-Official Traxxas JATO Thread-
#3051
TX
RE: -Official Traxxas JATO Thread-
ORIGINAL: devo208
the o.s.12tz is a direct drop you just have to take the motor mount spacers off and slot the crank for a e-clip. And i'll bust a 3.3 ass.
just kinda curious cause i run against my buddies in top speed runs.....
#3053
Hey guys what fuel are you running in your trx 3.3? I am getting a new engine and am wondering whether to use 25% nitro, I used 16% and it went OK but that engine's dead now so time for a new one... whats your recommendation? 16% or 25%?
#3055
I was thinking about getting the same engine fro my jato. Is that a pullstart or how exactly does it work? I have never seen that. Also what header? I was also thinking about a Buku pipe along with the 12TZ?
#3056
PA
You need a bump starter box to start this engine and i just used a LHS exhaust. You have to remove the motor mount shims or use a different bigger flywheel.
#3057
I also have a 12 TZ for my jato. I just wanted 2 know what flywheel do I need 2 make it fit and lock nut do I need. I see you said I would need 2 slot the crank 4 the e-clip. I noticed the front of the crank has some threads. would it work if I found a small enough screw and screw it in the front of the crank 2 hold it all on. What bumpstart will work?
#3058
PA
I used the 3.3 flywheel and used washers to shem up the flywheel nut. I used a dremmel to make the slots on the crank because you may have to cut the crank to use a bolt at the end to hold the bearing and the bell.
#3060
NC
ORIGINAL: ajk2649
Ok I see what your saying. what starterbox works 4 it?
I use this starter box..has two 550 motors and the front LCD panel w/12 cell battery included.
If you upgrade to a 3 shoe flywheel, with tighter springs, acceleration will be even better.
#3061
What exactly do you mean shim it with a spacer? Im not sure what ur talking about. I just put the flywheel and everything on it but the flywheel fits kinds loose arund the shaft. You have a link 2 the the 3 shoe flywheel and spring
#3062
NC
ORIGINAL: ajk2649
OK take a look at the picture I posted. See the end of the shaft has a Jato front wheel spacer in front of the CB. The spacer is much lighter and as wide as three for 4 shims and fits the shaft perfectly....no play. Then just use a shaft screw from a shim kit to hold everything in place.
I use the HPI but any 3 shoe clutch and shoes will be fine. This will allow you to stall the clutch higher by using diff. weight springs. The .12 has mad mid-range and top end, but it makes it power much higher into the rpm range when other engines stop pulling.
#3063
Ok man I see exactly what ur saying now. Ill be sure 2 give it a try. It sucks cuz its getting cold and I wont be able 2 break it in and see the beast in action.
#3066
Well do you know if this would work for my os 12 TZ
http://www3.towerhobbies.com/cgi-bin...?&I=LXVCK3&P=7
#3067
yea but i mean is that the best way? because many talk about the heatcycle, i have 2 jatos and i am going to break in the new one, but the old i didnt make it like the manual said, i just run it changing the speed and i got it up 66mph after that, thats why i dont now wich one is the best way, everyone says something different!!.[X(]
#3068
PA
I'd go by what the manual says. If something's wrong with your engine and you call traxxas they probably won't help you if you didn't break it in according to the manual. Also it is clearly stated exactly what you have to do instead of the other somewhat vague methods out there.
#3069
NC
ORIGINAL: devo208
What gearing you running with the .12TZ. I'm running 22/58 with my JLR .12 and crazy top end, pretty good acceleration. Haven't tried anything lower yet.
#3071
My Feedback: (10)
Well my motor finally threw a rod. It seems the top bushing on the crank just wore completely away and then the crank snapped down the middle and punched a hole in the piston. Piston was clean and was still real tight. I got this second hand so no telling how old it is. I always ran it kinda rich on 15% fuel with 18% oil. Case, crank and all look good and will rebuild but my question is what con rod.? I don't want to use the stock one again as they are really light weight stuff. Davis models makes a heavy duty one at Tower and I was wondering if any other makers make a good rod for these 3.3 motors?
http://www3.towerhobbies.com/cgi-bin...3&I=LXVHW4&P=K
#3073
NC
ORIGINAL: devo208
nitro - i'm using 22-56 like you said crazy top end, neck and neck with the 4-tec.
How does the 20 tooth impact top end...I know it has to be a beast outta the whole.
#3074
I know there's probly a answer all ready here on this thread but im too lazy to look though all the posts.
What im wondering is, is there hex (12mm) adapters to fit onto the front of my jato 2wd or can i convert it ie what parts would i need, to convert it to use 4wd wheels.
#3075
ORIGINAL: marionette1975
This may help out a bit. This guy doing the same thing.
http://monster.traxxas.com/showthrea...eel+drive+jato
