tool to keep engine from turning
I have an O.S. .18 TZ-TX and am looking for a tool that fits the p3 plug threads to keep the piston from moving..anyone know where I can get one? Thanks.
Dewt.
Dewt.
Why do you need to keep it from turning? Are you trying to get the clutch nut ff the crankshaft? If you are then you can buy a flywheel tool from duratrax that works just as well.
GA
Are you sure the threads are different then the regular plugs? [8D]
What are you running the TZ in? I hope to be getting one some.
All so how do you like it?
ND
is this what your looking for ? http://www2.towerhobbies.com/cgi-bin...?&I=LXD567&P=0
SC
No turbo and standard plugs use different threads. Here is what you need http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMW34
