Official Nitro Evader ST Thread v2.0
#9456
IL
RE: Official Nitro Evader ST Thread v2.0
thanks, i masked off the inside of the body, trimmed out my flame design in the mask and removed the area i wanted to paint the flames on, then i mixed up a metalic blue pearl and very lightly sprayed the flames then i pulled the mask from the rear of the body and sprayed it with a mettalic sapphire blue, and then pulled the rest of the mask and sprayed the entire inside with a yellowish green and that made the flames take the color that they did took probably two hours to do start to finish. i use an airbrush and custom blend all my own paints.
#9462
PA
I just got the new Tower catolog yesterday and they still have the st in there??? Where did yu see it was discontinued??
#9463
thinking about selling my evader... as a roller.... new masher 2k's on it new rear diff case and gears, needs a bulkhead comes with 2 bodies and half gal of fuel and glow plug igniter and radio gear but shorted out somewhere, has 2 new servo's and original motor that needs rebuilt, i have an os18 cvrx that was broken in and thats it ran like 8 times..... give me a price in pm's and we can talk buisness.... im going up to 1/4 scale and starting a buisness
oh and it has a new motor mount.... and a stainless steel brake disc custom built and some graphite brake pads
#9464
IL
http://www3.towerhobbies.com/cgi-bin...1p?&I=LXDJL9**
they didint discontinue just were outta stock at tower.
#9465
KY
my engine revs up very very high and the throttle is closed all the way any suggestions why it would do this i striped out the gear and it wont engine slow down it just revs up really high
#9466
IL
Are you meaning the gear stripped out and now the engine idle's at a high rev? If so you should just need to replace the gear, if that doesint help then post and let us know we'll help ya figure it out. Id imagine its just the gear if im understanding you right.
#9467
KY
its not just the gear the engins rev is high like your flooring it w/out the gear on and that's what caused it to strip it is runing like the carb is all the way open when it s closed
#9468
NY
ORIGINAL: evader512
air leak
#9470
IL
Had that happen before my carb was able to loosen itself and that led to the evader needing like 60$ worth of parts and having to replace my neighbors flowerpot.
#9472
NY
