RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Spur gears
Old 05-16-2006 | 09:39 PM
Default Spur gears
Im shredding spur gears for the xxx nt at an alarming rate suddenly. Does anyone know if its possible to get a metal one for losi? The kevlar crape aint cutting it.
Old 05-16-2006 | 09:43 PM
Nitro Rustler Racer's Avatar
Default RE: Spur gears
are you sure your mesh is set correctly? make sure it isnt to close to or to far apart
Old 05-16-2006 | 09:49 PM
When I had my stock motor on I messed with the mesh all the time. Never shredded a spur. Today I bought the thing at 5:00 started running it at 6:00 and it shredded at 6:01.
Old 05-16-2006 | 09:50 PM
46u's Avatar
46u
If you are eating up spur gears either you have a problem or are not setting the mesh properly. I have the same spur gear on all my nitro’s including my Savage for many gallons. Do not know if they make a metal one for your truck but if you have something wrong or do not set the mesh properly it may last longer but there will still be problems in the long run.
Old 05-16-2006 | 09:53 PM
try loosening the slipper if the xxxnt has one, that could help with the stripping, spur gears dont just strip that easily, i havent stripped mine in like 6 years and still going
Old 05-16-2006 | 09:56 PM
no doubt in my mind, your spur gear mesh is bad or more then likely your clutchbell bearing are shot. I would check the bearings on the clutchbell, then if those are fine, set the spur gear so that is is almost at a slight grinding point. You just want the mesh to click. Hard to explain. Then tighten the crap out of your engine mounts so the engine can't move. Guaranteed fix!
Old 05-16-2006 | 09:59 PM
ORIGINAL: Tmaximum375
loctite on engines mounts
and if a xtm sopur fits a xxxnt, then here
http://www.hobbypeople.net/gallery/149651.asp
Old 05-16-2006 | 10:29 PM
Screws for the mount do have locktite on them. I just dont want to walk into the hobby shop tommorow and go guess what I fried another one. Although there happy to sell me another one there probably thinking (what a dumbass) in their head.
