GT Diff HELP!!!
Is there a better diff for this thing? Mine keeps slipping (backing out) and now I've lost some of the bearings.[sm=confused.gif]
BTW it is the RTR version.
The rebuild kit from www.rc10gthobby.com is better than stock. Tighten the bolt down until its stops then your good don't back it off like they say i think its too loose and it will slip and wear out faster. Make sure too get the tranny savers they keep the dirt out and makes your diff last alot longer. Always check your diff adjustment after runs to make sure its not slipping
small amount of lock thred .. the blue stuff is for lite use.. works good for this issue.. [link=http://poptartschat.com]poptartschat.com[/link]new rc10gt forum off site of this one.. help us grow .. its FREEEEE
Don't use thread lock on anything screwed into plastic. Only metal to metal.
Make sure the t-nut isn't stripped, that could cause it to loosen up.
Make sure the allen head is on right side of the diff, not the left.
Check periodically to keep it properly adjusted...Once it starts to slip, it will toast in short order. Adjust the slipper to slip before the diff.
