (three in total) with a TRS set up to close the dead servo. Guess it depends how long you bash for.
Old 02-15-2005 | 09:30 PM
Ok so with a servo with power it can over power the TRS however if the servo loses power it just goes like limp. What if the servo is to weak or the spring basically it sucks and u wasted 2 bucks?
Old 02-23-2005 | 10:54 PM
my return springs work when i take the crystal out
it closes the carb
save your money and go to your lhs and get 2 trs for $2 [8D]
